What would you buy???
  • tomcos67
    • Apr 2015
    • 311
    • Amsterdam, N.Y.
    #91
    Sweet !!!!! Looks great.!!!! Great Job Marty.How big cc.weight?top speed.R they smooth riders????
    1980xs1100.sg Pacifica Fairing ..stock.
    2006 Honda Shadow Spirit 1100.! โ›บ
      • 7778
      yours looks almost brand spankin' new...
      Not if you're up close and personal.
        • 7778
        Engine: 90 degree V-twin, 4-stroke, Otto Cycle KD-Type, Air Cooled
        Displacement: 1064 cc, light-alloy surface hardened cylinders
        Bore and Stroke: 92x80 mm
        Max Output:54kW [73.5 HP] at 6400 rpm (CE standards)
        Max. Torque: 94Nm [9.6kgm] at 5000 rpm (CE Standards)
        Fuel System: Magneti Marelli IAW Multipoint electronic phased sequential fuel injection; alpha-n type; two 40mm diameter throttle bodies with Weber IW 031 injectors
        Ignition: Magneti Marelli IAW electronic digital ignition with inductive spark
        Clutch: Double disk, dry, mechanically operated
        Compression Ratio: 9.5:1
        Valves and Operation: Light-alloy pushrod and rocker arm with two valves per cylinder.
        Starting System: Electric with starter motor
        Lubrication: High volume geared pressure pump, pressure regulator.
        Transmission: Primary by helical gears, secondary by cardan shaft with double universal joint.
        Gearbox: 5 speed, constant mesh gears with built in cush drive
        Frame: Detachable tubular duplex cradle in special high strength steel.
        Suspension: Front - Marzocchi 45mm diameter hydraulic telescopic fork, seperately adjustable. Rear - swingingfork with two WP adjustable hydraulic shock absorbers.
        Electrical System: 12V; 14V 25A alternator; 30Ah battery.
        Braking System: integral braking system with proportioning and delay valve consisting of: two front floating stainless steel discs Brembo ORO series, diameter 320mm; one rear fixed stainless steel disc diameter 282mm; Brembo ORO series 4-piston front calipers; parallel 2-piston rear calipers.
        Wheels: radial with patented BBS tubeless rims; front 2.50x18"; rear 3.50x17".
        Tires: front 110/90 VB 18; rear 140/80 VB17
        Instruments: Speedometer with odometer and trip meter (total and partial); electronic rev counter and warning lights.
        Fuel tank Capacity: 19 liters
        Fuel consumption: 5.0l/100km (CUNA standard)
        Dry Weight: 251 kg
        Max Speed: 200 km/h [122 mph] (CE standard) without accessories
        MSRP: $11,770.00
        1998 California E.V.
          It has moved in with the Yamaha herd. Are you coming through again after the equinox?
          Hi Marty,
          Yes I certainly hope to be able to pass through in March.
          • Mathh
            • Nov 2006
            • 665
            • Beek, Netherlands
            #95
            after going baack viewing more vids,the nuda is a husquvarna,spelling?900.what a fraking bike it is....
            Yep, you're right !
            MV Agusta Brutale 910R '06.
            Yamaha MT-09 Tracer '15 grey.
            • tomcos67
              • Apr 2015
              • 311
              • Amsterdam, N.Y.
              #96
              Originally posted by Mathh
              Yep, you're right !
              Do you have pics of your Agusta?????
                A decent looking and interesting bike there Marty. For me, the Yammy shaft driven Super Tenere dual sport would be my next ride..........we'll see how I do on two wheels(the Venturer) this spring after the herendous crash I had back in June on the Honda ST. It was totalled. Best part, is at least I'm back upright and walking!
                • tomcos67
                  • Apr 2015
                  • 311
                  • Amsterdam, N.Y.
                  #98
                  I like her Marty....
                  • Bergman16
                    • Jun 2014
                    • 286
                    • New York, N.Y.
                    #99
                    Marty that is an awesome machine. After I start my new job I will look for an 01 Special Sport. I love the EV, just really love the SS with Black/red tank.
                    Steve R
                    '80 SG
                    "Fred" -- TC fuse box, stock airbox/exhaust/jets, SS brake lines, Windjammer V fairing, Cibie headlight lens, TKAT fork brace, Showa rear shocks, MikesXS emulators
                    Former bikes:
                    1973 Yamaha 125 Enduro (brother's but I 'borrowed' it a lot, usually after midnight)
                    1978 XS400E Red
                    1981 XS850 Special (Stingo)
                      • 7778
                      I can dig it! Fun machine for sure.
                        • 7778
                        Mine, now.
                        • Bergman16
                          • Jun 2014
                          • 286
                          • New York, N.Y.
                          #102
                          The Italians know how to make machines look good! There's a new El Dorado I'm told. The only Guzzi I've ever ridden was an old CA police model, and that was just around the block when I was in college in IA.
                          Steve R
                          '80 SG
                          Former bikes:
                          1978 XS400E Red
                          • Prisoner6
                            • Aug 2013
                            • 1184
                            • Phoenix, AZ
                            #103
                            New Eldorado
                            The Italians know how to make machines look good! There's a new El Dorado I'm told ...
                            There most certainly is ... and it's gorgeous!
                            2016 Moto Guzzi Eldorado
                            Marco
                            1979 Honda CBX
                            2002 Kawasaki ZRX1200R
                            WE MISS YOU, DON
                              • 1942
                              Yeah!
                              Marty- we know you have been dreaming about that bike for quite awhile. It must be a memorable day for you! Congratulations!
                              I'm sure we'll hear and see more about her. We'll look forward to it.
                              Came with a gas can like mine, didn't it? I got the idea from you to begin with.
                              • 2manybikes
                                • 194
                                • Meadows of Dan Va.
                                #105
                                XJR 1300 pic
                                madmax-im,
                                What year and model is the bike in the pic you posted?
