Who Wants A Bolt-on Chaindrive And Fat Tire?
  • xschop
    • Feb 2006
    • 1794
    • oklahoma city
    #106
    more info I think should be included
    Yes, the ZRX swingarm is hard to get ahold of, I check the bay regularly for it. Lot of modding going on with that arm.Scappod installed his and then left outta town.Should here from him soon. I figured the brackets for the stock XS shocks will put the new mounts @ 4 inchs away from the top mounts....If I decide to go with this ZRX swinger on my next build, I will use the ZRX shocks or New KZ1000 Shocks (100 bucks ebay) since they are 14.25" I2I....After checking shock lengths, it got me thinking about the KZ swinger again. Since it's 9.25" at the pivotsand the shock mounts are right at the XS11's, I believe the XS11 pivot ends/bearing could be grafted onto the KZ swingarm...There are about 10 of them on the bay right now at $20 each....JAT.....However,If your all about light-weight and performance, the ZRX11 swinger is SUPER-LIGHT aluminum alloy...Chop
    MDRNF
    79F.....Not Stock
    • scappod
      • Mar 2005
      • 233
      • Bremerton Washington
      #107
      ZRX Swingarm
      Hey Chop,
      Hey all,
      I'm back the swingarm is installed and looks good I will post some pics here probably today... as far as getting a zrx swingarm it is very hard to get now... How many people are interested in this mod now chop? Anyway P.M. me or something later
      Ego Sum Meus Frater Custodis...
      • scappod
        • Mar 2005
        • 233
        #108
        shock lengths
        I bought a new set of shocks on Bike Bandit that are 14 3/8 long and are a perfect match for the ride height of the zrx swingarm...
        I now need to lengthen my rear frame arms to support the fender and positioning of the new fender.
        • xschop
          • Feb 2006
          • 1794
          • oklahoma city
          #109
          Sweet
          Which fender are you going with again? I really like the Yamaha Road Warrior fender too. When you take pics of the set-up, let me know exactly the distance from the Center of the top shock mount hole to the frame mount bolt. All my calcs. have the custom bracket on the left out 34mm and the right 15mm.The swingarm cost seems to be the limiting factor here as I thought it would be. A few XS 750/850 guys are in for the swap as well. Mine has been a BLAST to ride. I am rebuilding an 80 head as we speak for some even more power....
          MDRNF
          79F.....Not Stock
          • xschop
            • Feb 2006
            • 1794
            • oklahoma city
            #110
            installation
            Disregaurding the pivot bolts, The first spacer on the left in this pic needs to be touching up against the XS11 frame when you install, then everything else tightens up...Also the thinner (11mm) thrust bearing goes left and the thicher (16mm) goes on the right. If not, nothing will line up. These spacers were calculated to bring the complete ZRX11 swingarm/wheel in exact centerline with the XS11.
            MDRNF
            79F.....Not Stock
            • scappod
              • Mar 2005
              • 233
              #111
              PITA Progress
              Okay Chop,
              Tell me what you think of these shots and if you have any imput please tell me
              • xschop
                • Feb 2006
                • 1794
                • oklahoma city
                #112
                Shock tops
                That looks right. I PM'd you about leveling the bike. If your concrete slab is level in the garage, you can put the bike on center stand. Those shocks are different dimensionally to the XS11's but NO PROBLEM. just make sure to level the frame ( I used a 24" carpenter level on the bare frame right above the shock mount bolts).Then use the level or a plumb-bob on the shock to set it vertical(bottom shock mount attached only at this point). Then use a caliper to measure the Frame Shock Face to inner shock face) this is the spacing you will need.
                MDRNF
                79F.....Not Stock
                • xschop
                  • Feb 2006
                  • 1794
                  • oklahoma city
                  #113
                  Ride heighth
                  I can't tell from the pics, But as you set on the bike, the swingarm should be parallel to the ground, maybe just with a negative degree or two past parallel....Man looking good....Chop
                  MDRNF
                  79F.....Not Stock
                  • xschop
                    • Feb 2006
                    • 1794
                    • oklahoma city
                    #114
                    many options
                    with 2 simple brackets (Left -Right) like these, the options are limitless on shock choice...the adapter shock bolt 14mm Diameter (10mm for an R1!) needs to be welded into the 1/2 thick adapter plate.
                    MDRNF
                    79F.....Not Stock
                    • snowdog51
                      • 348
                      • st. paul ,mn
                      #115
                      2nd that
                      i 2nd that my favorite color too
                      bill
                      bill hane
                      • xschop
                        • Feb 2006
                        • 1794
                        • oklahoma city
                        #116
                        tire size, Pic?
                        what size rear tire did you decide on? got a pic from the back?.....Also, did you get all the correct spacers for the rear axle/wheel. If need be I can mic this set and post dimensions to make sure you have the right sizes....Chop
                        MDRNF
                        79F.....Not Stock
                        • scappod
                          • Mar 2005
                          • 233
                          #117
                          spacer sizes
                          If you could mic yours that would be great I am unsure because I got mine a couple parts at a time... I am about 3 washer widths off and I delieve tthat the axel itself is too long, however I could be doing something wrong. I like the lolerances tight so maybe I am doing that wrong...
                          I measured everything again and come up with the same spacer sizes for the shocks. everything is level and all too!!!
                          • scappod
                            • Mar 2005
                            • 233
                            #118
                            more pita pics
                            Okay Chop here are some more shots
                            Here she is on the centre stand all relaxed
                            rear view on the centre stand
                            Left side
                            right side
                            and the shocks\
                            and that should cover that
                            • xschop
                              • Feb 2006
                              • 1794
                              • oklahoma city
                              #119
                              install is good
                              Looks like you got the swingarm on correct, the 3-piece thrust bearing on the left is 11mm wide and the right 16mm wide? Just making sure, it's hard to tell from the pics....Since the swingarm is installed correctly, shock mounts are next. So your measurements will be O.k. for the shock spacers. I do have one question for you because I am curious, is your frame a special or standard? and can you get a good measurement from left face to right face where the shocks mount to the frame? I have 10 1/16 using a large caliper....
                              MDRNF
                              79F.....Not Stock
                              • xschop
                                • Feb 2006
                                • 1794
                                • oklahoma city
                                #120
                                bracket
                                so basically make a bracket like the one above for the right side. and another one for the left with a longer shock bolt on the adapter and you're done....the adapter bolt will give you another 1/2 lift or so which it looks like you need....chop
                                MDRNF
                                79F.....Not Stock
