Tach needle jumping around...
  • JonnyO
    • Oct 2020
    • 229
    • Sun City West, AZ
    #46
    Ok. I give up.
    Thanks for all the suggestions, nonetheless.
      • 2007
      Why are you giving up? You are making steady progress. Probably doesn't seem that way but you are. I was going to suggest the impact wrench too; it's just a bit bigger then those Deebs suggested and the bits that acoompany it are still American standard. If it did the job though great. I acutally own one. It is just a bit bigger then the JIS ones and sometimes it's bulk can hamper things. Evapo rust works slow but sure. I would just leave it in there for a day. Don't forget to check the welds. The left control is the one that has more welds in it that need to be checked/verified and resoldered if necessary. Don't give up. Spend the time going through all the electrical connections and grounds on the entire bike. I mean all of them. One product that I have always liked to use to spritz all my connections is CAIG Deoxit D5 (I know I keep telling you to buy something) but this stuff is really good at cleaning the oxidation you can't see off of contacts. It also maintains them for longer then the contact cleaner you can pick up at Walmart etc...
      I can't really see the screws condition from you pictures but if they are not stripped reuse them. I have never put any Loctite on mine. They shouldn't come loose by just torquing them. The reason they are so hard to remove to begin with is because they are mounted in aluminum. Dissimilar metals will seize over time with the oxidation that builds up on them. I actually use anti seize on some things like the middle and final drive drain and fill bolts. I don't on the control screws and cover screws.
        JonnyO, however long submersed will not damage any part, so no worries.
          • 834
          #49
          Every time I take on a new task and am forced to challenge myself by entering the "unknown" and keep plugging away until I succeed I'm upping my game. Things get frustrating without a doubt but now I have the confidence to go anywhere I want in the country on a 45 year old motorcycle with nothing more than my wits and a minimal amount of tools to get things done with.
          NOTHING will give you more confidence in life than overcoming self doubt, keep at it and you WILL succeed as long as you keep asking questions and stay away from making self deprecating statements.
          • JonnyO
            • Oct 2020
            • 229
            • Sun City West, AZ
            #50
            Appreciate the positivity from you guys but I've done everything suggested. ( I think ) I'll just have to say "I've shelved it for now" then. Frustrating to an old buzzard, it is. It will continue to bug me, no doubt, as it bounced around on my trip to get Pig Spit.
            ANYWAY, Happy New Year! to you all and I'm forever grateful for your invaluable gifts of shared wisdom and advice!
            -Jonny in SCW
            • JonnyO
              • Oct 2020
              • 229
              • Sun City West, AZ
              #51
              So a new problem has reared its ugly head and it makes me wonder if it could be related to the tach malfunction.
              I went early morning Monday to pick up my Uncle's mini-van to get them at the airport in the afternoon. I fired the bike up, pulled out the choke lever and drove off...only it kind of sputtered like it was cold but when I gave it throttle it really bogged down, like it was going to die. Felt like it was only running on two cylinders or running out of gas. I flipped the petcocks to no avail and the only thing that really kept it running was keep the choke out. Managed to make it the two miles and parked it. Picked it up at 4 after I dropped them back home and I expected to have to deal with the problem-nope-ran GOOD. I parked it in the garage and went to drive it today and only got about a half a mile before it started to bog down again and I drove it back and put it in the garage. I'm thinking A COIL PACK as it seemed to be missing badly.
              As most of you seemed to think my tach problem ( needle jumping around or not functioning at all ) was/is electrical related any thoughts that this might explain the tach problem? That is, if it is a coil pack wouldn't a weak coil make sense?
              Also, the tach hadn't moved at all the last few rides I went on over the last couple of weeks-until the ride back after the Airport pick up.
              Anyway, thanks for your help.
              -Jonny
                • 2007
                You might want to read through this thread and check your bike. Pick-up Coil Wire Repair - XS11.club Forums
                One other thought .... What happens when a regulator rectifier goes bad?
                A failing regulator-rectifier leads to poor battery charging, dim or flickering lights, and malfunctioning electronics.
