Valve shim library
  • randy
    • Dec 2003
    • 4521
    #76
    I'll check stock after work tonight.
    • randy
      • Dec 2003
      • 4521
      #77
      Rob, I have the 275. PM me your address.
      • Wildkat
        XS Special Gurette
        • Apr 2004
        • 3416
        • Location, Location
        #78
        Changing of the Guard is complete
        MAJOR thanks to Randy for taking this on...
        Please contact him with any shim requests.
        81 SH Something Special
        โ˜บ
        79 SF MEAUQABEAUXS
        81SH Nor'eas tah (Old Red)
        80 LG Black Magic
        78 E Standard Practice
        James 3:17
        โ€œAlis Volat Propriisโ€
        Yamaha XS 1100 Classic
        For those on FB
        • morticiaann
          • Apr 2003
          • 90
          • Long Beach, CA
          #79
          Rick's Cycle Parts is out of business. Carry shims in all the sizes you might need. I wouldn't measure more than .oo5 but that is the thickness change in the next size shim. You will get used to it being a small change if you do your valve adjusting about once a year. It kind of looks like you don't have enough shims. Record the clearance of each valve so you can buy shims in advance. If you increase your clearance from .oo5 to .o1o then you risk power loss valve damage and increased noise.
          [IMG]http://michaelwilliamandersen.ga[/IMG]
          • randy
            • Dec 2003
            • 4521
            #80
            Ummm...is there a request in there somewhere?
            • morticiaann
              • Apr 2003
              • 90
              • Long Beach, CA
              #81
              adjust valves about once a year
              I got a message that said something mystical about going from a .270 to a .280. I don't know where it went but, it was just too many questions at once. I'm thinking of having to replace the valve seats and guides.
              • Crazcnuk
                • 2980
                • Hinton, AB, Canada
                #82
                You don't have to even think about replacing the valves or redoing the heads until you run out of shims, and you are a long ways from there.
                Some people like to set the valves on the loose side so as not to have to set them as often. You have two shims to choose from, usually, that will still be in range, or close to it.
                There is an excel spreadsheet around here somewhere that will calculate which shims you need and shows you two possible shims for each valve.
                Also, in 1980 Yamaha changed the intake setting to 'reduce valve noise'. Exhausts are the same for all XS11's.
                '05 ST1300
                • randy
                  • Dec 2003
                  • 4521
                  #83
                  steward of the shims
                  Kat shipped me the shim library. I have to add my stock to the mix and ill post the inventory on monday...I'm out riding this weekend the weather here is perfect!
                  • randy
                    • Dec 2003
                    • 4521
                    #84
                    Shim Library inventory
                    As of today, we have:
                    • jmnjrpa
                      • Jun 2009
                      • 863
                      • Lewisville, Texas
                      #85
                      Randy,
                      I need
                      2-.265
                      2-.275
                      I have
                      1-.250
                      1-.255
                      2-.285
                      How does it work?
                      Thanks
                      '81 1100 MNS - "Midnight XSpress"
                      Original except:
                      Big John
                      • randy
                        • Dec 2003
                        • 4521
                        #86
                        It works well, thank you.
                        Looks like I have them, but let me get back to you tonight.
                        Here's how it works. I mail the shims. You return mail your shims and re-imburse my postage.
                        Simple and cheap er, inexpensive
                        • jmnjrpa
                          • Jun 2009
                          • 863
                          • Lewisville, Texas
                          #87
                          Thanks Randy,
                          That will work. PMed Addy!
                          Original except:
                          Big John
                          • randy
                            • Dec 2003
                            • 4521
                            #88
                            Library update
                            Current stock as of today...If it's not here, please don't ask for it! Thank you..
                            • Greg Good
                              • 15
                              • So California
                              #89
                              Need shims for my 79 XS1100 special
                              Hey Randy,
                              I need:
                              3 .200
                              2 .240
                              2 .230
                              1 .205
                              If you still have these, would you please send them to me. I will send you back my current shims and return your postage +. You are too kind.
                              Greg Good
                              18161 Bastanchury Road, Yorba Linda CA 92886
                              • randy
                                • Dec 2003
                                • 4521
                                #90
                                Greg, I have all your shims, they'll go out tomorrow.
                                Updated inventory:
