Carbs done!
    You can check them with a vacuum pump or just hook them up to a vacuum source on your car. Tee them all together and make certain the all read the same under the same condition.
    Do that first and then we can explain how to adjust your idle mixture with the guages.
    • Tat2demon
      • Jun 2012
      • 718
      • Sioux Falls, South Dakota
      #47
      Ok, will try to get that done in a bit. What makes you think they are not right by looking at the pics?
      Nate
      78 XS11 "Matilda" 2H7 000364
      K+N Air Filter
      88 Voyager XII
      81 XJ650 Maxim
        Nothing really, but it looks like at least 2 cyls are a little rich. Just want to be certain the guages are reading correctly or all is for nothing.
        • Tat2demon
          • Jun 2012
          • 718
          #49
          Ah ok. The dark one is the carb that had needle I had to drill out. It also has a float with the sides crushed in. No surprise that one is so different.
          Nate
          K+N Air Filter
          88 Voyager XII
          81 XJ650 Maxim
          • Tat2demon
            • Jun 2012
            • 718
            #50
            Will hooking all 4 gauges into a 4 way aquarium air pump manifold then hooking that to one of the vac hook ups on the bike work for testing this?
            Nate
            K+N Air Filter
            88 Voyager XII
            81 XJ650 Maxim
              A steady vac source would be better. The bike will bounce around.
                #52
                Originally posted by Tat2demon
                ...It also has a float with the sides crushed in. No surprise that one is so different.
                If you have a damaged float, you'll be wasting your time until you get that replaced...
                  He also has an extra hole drilled in a carb plugged up with JB weld.
                  • Tat2demon
                    • Jun 2012
                    • 718
                    #54
                    That filled hole is a non factor. Completely filled in, smooth on both sides. How much with that float be a problem and is there any way to fix it? Asked Ray about it and said it shouldn't be a problem.
                    Nate
                    K+N Air Filter
                    88 Voyager XII
                    81 XJ650 Maxim
                      #55
                      ...How much will that float be a problem and is there any way to fix it? Asked Ray about it and said it shouldn't be a problem.
                      A fairly big problem... If it's size is different from the rest, it will displace less fuel in the bowl and cause a rich condition.... which is what your seeing. As far as 'fixing' it, that depends. If it's crushed too much, replacement will be the only fix. Some have 'unsoldered' these and straightened them and resoldered them, but that's extremely tricky to do without changing it's weight. Some have put the float in boiling water and the expanded air from the heat has 'puffed' the float back into shape. Sometimes these things work, sometimes not...
                      • Tat2demon
                        • Jun 2012
                        • 718
                        #56
                        The outside ends are "bowled" in. I tried boiling water with no luck. Looks like I need to dump even more money into these things. It never ends does it? Starting to think its just easier to put the mystery carbs back on. I could at least ride it with them.
                        Nate
                        K+N Air Filter
                        88 Voyager XII
                        81 XJ650 Maxim
                        • Tat2demon
                          • Jun 2012
                          • 718
                          #57
                          Can only find one vac line on my truck and at idle theres no vacuum.
                          Nate
                          K+N Air Filter
                          88 Voyager XII
                          81 XJ650 Maxim
                            What kind of truck?
                            • Tat2demon
                              • Jun 2012
                              • 718
                              #59
                              91 Silvarado
                              Nate
                              K+N Air Filter
                              88 Voyager XII
                              81 XJ650 Maxim
                              • Tat2demon
                                • Jun 2012
                                • 718
                                #60
                                Pulled off the carbs and put the old mystery carbs back on. Runs great again.
                                Nate
                                K+N Air Filter
                                88 Voyager XII
                                81 XJ650 Maxim
