XS1100 Standard for $1.00
  • TheRev
    • Jun 2012
    • 235
    • Madison, Wi.
    #76
    Wow! TC you are awesome! Thank you so much for fixing my pics in this thread. I was worried I would have to start all over. You are the best. I appreciate the work. And, thank you for noticing the missing washer. I did forget it. I'm sure glad you spotted that.
    1979 xs1100f
    New Fuse Box
    Progressive Shocks
    Gold Valve Emulator
    Dyna Coils
    Electronic Flasher
    Led Headlight
    Led Turn Signals
    4 Led Driving Lights
    2nd Gear Fix
    Auto Cam Tensioner
    Digital Dash
    Stainless Braided Lines
    R6 4 Piston Calipers
    Stainless Bolt Kit
    Maier Fairing
    Dyna Balancing Beads
    Spin On Oil Filter
    Stebel Nautilus Horn
    Plasti Dip Rims
    ISO Grips
    • TheRev
      • Jun 2012
      • 235
      • Madison, Wi.
      #77
      I have a friend that owns an auto body shop so I went down to his place this weekend and worked on preparing my parts for paint. I spent a lot of time sanding. Here are some pics
      Block sanding is a pain in the rear. I thought I would get to paint this weekend but I ran out of time.
      I originally filled the badge holes with body filler but my buddy said he had a better product, so i drilled out the holes and used this stuff
      I guess it's super expensive but it works awesome. It bonds all plastic like nothing you believe. He says he uses it to mend plastic bumpers all the time. Any how you apply it just like body filler and wait 30 minutes for it to harden. Then you sand it down like filler. However, it's much much harder to sand. I worked my tail off to get this stuff flat.. But when done you can't tell there was any work done. It's truly that amazing. Here are some more pics of the work I did this week.
      I found a huge patch that the PO tried to fix on the rear cowl. What ever the PO used it looked like crap. I decided to fix the problem the correct way, so I ground down whatever crap the PO used and added some more of the 3M material. I then began the process of sanding, priming, sanding and priming until it was perfect.
      Next week I hope to put down the color, stripes, and clear. I am looking forward to seeing how it turns out.
      1979 xs1100f
      New Fuse Box
      Progressive Shocks
      Gold Valve Emulator
      Dyna Coils
      Electronic Flasher
      Led Headlight
      Led Turn Signals
      2nd Gear Fix
      Auto Cam Tensioner
      Digital Dash
      Stainless Bolt Kit
      Maier Fairing
      Spin On Oil Filter
      Plasti Dip Rims
      ISO Grips
        #78
        Nice work. Yes, wit paint it seems the prep work is the real work. By the time your ready to shoot paint, your sick of looking at the thing. But then the paint work goes pretty quick, and will show the detail you put in the prep.
        • TheRev
          • Jun 2012
          • 235
          • Madison, Wi.
          #79
          So today I went back to the paint booth to paint the tank, side covers, cowl and fairing. I was so excited to see the color. It turned out awesome! Here are the pics after the base color and 1st clear coat. This picture isn't very good. For some reason it looks all washed out.
          Here is a better pic.
          The color is a deep dark blue that looks almost black until the light shines on it. Then the pearl color comes out. It's originally a Porsche color that I have always loved. Here are some more pics.
          1979 xs1100f
          New Fuse Box
          Progressive Shocks
          Gold Valve Emulator
          Dyna Coils
          Electronic Flasher
          Led Headlight
          Led Turn Signals
          2nd Gear Fix
          Auto Cam Tensioner
          Digital Dash
          Stainless Bolt Kit
          Maier Fairing
          Spin On Oil Filter
          Plasti Dip Rims
          ISO Grips
          • TheRev
            • Jun 2012
            • 235
            • Madison, Wi.
            #80
            The next step was to wet sand at 800 grit all the pieces to even out the clear coat. I had to be very careful not to sand too deep and sand off the clear. Everyone has their own way of painting, this is the way I was taught.
            This whole process took about an hour.
            1979 xs1100f
            New Fuse Box
            Progressive Shocks
            Gold Valve Emulator
            Dyna Coils
            Electronic Flasher
            Led Headlight
            Led Turn Signals
            2nd Gear Fix
            Auto Cam Tensioner
            Digital Dash
            Stainless Bolt Kit
            Maier Fairing
            Spin On Oil Filter
            Plasti Dip Rims
            ISO Grips
              • 4012
              THAT is an AMAZING color! I bet it would look even better with the Yamaha decals.
              • TheRev
                • Jun 2012
                • 235
                • Madison, Wi.
                #82
                Then the fun began. I started to lay out the stripes. I wanted racing stripes but I wanted them to be done in paint and not a decal. I am sure glad my friend helped me line these up. He was a great help. I began with the tank. First I placed 1/4 inch tape in the center of the tank.
                Then using the center line as a guide I placed the next two lines using 1.25 inch tape. Then another 1/4 inch, then 1/2 inch and finally another 3/4 inch. I then carefully removed the 1.25 and the 1/2 inch tape leaving a gap or (stripe) between the 1/4 inch pieces. Sorry if that didn't make any sense. Here is a pic to help.
                Here is what it looked like on the actual parts.
                I then placed paper over the rest of the pieces to prepare for painting the stripe.
                1979 xs1100f
                New Fuse Box
                Progressive Shocks
                Gold Valve Emulator
                Dyna Coils
                Electronic Flasher
                Led Headlight
                Led Turn Signals
                2nd Gear Fix
                Auto Cam Tensioner
                Digital Dash
                Stainless Bolt Kit
                Maier Fairing
                Spin On Oil Filter
                Plasti Dip Rims
                ISO Grips
                • TheRev
                  • Jun 2012
                  • 235
                  • Madison, Wi.
                  #83
                  Then I placed the decals. This was a very tough job to make them perfect. The measuring was difficult as well as making everything line up. It would have been much easier if the parts were flat, however life is not that symmetrical and neither is the xs1100. The tank is roundish and the side covers are, let's just say not symmetrical.
                  1979 xs1100f
                  New Fuse Box
                  Progressive Shocks
                  Gold Valve Emulator
                  Dyna Coils
                  Electronic Flasher
                  Led Headlight
                  Led Turn Signals
                  2nd Gear Fix
                  Auto Cam Tensioner
                  Digital Dash
                  Stainless Bolt Kit
                  Maier Fairing
                  Spin On Oil Filter
                  Plasti Dip Rims
                  ISO Grips
                    • 4012
                    More pics please!!!
                    • TheRev
                      • Jun 2012
                      • 235
                      • Madison, Wi.
                      #85
                      So here are more pics of the process.
                      1979 xs1100f
                      New Fuse Box
                      Progressive Shocks
                      Gold Valve Emulator
                      Dyna Coils
                      Electronic Flasher
                      Led Headlight
                      Led Turn Signals
                      2nd Gear Fix
                      Auto Cam Tensioner
                      Digital Dash
                      Stainless Bolt Kit
                      Maier Fairing
                      Spin On Oil Filter
                      Plasti Dip Rims
                      ISO Grips
                        • 4012
                        Rev- Is that a Meier fairing? If so, where did you find it?
                        • TheRev
                          • Jun 2012
                          • 235
                          • Madison, Wi.
                          #87
                          I then sprayed the fairing, tank and cowl with three coats of silver.
                          Next I baked the parts for 30 minutes. Then I gently pulled the tape and paper off the parts and presto perfect racing stripes that are paint not decals.
                          I then put one layer of clear coat on and left for the day. I live about 1.5 hours from the shop and I only have one day off a week. So next Monday I am going to wet sand the parts again, clear, wet sand, clear and then polish. By the end of this project the tank, fairing, cowl and side covers are going to shine. Stay tuned.
                          1979 xs1100f
                          New Fuse Box
                          Progressive Shocks
                          Gold Valve Emulator
                          Dyna Coils
                          Electronic Flasher
                          Led Headlight
                          Led Turn Signals
                          2nd Gear Fix
                          Auto Cam Tensioner
                          Digital Dash
                          Stainless Bolt Kit
                          Maier Fairing
                          Spin On Oil Filter
                          Plasti Dip Rims
                          ISO Grips
                          • TheRev
                            • Jun 2012
                            • 235
                            • Madison, Wi.
                            #88
                            I plan on using an LED Headlight from TruckLite. Here it is.
                            This light uses very little power and is very bright. It will match the color (white) light of the running lights I installed, which are also LED. I am using Crazy Steve's Mod "Install an off the shelf headlight in a standard" to mount it. It is going to be awesome!
                            1979 xs1100f
                            New Fuse Box
                            Progressive Shocks
                            Gold Valve Emulator
                            Dyna Coils
                            Electronic Flasher
                            Led Headlight
                            Led Turn Signals
                            2nd Gear Fix
                            Auto Cam Tensioner
                            Digital Dash
                            Stainless Bolt Kit
                            Maier Fairing
                            Spin On Oil Filter
                            Plasti Dip Rims
                            ISO Grips
                              Hi Rev,
                              Thanks for sharing your painting project with us.
                              • TheRev
                                • Jun 2012
                                • 235
                                • Madison, Wi.
                                #90
                                Hi Ian
                                Yes it is a Meier fairing. I just did a web search and priced it out. I think at the time it was a seller on Amazon. It should look good with the windscreen, although after seeing the paint with clear coat it looks like the paint will out shine the windscreen.
                                1979 xs1100f
                                New Fuse Box
                                Progressive Shocks
                                Gold Valve Emulator
                                Dyna Coils
                                Electronic Flasher
                                Led Headlight
                                Led Turn Signals
                                2nd Gear Fix
                                Auto Cam Tensioner
                                Digital Dash
                                Stainless Bolt Kit
                                Maier Fairing
                                Spin On Oil Filter
                                Plasti Dip Rims
                                ISO Grips
