Carbs done!
  • #31
    Have you tried freezing the carb body first, then trying to pick or punch it out?
    Another method that has worked for some.
    XJ1100 Ruby Red
    XS1100LH "Midnight"
    1972 MGB Roadster "sold"
    • #32
      Ill give that a shot first. But after all the pick work last night the hole has enlarged a bit. If I can get the tip out after freezing I wonder if the hole size will be an issue.
      Nate
      78 XS11 "Matilda" 2H7 000364
      K+N Air Filter
      88 Voyager XII
      81 XJ650 Maxim
      • #33
        Jb weld does get soft and falls apart in gasoline.
        • #34
          I know the JB Kwik does but from what Ive been reading the regular is impervious to it after it fully cures.
          Nate
          K+N Air Filter
          88 Voyager XII
          81 XJ650 Maxim
          • #35
            It still cant handle constantly being in contact with it.
            • #36
              Ok the freezing didnt help so I started drilling. An 11/64s bit fit in the screw hole perfectly so I didnt mess up the threads and the hole was just snug enough to keep the bit dead center. I was able to drill out just enough to get the tip out but not so much that I made the hole into the throat any larger.
              Ideas on how to close up the secondary hole that someone drilled in the past if JB wont work?
              Nate
              K+N Air Filter
              88 Voyager XII
              81 XJ650 Maxim
              • #37
                Gas resistant Epoxy
                Get some of the gas resistant epoxy - it too will eventually break down in gasoline (my experience, YMMV) but takes a lot longer - for as little actual gas as that hole will get exposed to I think you will be fine.
                Look for gas tank repair stuff. Its only meant as a temp repair for a holed tank while off roading say - which is where I have seen it used and it will certainly save you from being stranded in the desert.
                Or you could solder it!
                John
                '81 XS1100H - "Enterprise"
                • #38
                  Well I have solder and an iron. Just regular old solder on the inside of the throat? Obviously I cant get it in the screw hole.
                  Nate
                  K+N Air Filter
                  88 Voyager XII
                  81 XJ650 Maxim
                  • #39
                    After reading on aluminum soldering I decided to go the JB route. Will see how it holds up.
                    It need to cure for 20 hours so will install tonight and wait till tomorrow afternoon to tune.
                    Nate
                    K+N Air Filter
                    88 Voyager XII
                    81 XJ650 Maxim
                    • #40
                      That would have been my vote too
                      Good luck!
                      John
                      • #41
                        Ok got them put back on and everything hooked up. Just waiting for tomorrow afternoon.
                        During another hour long session of putting it all back in a terrible thought occured to me. After the synch and idle tune, I take it out for a ride, bring it back and check the plugs. Lets say the mix is off. Do I need to pull these dang things off again, adjust, put back together and test ride again and again until its right? Or can the changes be made while theyre on the bike?
                        Also, I see people talk about changing the float for the mixture but in my Haynes manual is says change the needle.
                        Nate
                        K+N Air Filter
                        88 Voyager XII
                        81 XJ650 Maxim
                        • #42
                          Depends on what you need to adjust. If you need to change jets then yes you have to pull them out. If you just need to adjust the idle mix screws then you can leave them on the bike. Leave the needle clip in the center of the needle. Floats can be adjusted some for more or less fuel, just depends on when the engine is lacking fuel.
                          Floats effect all throttle ranges
                          Pilots and idle mix screws - mainly just low end but to a small degree all ranges.
                          Mains and needles - mid range
                          Mains - too end
                          • #43
                            Got them synched very easily this time. After a visual bench synch with the first opening they were all withing half of a notch on my gauges.
                            I still cant get the idle as low as its supposed to be after warmup. It wont go lower than 1500. I sprayed around all the boots with carb cleaner with no effect.
                            Tuning really didnt happen. I tried the tune by ear but really never heard the slight pick up and settle down. That may be due to the higher idle. So I just have them at 1.5 turns out until I hear a better idea from you guys. I did try to turn them out a bit thinking a little richer would bring the idle down but it actually picked up a bit and stayed there. That was another full turn out so at 2.5 out total.
                            I took it out for a couple mile ride tonight and heres what the plugs look like. All the floats are at 25mm right now.
                            From the little I know, it looks like I'm running lean. Whats the next step I need to take?
                            Thanks a lot.
                            Nate
                            K+N Air Filter
                            88 Voyager XII
                            81 XJ650 Maxim
                            • #44
                              jat,
                              are u using needle vac guages?
                              if so they need to be callibrated.
                              pete
                              new owner of
                              08 gen2 hayabusa
                              former owner
                              1981 xs1100 RH (aus) (5N5)
                              zrx carbs
                              18mm float height
                              145 main jets
                              38 pilots
                              • #45
                                Yeah. How can you tell? The needless were all exact accrued all 4 gauges when I started.
                                Nate
                                K+N Air Filter
                                88 Voyager XII
                                81 XJ650 Maxim
