XS1100 Standard for $1.00
    #61
    What color did you use on your exhaust? I am hoping for a glossy black ,or a chromish black look.
    What temp does it require to apply it? Above 60 deg F like most paints? Is it high in VOCs like some paints? I have a basement workshop I can paint in this time of year, but the smell goes everywhere in the house, so I try not to use the strong stuff down there.
      #62
      Lookin' good...
      I'm surprised you used the 'red' Dyna coils rather than the green ones. Both will work, but the green ones let you eliminate the ballast resistor and will give you a bit hotter spark when running because they're getting full voltage.
      • TheRev
        • Jun 2012
        • 235
        • Madison, Wi.
        #63
        I used the Black Velvet color. They have a bunch you can choose from. Make sure you look at the High Temp Coatings rather than the Gun Coatings, which cure in an oven like powdercoat. I didn't notice a huge smell with the coating. It has some great instructions on the website.
        1979 xs1100f
        New Fuse Box
        Progressive Shocks
        Gold Valve Emulator
        Dyna Coils
        Electronic Flasher
        Led Headlight
        Led Turn Signals
        4 Led Driving Lights
        2nd Gear Fix
        Auto Cam Tensioner
        Digital Dash
        Stainless Braided Lines
        R6 4 Piston Calipers
        Stainless Bolt Kit
        Maier Fairing
        Dyna Balancing Beads
        Spin On Oil Filter
        Stebel Nautilus Horn
        Plasti Dip Rims
        ISO Grips
        • TheRev
          • Jun 2012
          • 235
          • Madison, Wi.
          #64
          Lookin' good...
          I thought about that but I got some mixed reviews when I did the research. I haven't started her up yet so I hope they work well.
          1979 xs1100f
          New Fuse Box
          Progressive Shocks
          Gold Valve Emulator
          Dyna Coils
          Electronic Flasher
          Led Headlight
          Led Turn Signals
          2nd Gear Fix
          Auto Cam Tensioner
          Digital Dash
          Stainless Bolt Kit
          Maier Fairing
          Spin On Oil Filter
          Plasti Dip Rims
          ISO Grips
            • 2095
            Originally posted by TheRev
            This mod was the most difficult so far. I wanted to upgrade my brakes so I picked up some R6 calipers, build an adaptor, machined some hub spacers, installed some 320mm rotors and installed some stainless lines. I am very happy with the way everything turned out. I also installed Gold Valve Emulator in the forks and added a Tkat fork brace so the frond end should be solid.
            Nice job on your bike so far.
            What disc rotors are those, R6's, and what year ?
              #66
              The Dyna 3 ohm coils are green too; yeah, the Mikes green coils are crap, but I haven't heard of any issues with the Dynas....
              • TheRev
                • Jun 2012
                • 235
                • Madison, Wi.
                #67
                Ok, so I don't really like the xs1100's badges so I took them off. I then proceeded to cut off the tabs that hold the badges. This proved to be a bad idea because I punctured a large hole in the tank. I tried to MIG weld the hole and actually made it worse. So I took the tank to a professional and had it TIG welded. They did a great job. Then I took JB Weld and filled in the large indentation.
                I then used Rage body filler and filled in the rest of the indentation. Tomorrow I will sand the filler so everything looks flush.
                I also filled in the badge holes on the side covers and the rear cowl.
                1979 xs1100f
                New Fuse Box
                Progressive Shocks
                Gold Valve Emulator
                Dyna Coils
                Electronic Flasher
                Led Headlight
                Led Turn Signals
                2nd Gear Fix
                Auto Cam Tensioner
                Digital Dash
                Stainless Bolt Kit
                Maier Fairing
                Spin On Oil Filter
                Plasti Dip Rims
                ISO Grips
                • Eveready1100
                  • 539
                  #68
                  Um, Rev. You didn't happen to accidently click on the "oganise photos" button on photobucket cos every one up till todays has disappeared?
                  • TheRev
                    • Jun 2012
                    • 235
                    • Madison, Wi.
                    #69
                    Crap! Now what do I do?
                    1979 xs1100f
                    New Fuse Box
                    Progressive Shocks
                    Gold Valve Emulator
                    Dyna Coils
                    Electronic Flasher
                    Led Headlight
                    Led Turn Signals
                    2nd Gear Fix
                    Auto Cam Tensioner
                    Digital Dash
                    Stainless Bolt Kit
                    Maier Fairing
                    Spin On Oil Filter
                    Plasti Dip Rims
                    ISO Grips
                    • TheRev
                      • Jun 2012
                      • 235
                      • Madison, Wi.
                      #70
                      I did not click the organize button but i have been on photo bucket all day adding pics. Is there any way to go back and edit my posts?
                      1979 xs1100f
                      New Fuse Box
                      Progressive Shocks
                      Gold Valve Emulator
                      Dyna Coils
                      Electronic Flasher
                      Led Headlight
                      Led Turn Signals
                      2nd Gear Fix
                      Auto Cam Tensioner
                      Digital Dash
                      Stainless Bolt Kit
                      Maier Fairing
                      Spin On Oil Filter
                      Plasti Dip Rims
                      ISO Grips
                        • 8879
                        Might as well just start a new thread.
                        • mikubuilder
                          • Jul 2011
                          • 548
                          • Westland, Mich.
                          #72
                          Hey Rev, if you don't like your badges, send them my way, I will cover shipping
                          Nick
                          1982 Virago 750 (it's alive!)
                          • TheRev
                            • Jun 2012
                            • 235
                            • Madison, Wi.
                            #73
                            Let me check to see if they are in good shape.
                            1979 xs1100f
                            New Fuse Box
                            Progressive Shocks
                            Gold Valve Emulator
                            Dyna Coils
                            Electronic Flasher
                            Led Headlight
                            Led Turn Signals
                            2nd Gear Fix
                            Auto Cam Tensioner
                            Digital Dash
                            Stainless Bolt Kit
                            Maier Fairing
                            Spin On Oil Filter
                            Plasti Dip Rims
                            ISO Grips
                            • TheRev
                              • Jun 2012
                              • 235
                              • Madison, Wi.
                              #74
                              I finished sanding the tank, side covers and rear cowl. attached the cowl on the seat and set the tank on the frame just to get a idea of it's future stance. I like the fact that I cut down the rear fender. I didn't have the seat and the cowl at the time so I just eyballed it. I actually would have chopped it some more but I think it looks fine. I also installed the front fender and added a cable holder to the right side to hold the stainless brake line.
                              1979 xs1100f
                              New Fuse Box
                              Progressive Shocks
                              Gold Valve Emulator
                              Dyna Coils
                              Electronic Flasher
                              Led Headlight
                              Led Turn Signals
                              2nd Gear Fix
                              Auto Cam Tensioner
                              Digital Dash
                              Stainless Bolt Kit
                              Maier Fairing
                              Spin On Oil Filter
                              Plasti Dip Rims
                              ISO Grips
                                #75
                                Hey Jared,
                                Your photo links are all fixed, so I deleted your post with the big list of links in it.
                                While fixing them, I noticed this one in post #53, and I think you left off a LARGE WASHER that should be underneath the castle nut on the rear axle, not to mention the cotter pin! Unless you are leaving like this for temporary assembly, and were going to tear it down again for some reason....but still you need those parts.
