Carbs done!
  • Tat2demon
    • Jun 2012
    • 718
    • Sioux Falls, South Dakota
    Carbs done!
    Well its take 3 weeks to get everything delivered, tear it all apart, clean everything and get it all back together but Im finally done. The carbs and airbox are both from Diverray. Rebuild kits for the gasket and idle screws from Georgefix on ebay.
    I completely tore them apart, all the way down to shafts and seals. Replaced the butterfly screws and a few steel bolts on the covers all with stainless hex.
    Painted with Rustoleum high temp engine paint. Not so much for the temp as much as for the fuel resistance.
    When I got the carbs and airbox I was a bit disappointed with thinking I was going to need to get the airbox re-chromed due to all the little rust spots. Today I hit it with some Eagle One polishing stuff.
    Before-
    After-
    Thanks everyone for putting up with all the questions while I got these back together.
    Nate
    78 XS11 "Matilda" 2H7 000364
    K+N Air Filter
    88 Voyager XII
    81 XJ650 Maxim
  • mikubuilder
    • Jul 2011
    • 548
    • Westland, Mich.
    looks great! now the tricky part....put them on the bike and let it rip
    Nick
    1982 Virago 750 (it's alive!)
      See, that wasn't so hard, was it?....
      • Tat2demon
        • Jun 2012
        • 718
        Ive run into some issues while trying to synch them.
        First, after getting them in I realized the PO must have removed the vac advance. There was nothing hooked up to the old mystery carbs and where Im guessing its supposed to hook into behind the timing cover is a rubber plug.
        Second, the PO had cut a hole in the oil breather area and put in what looks like an automotive breather cap. Now that I have a stock filter, I need to find something to plug up the old hole.
        Now for the synching. I can get all 4 carbs syched but cant get it to idle lower than 2k with the idle knob backed all the way out. The idle mixture screws are a full 3 turns out. I started at 1.5 then to 3 but no difference.
        Ideas on the vac advance and idle problems?
        Nate
        K+N Air Filter
        88 Voyager XII
        81 XJ650 Maxim
        • Tat2demon
          • Jun 2012
          • 718
          Just occurred to me, without figuring out how to hook up the vac advance, that fitting on number 2 is open. Will close that off and try again tomorrow after work.
          Nate
          K+N Air Filter
          88 Voyager XII
          81 XJ650 Maxim
          • Tat2demon
            • Jun 2012
            • 718
            Just went out and popped the timing cover off. The vac advance pot is in there with about 1.5 inches of hose and a plug. Why the hell would someone plug off the advance? Im really starting to hate the PO.
            Nate
            K+N Air Filter
            88 Voyager XII
            81 XJ650 Maxim
              Also sometimes the clamps on the carb boots can hold the throttle open some if they are not positioned right.
              • Jeffintampa
                • Apr 2011
                • 344
                • Zephyrhills, Florida
                nice
                now do mine lol, As far as I know mine have never been off the bike, runs good (unless were in the pouring rain). My boots that go between the carbs and the motor all all cracked but dont seem to leak. I know some day I will have to change them but plan on a carb rebuild and sync then
                Bike History:1980 XS 1100 special current bike
                1980 XS 850 special wife sold
                  As far as the idle goes, I just went through this. You weren't properly bench synched before you started this process. You're trying to sync to a master that is dialed up too high. Take them off, bench sync them, and do it again.
                  • GLoweVA
                    • Jun 2011
                    • 1957
                    • Virginia Beach, VA.
                    http://www.xs11.com/forum/showthread...ght=bench+sync
                    Marty, If you read above, he did the sync with no advance hooked to #2, so it was sucking in air there and thus causing a higher idle.
                    Once he gets the vac advance hooked up, he should be able to dial it down then.
                    80G (Green paint(PO idea))
                    The Green Monster
                    Got him in '04.
                    bald tire & borrowing parts
                    Scarlet
                    Got her in '11
                    Ready for the twisties!
                    81H (previously CPMaynard's)
                    Hugo
                    Cold weather ride
                      There should be no vacuum at the #2 carb port at idle. It's ported.
                      At idle the butterfly should cover the oraface inside.
                      • Tat2demon
                        • Jun 2012
                        • 718
                        Going out in a bit to try it again.
                        Pretty sure I know what went wrong.
                        I did do a bench sync, but when it came time to do a regular synch, I did it 1+2, 2+3, 3+4, then was all over. I misread the directions on the gauges. Will try again doing the pairs then synching them together.
                        Pretty mad at myself for this. Took me two hours to get those damn things in, now I gotta pull them back out
                        Nate
                        K+N Air Filter
                        88 Voyager XII
                        81 XJ650 Maxim
                        • Tat2demon
                          • Jun 2012
                          • 718
                          Yeah mine look like crap too but no leaks. Im going to replace them this winter when I do a full tear apart.
                          Nate
                          K+N Air Filter
                          88 Voyager XII
                          81 XJ650 Maxim
                            3 is your static carb. 4 to 3, 1 to 2, then 1/2 to 3/4.
                            • Tat2demon
                              • Jun 2012
                              • 718
                              Yeah thats what unclearly tried to say. :P
                              Nate
                              K+N Air Filter
                              88 Voyager XII
                              81 XJ650 Maxim
