I am also VERY interested in this setup. I am looking at purchasing a cheap XS11 to do the same SSSA style setup on, but won't buy it if the conversion is no longer available. Are they still available?
Who Wants A Bolt-on Chaindrive And Fat Tire?
Ducati it is
. Im pikcing up my 75% complete parts bike nxt week, and I have a titled frame coming in as well. So I have a spare frame to test fit for any fabrication. Should come in handy. Got a quick question for you though. I have seen a few chain failures in the past, luckily never on my bike, and all on sportbikes. in most cases, the chain pretty much destroyed the sprocket cover, and even then, in a few instances there was still injury to the riders leg. Do you have any ideas for some sort of sprocket cover or a crossguard of some sort. Having a bare sprocket that close to the leg seems like it could do some serious damage if the chain were to fail.
1981 XS11SH Custom Project - Juggernaut
1990 FZR600 Hybrid Streetfighter - Lilith
1996 FZR600 Custom Project
1994 FZR600Comment
run-up
Its that time again. If you have contacted me in the last few months and want a completely assembled chaindrive housing, PM me so I can get a heads-up on the Billet that I need to order. As Always, I need a complete middle drive from you....Chop
Completely assembled unit with all installation hardware ....
$600 U.S
$625 Canada
$660 OverseasMDRNF
79F.....Not Stock
80G......Not Stock Either....In the worksComment
Chain to shaft?
Hey, can someone help me out with XS/XJ Shafty parts to convert my GS to Yami Shafty? First some ratios?
Thanks
gmansyz@earthlink.netComment
xs11 middle drive ratio is almost 1:1
XS11 FD is 3.3:1
You can stick on a 2.9:1 ratio from an XS750/850
This is last call for this year on the chaindrives.. I will need a good middle drive from you, just PM me, Chop.MDRNF
79F.....Not Stock
Hey, I need about 50 of them... Can you get that done by next week?
Let's see.. @ 8 hours+ per piece X Fitty = Foe hunnet hours.
One hunnet sixty eight hours in a week.
Betta get yo azz busy Cuz!
Hi xschop! I just found a new cushdrive with a brandnew aluminum 520 rear sprocket, so i now want to run a 520 chain on the chain setup but I have no clue where i can find a suitable front sprocket, do you have any idea? What spline do I have to look for?
kr, mathXS1100 3X0 '82 restomod, 2H9 '78 chain drive racer, 3H3 '79 customized.
MV Agusta Brutale 910R '06.
Yamaha MT-09 Tracer '15 grey.
Kawasaki Z1300 DFI '84 modified, red.Comment
520 sprockets
The XS-650 sprockets match the XS1100 middle shaft splines.They are what to look for. They come in 530 and 520 sizes and are relatively inexpensive. There is also an older Honda with these same spline patterns that Sprocket Specialists carry.MDRNF
79F.....Not Stock
Thanks! Just what I needed. I found the Honda one but that was only in 530.XS1100 3X0 '82 restomod, 2H9 '78 chain drive racer, 3H3 '79 customized.
like those eccentric chain adjuster in kawasaki swingarm....makes life easier, chain adjustment wise.
Paul B. Bautista
Manila, Philippines
XS1100 Midnight Special Cafe Racer
TZR250 Street Tracker
1986 Honda GB400 TTComment
Just send me a good middle drive or the shaft, inner circlip and outter locknut.I'm making a few spare housings with these few that I am doing now......Hows that XS-Vegas coming along?
""""""like those eccentric chain adjuster in kawasaki swingarm....makes life easier, chain adjustment wise.""""""
That's another reason why I chose that arm to mod up, that and it is all alloy with underbracing fron the factory....MDRNF
79F.....Not Stock
