Who Wants A Bolt-on Chaindrive And Fat Tire?
  • xschop
    • Feb 2006
    • 1794
    • oklahoma city
    #151
    small
    skinny perhaps, but you are going to drop some major poundage off the setup...does your xs650 rim have a disk brake?
    MDRNF
    79F.....Not Stock
    • scappod
      • Mar 2005
      • 233
      • Bremerton Washington
      #152
      rear wheel
      If your gonna do it I would recommend going ahead and getting the zrx rear wheel too...
      You need to make sure that the rear axel is from the zrx1100 because if you mix parts you'll run into a bit of trouble...
      Ego Sum Meus Frater Custodis...
      • xschop
        • Feb 2006
        • 1794
        • oklahoma city
        #153
        3 spoke
        the 3 spoke wheel drops a couple more unsprung wt pounds, But since he's going for an original look, he could have the rim widened later on....
        MDRNF
        79F.....Not Stock
        • scappod
          • Mar 2005
          • 233
          #154
          wheel
          Could do,
          But isn't that a bit pricey?
          I have some standard forks commin from andreas so I will be able to finish the front. You are correct about the special forks bein a bear to adapt to the r-1 wheel
          • xschop
            • Feb 2006
            • 1794
            • oklahoma city
            #155
            Pricey
            could be @300 bones, but would be worth it in the cool factor. I have only seen 1 other widened XS rim over in Euro land......
            Oh yeah special forks......forgettabboutit.....It will be easier to adapt your R1 calipers to the standards
            MDRNF
            79F.....Not Stock
            • 79XS11F
              • 3563
              • Ottawa, Ont. Canada
              #156
              Re: small
              Yes the holes are there but not the disc as I wanted to save on shipping weight. My EBC pro-lite disc will be used on that wheel.
              Rob
              KEEP THE RUBBER SIDE DOWN
              1978 XS1100E Modified
              1978 XS500E
              1979 XS1100F Restored
              1981 Suzuki GS1100
              1983 Suzuki GS750S Katana
              1983 Honda CB900 Custom
              • xschop
                • Feb 2006
                • 1794
                • oklahoma city
                #157
                light rotor
                Hey Rob, what does that EBC weigh?
                MDRNF
                79F.....Not Stock
                • 79XS11F
                  • 3563
                  #158
                  Re: 3 spoke
                  That's correct... I do not want to venture too far from the stock look of the bike.
                  If I were to consider changing out the rear wheel I would have to do the front as well for continuity and the bike would start to stop looking like an "XS" series 1100.
                  Rob
                  1978 XS500E
                  1981 Suzuki GS1100
                  • 79XS11F
                    • 3563
                    #159
                    Re: light rotor
                    All three EBC disc's combined are just a little heaver then one stock disc :-) They are very lite!!!
                    Rob
                    1978 XS500E
                    1981 Suzuki GS1100
                    • scappod
                      • Mar 2005
                      • 233
                      #160
                      standard forks
                      Hey chop do you have any plans for the adaptation of the r-1 calipers to the standard fork????
                      • xschop
                        • Feb 2006
                        • 1794
                        • oklahoma city
                        #161
                        XS series
                        However you do it up, the bike will be original. I like going to bike night and parking next to the $30-40K Harley-in-a-box bikes, and everyone crowds around mine....Haters
                        MDRNF
                        79F.....Not Stock
                        • xschop
                          • Feb 2006
                          • 1794
                          • oklahoma city
                          #162
                          brackets
                          I only have the Hayabusa 6-pots programmed to the CNC, however ALANB and others from the U.K. site have them and have done a few swaps, same as the xs650 guys....
                          MDRNF
                          79F.....Not Stock
                          • xschop
                            • Feb 2006
                            • 1794
                            • oklahoma city
                            #163
                            don't forget
                            Hey Scap, just remember if you are using xs standard forks and the R1 wheel and rotors, the actual bracket design will be different from the bracket those guys made......
                            MDRNF
                            79F.....Not Stock
                            • scappod
                              • Mar 2005
                              • 233
                              #164
                              hayabusa calipers
                              So if I sent you a set of standard forks hayabusa calipers and my wheel you could rig it up for me???? Hope hope
                              • xschop
                                • Feb 2006
                                • 1794
                                • oklahoma city
                                #165
                                Does your wheel have the rotors and what year is the wheel and rotors...basically I need to know the rotor Diameter.....the busa calipers go on monster 320mm rotors....I believe the combo would work....with some work
                                MDRNF
                                79F.....Not Stock
