I havent had a chance to synch the gauges yet but wanted to get some input on the plug color.
I thought it was running lean but you say its rich. 2 of the plugs have some color on the insulator while the other 2 look absolutely brand new on the insulator. All 4 are white on the top part of the electrode.
Once I get the gauges checked, whats the best way to go about setting the carbs? Floats only? Run at each 1k RPM increments for a while and check the plugs then swap out jets accordingly?
I read about having to change out jets but have yet to see how to tell the difference between jettting/float/needle adjustments.
