XS1100 Standard for $1.00
  • Courtney
    • 542
    • Nanaimo BC Canada
    #46
    1: I removed the timing cover
    2: I turned the engine clockwise with a 6 mm hex key until the "C" lined up with the pointer.
    3: I removed the two 5mm hex bolts from the original cam chain tensioner.
    I'm surprised no one else spotted this? You are doing a great job on your engine, and I really like the frame, but next time you are turning the timing plate, use a 19mm wrench on the square flats, and not the 6mm allen key. They have been known to snap off which would not be fun. BTW, killer price on that Raptor adjuster!
    Bone stock 1980 Special except for the exhaust and crashbars. Oh yeah, and the scabbard for the Winchester Defender.
    • TheRev
      • Jun 2012
      • 235
      • Madison, Wi.
      #47
      Great tip. That would have been bad it if snapped off. I learn something new everyday on the forum. Thanks
      1979 xs1100f
      New Fuse Box
      Progressive Shocks
      Gold Valve Emulator
      Dyna Coils
      Electronic Flasher
      Led Headlight
      Led Turn Signals
      4 Led Driving Lights
      2nd Gear Fix
      Auto Cam Tensioner
      Digital Dash
      Stainless Braided Lines
      R6 4 Piston Calipers
      Stainless Bolt Kit
      Maier Fairing
      Dyna Balancing Beads
      Spin On Oil Filter
      Stebel Nautilus Horn
      Plasti Dip Rims
      ISO Grips
      • TheRev
        • Jun 2012
        • 235
        • Madison, Wi.
        #48
        My notes said I paid 40 dollars. Do you need one?
        1979 xs1100f
        New Fuse Box
        Progressive Shocks
        Gold Valve Emulator
        Dyna Coils
        Electronic Flasher
        Led Headlight
        Led Turn Signals
        2nd Gear Fix
        Auto Cam Tensioner
        Digital Dash
        Stainless Bolt Kit
        Maier Fairing
        Spin On Oil Filter
        Plasti Dip Rims
        ISO Grips
        • TheRev
          • Jun 2012
          • 235
          • Madison, Wi.
          #49
          It's been a long while since I posted anything on this thread. However. I have been busy working on the bike. It's -24 degrees here in Wisconsin so my garage is quite cold but here are a few pics of my project.
          Check out the smoked lenses on the turn signals. It matches the over all look of the bike.
          1979 xs1100f
          New Fuse Box
          Progressive Shocks
          Gold Valve Emulator
          Dyna Coils
          Electronic Flasher
          Led Headlight
          Led Turn Signals
          2nd Gear Fix
          Auto Cam Tensioner
          Digital Dash
          Stainless Bolt Kit
          Maier Fairing
          Spin On Oil Filter
          Plasti Dip Rims
          ISO Grips
          • TheRev
            • Jun 2012
            • 235
            • Madison, Wi.
            #50
            Here is another pic. The previous owner had installed a vetter fairing which I quickly took off. What was left was these bars that were welded on the frame that held the faring on. I improvised and used those bars to install some awesome LED running lights. Don't worry they are aimed low so they don't blind the oncoming cars.
            1979 xs1100f
            New Fuse Box
            Progressive Shocks
            Gold Valve Emulator
            Dyna Coils
            Electronic Flasher
            Led Headlight
            Led Turn Signals
            2nd Gear Fix
            Auto Cam Tensioner
            Digital Dash
            Stainless Bolt Kit
            Maier Fairing
            Spin On Oil Filter
            Plasti Dip Rims
            ISO Grips
            • TheRev
              • Jun 2012
              • 235
              • Madison, Wi.
              #51
              I also cut the rear fender because I don't like how low it sits. That gave me an opportunity to install a LED rear tail light. I chose a cat eye light. I think it will look sharp when all is completed. I also smoked the rear turn signal lenses to match. I tested the turn signals and they are plenty bright. My goal is to use all LED lights. I am currently working on the LED Flasher Mod. You can also see that I make the wheels silver. I actually used Plasti Dip for the wheels. A bunch of people are using these on car rims so I thought I would try it. The cool thing is I can literately pull it off if I want to go back to the stock rim.
              1979 xs1100f
              New Fuse Box
              Progressive Shocks
              Gold Valve Emulator
              Dyna Coils
              Electronic Flasher
              Led Headlight
              Led Turn Signals
              2nd Gear Fix
              Auto Cam Tensioner
              Digital Dash
              Stainless Bolt Kit
              Maier Fairing
              Spin On Oil Filter
              Plasti Dip Rims
              ISO Grips
              • TheRev
                • Jun 2012
                • 235
                • Madison, Wi.
                #52
                This mod was the most difficult so far. I wanted to upgrade my brakes so I picked up some R6 calipers, build an adaptor, machined some hub spacers, installed some 320mm rotors and installed some stainless lines. I am very happy with the way everything turned out. I also installed Gold Valve Emulator in the forks and added a Tkat fork brace so the frond end should be solid.
                1979 xs1100f
                New Fuse Box
                Progressive Shocks
                Gold Valve Emulator
                Dyna Coils
                Electronic Flasher
                Led Headlight
                Led Turn Signals
                2nd Gear Fix
                Auto Cam Tensioner
                Digital Dash
                Stainless Bolt Kit
                Maier Fairing
                Spin On Oil Filter
                Plasti Dip Rims
                ISO Grips
                • TheRev
                  • Jun 2012
                  • 235
                  • Madison, Wi.
                  #53
                  Here is another pic of the rear wheel. I was fortunate enough to have the OEM exhaust. I used CeraKote High Temp Ceramic Coating on the exhaust and on the entire engine. The product is super easy to use and incredibly durable. It is an air cure system that cures in five days to a super durable finish. I prefer it to powder coating because I can apply it myself and it goes on thin. I have used it on my shot guns and they hold up well, trust me my gun takes a lot of abuse.
                  Here is a pic of the engine. It's not the greatest pic because it is very dusty. I have been doing some grinding and the dust gets everywhere. I will clean everything up in the spring and take better pics.
                  1979 xs1100f
                  New Fuse Box
                  Progressive Shocks
                  Gold Valve Emulator
                  Dyna Coils
                  Electronic Flasher
                  Led Headlight
                  Led Turn Signals
                  2nd Gear Fix
                  Auto Cam Tensioner
                  Digital Dash
                  Stainless Bolt Kit
                  Maier Fairing
                  Spin On Oil Filter
                  Plasti Dip Rims
                  ISO Grips
                  • TheRev
                    • Jun 2012
                    • 235
                    • Madison, Wi.
                    #54
                    I installed some Dyna Coils. I believe my OEM Coils were fine but while the bike was apart I wanted to fix, upgrade or solve any potential problems. I just used some L brackets to mount the new coils.
                    1979 xs1100f
                    New Fuse Box
                    Progressive Shocks
                    Gold Valve Emulator
                    Dyna Coils
                    Electronic Flasher
                    Led Headlight
                    Led Turn Signals
                    2nd Gear Fix
                    Auto Cam Tensioner
                    Digital Dash
                    Stainless Bolt Kit
                    Maier Fairing
                    Spin On Oil Filter
                    Plasti Dip Rims
                    ISO Grips
                    • TheRev
                      • Jun 2012
                      • 235
                      • Madison, Wi.
                      #55
                      I forgot to post a pic of my fuse box upgrade. It was a straight forward upgrade. I really appreciate all the help this forum provides.
                      1979 xs1100f
                      New Fuse Box
                      Progressive Shocks
                      Gold Valve Emulator
                      Dyna Coils
                      Electronic Flasher
                      Led Headlight
                      Led Turn Signals
                      2nd Gear Fix
                      Auto Cam Tensioner
                      Digital Dash
                      Stainless Bolt Kit
                      Maier Fairing
                      Spin On Oil Filter
                      Plasti Dip Rims
                      ISO Grips
                      • TheRev
                        • Jun 2012
                        • 235
                        • Madison, Wi.
                        #56
                        For the stainless brake lines I choose to use two lines instead of the OEM three line. So I had to use a double banjo at the master cylinder. I also choose to use some sport bike bars for better look and handling.
                        Some of you may be wondering what the digital dash is. I purchased a Danmoto 180 digital dash. Everything works as intended except the tach. I still have to work out a couple of bugs with that. The speedo is electronic to I no longer use a cable. I purchased a machined spacer for the wheel hub that takes the place of the old speedo drive.
                        I made some simple brackets out of some flat stock. I mounted the brackets to the OEM Dash Mounts on the triple tree. Once I had the bends correct I had them powder coated to match everything else.
                        1979 xs1100f
                        New Fuse Box
                        Progressive Shocks
                        Gold Valve Emulator
                        Dyna Coils
                        Electronic Flasher
                        Led Headlight
                        Led Turn Signals
                        2nd Gear Fix
                        Auto Cam Tensioner
                        Digital Dash
                        Stainless Bolt Kit
                        Maier Fairing
                        Spin On Oil Filter
                        Plasti Dip Rims
                        ISO Grips
                          #57
                          Very nice!!! Your doing some great work on that old bike.
                          I am interested in that coating for the exhaust. I have an original exhaust on my project bike but it has been welded back together in a few spots, so chrome is not in its future, that looks like a nice durable alternative.
                          • SFerinTEXAS
                            • Jun 2006
                            • 876
                            #58
                            Some effort to absorb all you have done. .Outstanding. I have 1 question above many . How much of the Cerakote would you suggest to do an entire exhaust?
                            79SF
                            XJ11
                            78E
                            • TheRev
                              • Jun 2012
                              • 235
                              • Madison, Wi.
                              #59
                              The CeraKote is super easy to use. All I did was sandblast the exhaust and engine in my case. Then I use a HVLP gun just like normal painting. The tip of the gun needs to be small, I believe it's .8 mm or something like that. Then I just let it cure for 24 hours. After 5 days the coating is completely cured. It's as simple as that. I didn't want any chrome on the bike so it made good sense to me. When I realized how easy it was to do I started doing it myself. No need to take it to a pro.
                              1979 xs1100f
                              New Fuse Box
                              Progressive Shocks
                              Gold Valve Emulator
                              Dyna Coils
                              Electronic Flasher
                              Led Headlight
                              Led Turn Signals
                              2nd Gear Fix
                              Auto Cam Tensioner
                              Digital Dash
                              Stainless Bolt Kit
                              Maier Fairing
                              Spin On Oil Filter
                              Plasti Dip Rims
                              ISO Grips
                              • TheRev
                                • Jun 2012
                                • 235
                                • Madison, Wi.
                                #60
                                You actually use very little. I bought the smallest amount possible and I still have a bunch left over. A little goes a long way because you apply it so thin.
                                1979 xs1100f
                                New Fuse Box
                                Progressive Shocks
                                Gold Valve Emulator
                                Dyna Coils
                                Electronic Flasher
                                Led Headlight
                                Led Turn Signals
                                2nd Gear Fix
                                Auto Cam Tensioner
                                Digital Dash
                                Stainless Bolt Kit
                                Maier Fairing
                                Spin On Oil Filter
                                Plasti Dip Rims
                                ISO Grips
