Originally posted by edavi394
I did not take off the side cover for the engine since all the wires are working on the top side I did not trace it back further. did i miss something by doing this?
There's lots of good reading in the tech sections to get you pointed in the right direction.
anyway any color but yellow is fine with me. does anyone know a site to get some from? btw mikesxs is out of stock
Should be about 5-8K ohm each. The coils without the caps should have been about 15K ohm. You can actually take the caps apart, they unscrew, and you can remove the resistor slug and check it for corrosion, etc. The NGK caps from MikesXS are fairly cheap, shame you didn't just order them with the coils, they also provided the solid core wires in black as well!
