Bike just wont start!
  • Axel
    • May 2007
    • 869
    • Renfrew,Ontario
    #46
    test for power
    test for power at the coil on the red/white wire that is connected to the positve . Key must be on IIRC . If no power - trace back through the wiring harness until you find power ,cleaning plugs and connections along the way and re- plugging them with some di-electric grease . OR start at the TCI and check for power at the red/white wire . Did you check for that main fuse that isnt in the fusebox but under the seat hanging from the frame ???
    XJ1100K
    Avon rubber
    MikesXS black coils
    Iridium plugs w/ 1k caps
    MikesXS front master
    Loud Horns (Stebel/Fiamm)
    Progressive fork springs
    CIBIE headlight reflector
    YICS Eliminator
    • edavi394
      • 108
      • louisiana MO
      #47
      ok I made some progress I did get all wires to spark! but now I keep blowing a fuse as soon as i turn the key on. the fuse that keeps blowing is the one closest to the front of the bike in the fuse block
      "Lead by example, Follow by choice"
      1979 xs1100sf 10,182 miles
      • edavi394
        • 108
        • louisiana MO
        #48
        one more thing each coil is hooked up like it was before but i am not sure abou the plugs. i know one coil goes to #1 & 4 and the othe goes to #2 & 3 but i am not sure what wire from the new plugs goes to what cylender if that makes since. can some one tell me?
        • Axel
          • May 2007
          • 869
          • Renfrew,Ontario
          #49
          Progress
          Excellent . I'm afraid the gremlin of the fusebox is upon you . What is the fuse for ? I have an XJ so I dont have the same fusebox as you . Is it to do with ignition ?
          I dont think it matters which wire goes where as long as the 1&4 coils sparks 1&4 and the 2&3 coil sparks 2&3 IIRC
          XJ1100K
          Avon rubber
          MikesXS black coils
          YICS Eliminator
          • edavi394
            • 108
            • louisiana MO
            #50
            ok I wondered that since I didn't see anywhere that stated how to do that part and it would be REALLY important to know if it mattered. I am not sure yet what that fuse is for I do know the starter wilkl not turn over if it is blown but I don't knw if it goes anywere else or not. I am guessing it has a short somewhere to keep blowing like it does. it even smoked a lil the last time it blew
            • Axel
              • May 2007
              • 869
              • Renfrew,Ontario
              #51
              fusebox meltdown
              My fuse box has fuses for IGN ,Head ,Tail , SIG so I imagine your ignition fuse is the culprit . If you havent replaced your box , it may be a good time to do so . Ppl have said that they removed the box and wiring was melted behind . It might be time to disconnect your battery and inspect .
              P.S. what amp of fuse is it blowing ?
              XJ1100K
              Avon rubber
              MikesXS black coils
              YICS Eliminator
              • edavi394
                • 108
                • louisiana MO
                #52
                I just read in the manual that it is a 10a ignition fuse
                • Axel
                  • May 2007
                  • 869
                  • Renfrew,Ontario
                  #53
                  out riding ?
                  any luck ?
                  XJ1100K
                  Avon rubber
                  MikesXS black coils
                  YICS Eliminator
                  • edavi394
                    • 108
                    • louisiana MO
                    #54
                    no not yet my back went out on me so i have been in bed for the last few days no chance to work on it.. I did get it to start but I need to get a fuse box soon and put the bike back together then I can ride it. but i don't think it will be this week
                    • Axel
                      • May 2007
                      • 869
                      • Renfrew,Ontario
                      #55
                      OIC
                      Sorry to hear about that , bud . Take care
                      XJ1100K
                      Avon rubber
                      MikesXS black coils
                      YICS Eliminator
                      • morticiaann
                        • Apr 2003
                        • 90
                        • Long Beach, CA
                        #56
                        Bike just won't start!
                        *Can you find a hill to roll it down? Mine never starts even when new because of the oil and such that gets in it. After I roll it down a hill, it normally starts and I can see loose nuts and the like that prevented it from running.
                        *I think you have a fat blue spark [It fired over and tried to idle but died after about 2 seconds.] that indicates that the bike will start and is in good running order, basically.
                        *Since you did carb work, it follows that you might have loused something up. Either take it apart and check, let the bike shop look at it, or...... did you get the hose to the vacuum advance in the right place? It looks like the one to the diaphragm and if they are crossed the bike won't start.
                        [IMG]http://michaelwilliamandersen.ga[/IMG]
                        • edavi394
                          • 108
                          • louisiana MO
                          #57
                          Hi, thx for the replys. when I said the bike started and ran for 2 seconds thats because the gas tank wasn't on the bike it just had a lil gas left in the carbs enough to start but not run. all my fuese are a mess so I am going to replace the box then as soon as my back lets me get out of bed I will get it started
                          • edavi394
                            • 108
                            • louisiana MO
                            #58
                            well I can finaly walk again now as soon as I get my fuse box from TC then I can put it on the bike and see what else I need to fix before I can ride LOL. I just couldn't belive how much I had to do to get it ready for the road when I was running good when parked.
                            here is a list of some of the stuff I have done
                            New maintenance free battery
                            New fork seals
                            2 new tires
                            New brakes
                            New gas line
                            New coils
                            New plugs
                            New caps
                            New plug wires
                            New oil/filter
                            New headlight
                            New turn signal
                            New throttle cable
                            New throttle cable assembly with kill switch
                            Carbs rebuild
                            New fuse box and fuses
                            Rebuilt petcocks
                            Rebuilt octi
                            Inline filters
                            2 new fuel t's
                            Stainless carb bolt kit
                            Misc screws and bolts
                            I am sure there are a few more things but I can't think of any right now. I do have a few small things to do still before I ride like change the rest of the fluids but that won’t take long.
                            • edavi394
                              • 108
                              • louisiana MO
                              #59
                              Well I got my fuse box today (thx TC) I will put it on tomarrow and see if it will start i sure hope so after all i have done
                              • thewiz
                                • Oct 2006
                                • 1115
                                • Wilksboro, NC
                                #60
                                Lots of wrenching ...
                                have you done this on bike, edavi. Well done. Sounds very familiar,in fact, had I kept a list on one of mine, it would have compared. Just wait, though .... it's gonna' wanna' rip the bars right outa' your hands. You'll see.
                                80G Mini-bagger
                                Past XS11s
