Tach needle jumping around...
    • 2006
    The only time I ever saw mine go up to 15 plus is when my voltage regulator was bad. I honestly can't remember what my tach was doing though. I replaced the voltage regulator and everything went back to normal.
      • 8929
      Well Jonny, it looks like either obtain another tach and try it, or continue going through the wiring, cleaning all related connectors. At this point it could be either or maybe even something else. Operating on a tamper proof tach might not be for you. It's an extremely finicky task.
        Originally posted by LAB3
        15 sounds a bit too high, are you running a lithium battery? I'd be leery of anything higher than about 14.4 with a lead-acid battery.
        The tach itself is reading off one of the stator windings which would be an AC voltage somewhere in the 50v+ range.
        Actually LAB3, A lead acid wet cell battery on a 12V system, the regulated voltage with system running and working correctly, regulated voltage correctly should show to be 13.8-14.2volts. That comes from having 50+yrs. experience diagnosing 12v d.c. elecrical systems in the automotive world. That may also be of help to many others here.
          LAB3, no offense intended by my previous post, just factual knowledge.
            • 833
            None taken. After living over 20 years with an off grid power system running 12v lead acid batteries I have a good bit of charging system experience myself. Anything over 14.2 would be suspect in that scenario although I've seen people bump that set point up a bit to 14.4 with AGM.
            • JonnyO
              • Oct 2020
              • 229
              • Sun City West, AZ
              I don't believe so. Just an Interstate. I don't think they list a lithium for an XS. I've had it for a couple of years.
              • JonnyO
                • Oct 2020
                • 229
                • Sun City West, AZ
                Maybe the trickle charger has eventually done something not good? Battery shows 13.18 after unplugging charger and revs up to 14.81 on choke.
                  • 2006
                  That sounds normal. There are six cells in a battery. Each cell carries about 2.2 volts. Doing the math that comes to 13.2 volts. That is approximately what you will have on a fully charged battery. It only drops after trying to crank the motor. 14.81 is also good which shows that the alternator and the voltage regulator/rectifier are doing there job. When you stated 15ish that indicated exceeding 14ish which is not good. Back to checking your settings on what Phil said to check on your tachometer problems.
                  • JonnyO
                    • Oct 2020
                    • 229
                    • Sun City West, AZ
                    Aye aye. At this point I'm leaning towards buying a good tach from a member-just to rule it out.
                      • 2057
                      • JonnyO
                        • Oct 2020
                        • 229
                        • Sun City West, AZ
                        Hmm? I see a hieroglyphic drawing. From inside the tomb of Keops?
                        But seriously I've no practical knowledge of this " stuff ". I'm supposing that the W, B, BR are representative of White Black and Brown wires. 3 Ws. Does that represent the plug under the fuse box? I'm going to Lowes to get some circuit cleaner to try and clean out as the one post said cleaning the two plugs with those W and Br and G color wires under the fuse box solved his tach issue.
                        Just a shot in the dark.
                          • 2006
                          Here is a wiring diagram for your bike in color. 80sg_81sh_wire.pdf
                          • JonnyO
                            • Oct 2020
                            • 229
                            • Sun City West, AZ
                            Great. Colored hieroglyphics. JK
                            ANYWAY I used the contact cleaner on the two connections suggested in the maintenance post by XS11 from 2002. Nope. Didn't work. I suppose I'll now have to try to figure out how to follow his instructions on what voltage should be
                            on each wire. Rats.
                            I did check the battery off the trickle charger last night- 12.89 now so I guess the battery is still good.
                              • 2057
                              Here is a better explanation of the diagram.
                                • 2057
