And, yes, you don't have to buy this kit, it just took me 30 sec to find one on line that included FUEL caps, like I said, do your own resurch, I can get them cheap here, good luck to others
But they will fit
Or you can just buy the cheap ones at the auto parts store, just tell them they are "GAS" plugs
And i will hope for a better supply of fuel caps in your area
I only want the best and cheapest for all members, as my $$ are limited, so may you all find a cheap solution to your problems
So the cap is not really exposed to fuel and will live there quite happily I would suspect for a decade or so.
If you did forget how your petcocks work and turn them the wrong way, just turn them off, remove if even just a vacuum cap, rinse with water, dry it out with a Q tip, put it back on, and don't turn to "prime" again
