Valve shim library
  • Filter
  • #91
    Thank you!
    Thanks Randy, This is a huge help to me. Greg
    • #92
      Greg, I checked my records and I DID send them, they must have gotten lost Now I only have one that you need, the 230. Do you want it?
      • #93
        Library update
        As of today, 6/24:
        • #94
          Library update
          As of today 6/28 the inventory is...
          • #95
            Great! Now, where does a person buy the cap depression tool to change them? My local Yamaha dealer looks at me funny when I ask for stuff for this old bike. CZ
            • #96
              You need to find a different dealer.
              As for the cap depression tool, it's actually a bucket holding tool and you use the cam to depress the valve, then install the tool, back rotate the cam slightly and pull the shim.
              It's easier to loosen the cam cap nuts to raise the whole cam so you can get the shim(s) out.
              Do all your measurements first so you know which shim(s) need to be changed. End up with the "C" mark lined up on the timing plate. Loosen the cam adjuster lockbolt. Then loosen one cam at a time to get to the shims. When you're done, relock the adjuster. Rotate twice to seat the new shim(s) and re-check the clearances on the ones you changed.
              • #97
                Shim
                OK, I am new but, used shims are not the same thicness as new due to use and all books say to discard? Am I wrong? Should we keep used shims?
                1980 XS1100 Special
                1990 V Max
                1982 KZ750 LTD Twin
                1974 CB750-Four
                Past/pres Car's
                • #98
                  Tool
                  You can get the tool on ebay for about $15.00
                  1980 XS1100 Special
                  1990 V Max
                  1982 KZ750 LTD Twin
                  1974 CB750-Four
                  Past/pres Car's
                  • #99
                    Shim tool
                    here is a link to one currently on ebay
                    http://cgi.ebay.com/ebaymotors/Yamah...item27b31717f2
                    1980 XS1100 Special
                    1990 V Max
                    1982 KZ750 LTD Twin
                    1974 CB750-Four
                    Past/pres Car's
                    • Don't waste your money on this tool.
                      Actually, the official Yamaha tool is good, but this is a bad copy, put out by Motion Pro... hence the M.P. stamped on it. The prong at the end is too short to really hold the bucket down, and the base is too thick to allow it to seat deeper into the valve area to do some good. People have tried to modify this tool, but with limited success.
                      (We raffled one of those off a few years ago as a "gag gift")
                      What does work is the Kawasaki valve tool.... the "W" shaped one. It's a bit of a pain, but it'll hold the bucket down nicely if you can keep it from slipping off.
                      But, truthfully...as mentioned above, it's often quicker and less aggravating to just pull the caps and lift up the cam.
                      Small hint: Clean the oil off the cam gear and place a small mark of fingernail polish on the gear and where it contacts the cam chain. If the cam chain jumps a tooth while you're messing around in there with the cam... you'll quickly notice it.
                      • Tool
                        Please referance page 44 in the Clymer's guild, looks just like the tool I recomended. Works fine for for me but I was fixing motors from 38 years ago and might have some some special skills, but mine seems easy to use. Sure there is better quality at more $ but follow the "Clymer" steps and no chance of skipping a tooth on the cam and needing a new motor
                        1980 XS1100 Special
                        1990 V Max
                        1982 KZ750 LTD Twin
                        1974 CB750-Four
                        Past/pres Car's
                        • Valve shim tool
                          HERE IS A LINK TO A DIFF. BRAND TOOL, SAME USE.
                          http://cgi.ebay.com/ebaymotors/Yamah...item5630783671
                          1980 XS1100 Special
                          1990 V Max
                          1982 KZ750 LTD Twin
                          1974 CB750-Four
                          Past/pres Car's
                          • You may have misunderstood me.
                            I have both tools: The actual Yamaha one and the Motion Pro clone. One works, the other does not.
                            Most of people on this site don't have years of mechanical experience. For a lot of them, this is their first bike and first time doing mechanical maints. We try to explain things in simple terms and throw in whatever tips we can.
                            • Valve shim tool
                              I see. You are right, I would not recomend anyone try valve work or marking timming chain position without very much knowledge and skill or they will have a parts bike when they try to start it.
                              1980 XS1100 Special
                              1990 V Max
                              1982 KZ750 LTD Twin
                              1974 CB750-Four
                              Past/pres Car's
                              • Volunteer wanted
                                To assume the Stewardship of the Shims.
                                Be fore-warned, along with the glamor you can expect:
                                -Library Hours: 25 x 8
                                -**** gets lost in the mail in BOTH directions
                                -Cretins complaining that your shim didn't fix THEIR problem.
                                First taker gets it. PM me.
