Who Wants A Bolt-on Chaindrive And Fat Tire?
  • xschop
    • Feb 2006
    • 1794
    • oklahoma city
    #121
    pic
    BTW can you get a good pic showing the rear master cylinder plunger rod clearance? Another reason why this swingarm is a good choice.....OH Yeah, that rear tire and fender looks like it belongs there, cool tail light too Scap.
    MDRNF
    79F.....Not Stock
    • xschop
      • Feb 2006
      • 1794
      • oklahoma city
      #122
      new shock location
      The new shock adapter bolt location (In Blue) should be about 1.25 to 1.5" away from the frame shock bolt (this would give the XS11 stock ride heighth. If you want the tail raised, then the "BLUE" position should be further back
      MDRNF
      79F.....Not Stock
      • scappod
        • Mar 2005
        • 233
        • Bremerton Washington
        #123
        I can post one when I get home tonight
        Ego Sum Meus Frater Custodis...
        • xschop
          • Feb 2006
          • 1794
          • oklahoma city
          #124
          stock zrx axle spacers
          I will mic the axle spacers tonight and post pics how they install left to right as well....
          MDRNF
          79F.....Not Stock
          • scappod
            • Mar 2005
            • 233
            #125
            spacers
            Thanks chop,
            I will post pics of the mastercylinder tonite
            • xschop
              • Feb 2006
              • 1794
              • oklahoma city
              #126
              left to right
              Complete factory zrx11 rear axle/wheel spacers....
              MDRNF
              79F.....Not Stock
              • xschop
                • Feb 2006
                • 1794
                • oklahoma city
                #127
                They're all here
                Hey Scap, let me know what you don't have and I will Mic it.....
                MDRNF
                79F.....Not Stock
                • xschop
                  • Feb 2006
                  • 1794
                  • oklahoma city
                  #128
                  photoshop is jacked up
                  Caliper bracket between #4 and #5 from the right....Wheel between #5 and #6 from the right
                  MDRNF
                  79F.....Not Stock
                  • scappod
                    • Mar 2005
                    • 233
                    #129
                    wheel width
                    On your rear wheel how wide is the hub and is there a difference between the width of the zrx11 and zrx12 rear hub?
                    • xschop
                      • Feb 2006
                      • 1794
                      • oklahoma city
                      #130
                      HUb?
                      you mean the one in the pic with the sprocket attached? Or the part of the wheel where the rear axle goes thru? Unless I had a complete zrx12 rear I wouldn't know about spacer differences....chop
                      MDRNF
                      79F.....Not Stock
                      • JustJeff
                        • 61
                        • Golden Colorado
                        #131
                        I am interested. Do you have eng. specs/ drawings?
                        Obsessed Motorcycle Mechanic / 29 year Owner of a 78 “E” model
                        Restored 1196cc Turbocharged 211 BHP @ RWL
                        “Honk if you have never seen a gun fired from a motorcycle”
                        • xschop
                          • Feb 2006
                          • 1794
                          • oklahoma city
                          #132
                          for jeff
                          Took me a good few month's weekends to tear up and R&D a few middle drives to get the end result. All "engineering specs" are programmed into a Hurco CNC machine with tolerances .0001...you can read about it here...
                          MDRNF
                          79F.....Not Stock
                          • xschop
                            • Feb 2006
                            • 1794
                            • oklahoma city
                            #133
                            from scappod
                            This is the real benefit to this swingarm, No reworking of your stock rear master cylinder.Looks like the right front brake line from a 99-07 hayabusa (27" I2I and inexpensive) will work for the extended ZRX11 swingarm on the XS11.
                            MDRNF
                            79F.....Not Stock
                            • xschop
                              • Feb 2006
                              • 1794
                              • oklahoma city
                              #134
                              REAR MC pic
                              MDRNF
                              79F.....Not Stock
                              • scappod
                                • Mar 2005
                                • 233
                                #135
                                wheel
                                The Part of the wheel where the axle goes through would be good
                                thanks
