Removing The Octypus
  • mooseman
    • Jun 2007
    • 28
    • Pocono Mtns, PA
    Does anyone have a link to a thread for removing and replacing the octypus entirely? Please let me know. Thanks Mooseman
    79 SF
  • Cobia
    • Jul 2007
    • 1587
    • Palm Beach County, Fl
    What scoot do you have? It's a little different based on the model.
    1980G Standard, Restored
    Kerker 4 - 1
    850 Rear End Mod
    Automatic CCT
    1980GH Special, Restored
    '82 XJ1100 (Sold)
      Only the Specials have the octy; the standards have that feature built into the petcocks.
      You need to block off the 'prime' outlet on your petcocks when removing the octy... some just connect the two petcocks together or put a short piece of hose on with a bolt 'plug'. For a bit more elegant solution, look here: http://www.xs11.com/forum/showthread.php?t=32980
      Then simply connect the fuel line directly to the carbs...
      • Cobia
        • Jul 2007
        • 1587
        Steve,
        I beg to differ. I removed the octy from my G and J and had to connect vacuum lines from two of the intake manifolds to each of the petcocks, and then ran my fuel lines to the opposite side intakes of the carbs. This allowed me to install inline fuel filters without the risk of kinking the lines. I also have this setup on my J.
        Kerker 4 - 1
        850 Rear End Mod
        Automatic CCT
        '82 XJ1100 (Sold)
          The XJ would have the octy, as it shared petcocks with all the Specials. But if your standard had one, it was installed by a PO. I suspect that somebody swapped carbs and didn't pull it off the carb bank....
          • Cobia
            • Jul 2007
            • 1587
            My G has those 'transitional' carbs where the pilot jet tubes are plugged with rubber stoppers. It was manufactured at the end of 1979 also.
            Don't know if that has any bearing on it. This bike was bone stock when I got it from a co-worker who was the original owner. It only had 14k miles on it.
            Kerker 4 - 1
            850 Rear End Mod
            Automatic CCT
            '82 XJ1100 (Sold)
              You've got me curious... how was that plumbed? Were both petcocks and the octy connected to vacuum sources, or just the octy? If it was the latter, then the only way it would work would be if the petcocks were set on 'prime', but that defeats your 'reserve' function. If both, then you simply had two shut-off points.
              Somewhere along the line, somebody swapped carbs or made a point of installing that for whatever reason, unless somebody grabbed the wrong bits out of a bin on the production line and it made it past QC. Neither the manuals or the parts fiche show those on a standard, only the Specials and XJ.
              • Cobia
                • Jul 2007
                • 1587
                I really don't remember that was over four years ago. But it's quite curious.
                Kerker 4 - 1
                850 Rear End Mod
                Automatic CCT
                '82 XJ1100 (Sold)
                • cywelchjr
                  XS-XJ Super Guru(Deceased)
                  • 4450
                  • Sacramento, CA
                  Yes quite curios indeed since even the early 80 standards didn't have an octy as ALL standards have vacuum petcocks with the octy functionality built into the petcock removing any need for an octy. Even the later 80 carbs are basically the same as the early, they just don't have the cross passage or the plug, but they are identical otherwise.
                  • XS1100_OEM4ME
                    • Mar 2009
                    • 1619
                    • Fort Myers, Florida
                    Thread
                    Back on thread (and I get off thread more then most) If you have the octy, and are going to remove (which I don't recomend) it and you have the special style petcocks (no vacuum lines to them) Cap off the prim at the petcock with a line cap, $0.25 at any auto parts store (you wont need it as run / resurve become a prime) Next, run the two remaining lines tward the carbs two fuel input feeds. I would put a 4 way or two "T's" so both petcocks have the same fuel feed at all times JAT. This would also be a good time to install a couple of in line filters with all the extra room you have. Just make sure you turn off the fuel everytime you turn off the bike, the needles may work, and they may fail and poor gas in your oil
                    1980 XS1100 Special
                    1990 V Max
                    1982 KZ750 LTD Twin
                    1974 CB750-Four
                    Past/pres Car's
                      Originally posted by XS1100_OEM4ME
                      ..Cap off the prime at the petcock with a line cap, $0.25 at any auto parts store (you wont need it as run / resurve become a prime)..
                      The problem with that is the caps you can buy won't take exposure to raw fuel; several people have tried that and had them swell/leak. Those caps are vacuum caps, not for fuel lines. I used them on my conversion, but I sealed the prime outlets internally in the petcock so they aren't subjected to fuel. Strictly a trim item...
                      • tweeleft
                        • May 2009
                        • 110
                        • Bend Oregon
                        I removed the octy and just used the tee fitting to run the main and the prime into the carbs with no problems. And plugged the vacuum with a hose and bolt. Love these bikes
                        Keep the shiny side up
                        1979 XS1100SF
                        Mac 4-1
                        Drilled airbox Uni filter
                        Vmax bars
                        Virago 1" shorter shocks
                        30K miles
                        http://i1228.photobucket.com/albums/...429_135845.jpg
                        1981XS1100SH
                        '80 G Forks and Triple Tree
                        '80 G tank
                        Mac Turnouts
                        Virago 1" shorter rear shocks
                        SH Headlight
                        http://i1228.photobucket.com/albums/...psd6adaae1.jpg
                        61 Wife
                        83 Son
                        86 Son
                        89 Daughter
                        • XS1100_OEM4ME
                          • Mar 2009
                          • 1619
                          i bought fuel end caps, not vacuum caps, you are right, there is a diff. Still $0.25 each
                          1980 XS1100 Special
                          1990 V Max
                          1982 KZ750 LTD Twin
                          1974 CB750-Four
                          Past/pres Car's
                            Got a part number? No one I've talked to knew of any such thing....
                            • XS1100_OEM4ME
                              • Mar 2009
                              • 1619
                              Please
                              PLEASE do your own resurch from now on, I am trying to turn over a new leaf and not get pissed off at challeges form others Merry Christmas
                              https://www.denniskirk.com/271589.sk...utm_medium=cse
                              1980 XS1100 Special
                              1990 V Max
                              1982 KZ750 LTD Twin
                              1974 CB750-Four
                              Past/pres Car's
