    #3151
    Well, got around to tearing into Godzilla further.
    Okay folks,
    After breaking the left turn signal threaded stalk(hopefully I can unthread the remaining broken piece out and reuse the remainder to reinstall it?) I said I was going to HOIST it up like an almost endover wheelie! Well, I brought in the wooden hoist rig I had made the last summer from some 2x8 planks that used to be a bed frame, along with 2 layers across the top, and various 2x4 sections as cross braces to keep it from flexing and collapsing.
    I put the bike lift under it, and pushed Godzilla up onto it, put it up on the center stand, and then skidded it up to the wheel stop end. This positioned the handlebars just underneath the hoist frame. I had first thought of using the EYE bolt I had rigged up, but then decided with the ratchet straps to just drap them across the top hoist frame piece....space them apart a bit and this along with attaching them to the handlebar clamps would help stabilize it some and keep it from spinning so easily!
    Forgot to mention I pumped up the hoist to maximum height before attaching the ratchet straps, this way I didn't have to ratchet them much to get the height I was hoping for.
    Then I LOWERED the lift to just clear the rear wheel, so essentially the bike was HANGING from the hoist/straps. I also attached 2 additional SAFETY straps to the frame and hoist since I was going to be sitting/laying UNDER the bike, and wanted something to keep it from crashing down on me if the handlebar clamps/bolts or the main ratchet straps gave way!
    Dropped the oil pan, and pulled the OIL PUMP. I was surprised to see the condition of the O-ring. I had put a new one in in 2000 when I did my major topend/rebuild. I think I was from the LOCAL HARDWARE store, and I thought it was a NEOPRENE type that could withstand the oil and heat and pressure? Guess I was WRONG? I;m pretty sure it wasn't a Harbor Freight one though.
    I was ready to remove the countershaft bearing but after 15 minutes searching realized that I had lost my 30T Torx bit I had used 17 years earlier, and had to run off to Lowes to get another one!
    Got the shift pawl, and the shift fork shaft out, then pulled the 5th gear out, had already loosened and removed the large bolt from the other end of the countershaft, removed the shift forks, and then wiggled the shaft and gears and got it out in just a few minutes.
    Here's what the dogs on the 4th gear that engages with the solid 6 land 1st gear looked like. No wonder it was starting to skip!
    But now for the BIG REVEAL with regards to the 2nd gear and washer swap THEORY!!! Remember, folks felt that the extra thick washer doesn't allow enough depth engagement of the 5th gear dogs into the 2nd gear slots, and this is part of why we think they round off. Remember they are/were square cut at the factory! When I did my Tranny fix in 2000 and have put some 25+K miles on it, I did NOT do the washer swap. I just did an aggressive grinding of the 5th gear dogs and 2nd gear slots to match the same angles that WERE in the OEM 3rd gear dogs that WERE back/under cut at the factory.
    SO..as you can see from these 2 photos, the dog on 2nd show essentially NO signs of rounding off on the tips/edges, and the simple step of undercutting the dogs and slots appears to be adequate alone for keeping them engaged and not letting them get rounded/worn which leads to skipping. The propensity for the rounding affect IMHO comes mostly from the OEM square cut design, and IF Yamaha had undercut/angle cut them at the factory, we wouldn't even need the Dremmel fix for the 2nd gear, much less the extra work of swapping/moving the washer, and then the extra work of trying to get the countershaft assembly back into the engine since the washer swap shifts things a bit more adding to the difficulty factor of this process.
    I didn't TOUCH the 5th gear dogs/2nd gear slots at all this time, and STILL haven't moved the washer.
    Here are the 4th gear dogs back/under cut a little more aggressively to match the 3rd gear dog angles, and I also reground the 6 lands/slots on the 1st gear trying to put a corresponding angle on them as well.
    Then came the fun part of putting it together and back into the engine. The Countershaft assembly wasn't difficult, but the shift forks were a PITA! I got the middle fork flipped around the first time and THEN realized that the fork shaft wouldn't make it thru it and the 1st and 3rd shift fork. Had to reverse it, and and play with the shift drum and such, but finally got it all sorted out. Thankfully I had done this once before on it's BACk, I don't think I would still recommend this hoisting technique for the 1st timer/novice mechanic to use/attempt to perform this MOD/repair.
    I got all of this done Friday night and Saturday afternoon early evening. Later that evening, SWMBO let me know that she had been having this "CHEST PAIN" off and on for several hours, and that it was radiating to her left arm and her neck! DING< DING...Warning Will Roger...DANGER...DANGER!!
    Not sure how many of you all know that they(Medical community) has learned that WOMEN usually do not have these CLASSIC types of heart attack symptoms like MEN do, but these ARE classic heart attack symptoms. She wasn't nauseaus or sweaty, but knowing her strong family history of heart attacks....Dad-died, Sister, and Mother....She agreed that we should take her to the E.R. to be "checked out".
    15-20 years ago she had some different chest pains, had a stress test and was diagnosed with Microvascular angina.....in other words, nothing to worry about THEN. She had also been given Nitro under the tongue, and all it did was give her a headache, didn't help the chest pain.
    This time, they did a STAT EKG, drew cardiac enzymes/blood labs, and then gave her 4 kids aspirins, and then a NITRO. THIS TIME it helped the pain go away and didn't give her a headache....one confirmation sign! Her EKG and blood labs were OKAY, but because of her many other risk factors, diabetes, blood pressure, AGE, they said they wanted to ADMIT her to the Hospital for both observation and further testing ie. EchoCardiogram, eventually a Stress Test. So she spent the night, and today they repeated the cardiac enzymes/blood tests, and they still looked GOOD, she's been wearing a NITRO patch, and has not had any more chest pain. The EchoCardiogram appeared okay, but due to the Holiday weekend, the Cardiologist had already gone home for the day. The admitting Dr. discussed her case/history with him, and it was recommended that she stay yet another day/night for continued observation, and the Cardiologist will visit/see her tomorrow AM. Depending on his exam, they MAY let her go home tomorrow and get the additional tests on a OUTPATIENT basis. Not sure if she'll have to have a Cardiac Catheterization, and depending on those findings possibly a stent or so inserted IF they find significant blockage. But right now it looks like it was just an ANGINA attack, but not necessarily a full blown HEART ATTACK. PHEW!
    So...here's hoping your holiday weekend is a bit more enjoyable than mine!
      • 9981
      I just got one of those HF lifts today TC. I like it but that front wheel vise needs to be upgraded. Found one on GOOGLE for about $100 I think I'm gonna get.
        I'm glad your wife's okay!
        The setup for hanging Godzilla and the transmission gears look great!
        For cutting and rethreading your turn signal, CFR Title 49 covers separation and quite a few other details:.
        There are also laws that flat-out explicitly prohibit modifying the original lighting geometry.
        I got a ticket from the CHP back in '81 after I broke a turn signal on my KZ and cut it to fit so it can happen and the police are looking, it depends on if you hear a chicken cluck when you get pulled over.
        • donebysunday
          • Oct 2012
          • 1737
          • New Berlin, Wi.
          #3154
          Wow TC I thought I was having a tough weekend, You and yours I'm sure have all our prayers.
          76 XS650 C ROADSTER
          80 XS650 G Special II
          https://ibb.co/album/icbGgF
          80 XS 1100 SG
          81 XS 1100LH/SH DARKHORSE
          https://tinyurl.com/k6nzvtw
          AKA; Don'e, UD, Unca Don'e
            #3155
            Sorry, no photos this time.
            Well,
            Got quite a bit of work done on Godzilla today, Oil pump back in, tranny pan, clutch assembly and clutch cover, gear shift shaft seal replaced and cover on. Fixed broken left turn signal threaded shaft....borrowed one from another signal stalk I had. ALso found the no turn signal on the left side a simple fix, pulled the switch assembly and the left side wire came unsoldered from the switch board, resoldered and good to go!
            I had drained the final drive oil, but has just capped the middle drive vent tube so it wouldn't leak while flipped upside down. But after doing the HOIST method instead of the flip, I hadn't planned on changing the middle drive because I had just changed/filled it last year during the rebuild. But since I had gotten some Synth 75-140 Royal Purple Hypoid, I decided to go ahead and put it both final and middle drives....since I was going to be riding the bike the many hundreds of miles down there.
            And it's good thing I did, because what came out of the middle drive looked like a light Cappuccino and not 80-90 Hypoid oil! SO...I figured it must have gotten some water contamination in it from all of the rain riding I had to do. But wondering how since I had the vent drain hose well positioned down the back of the engine and out thru the frame swingarm wire bracket. The filler cap was well sealed with a nylon washer. Oh well, it's drained and I filled it with the Synth Royal Purple, hopefully that and riding it a while will heat up any residual moisture and get it to vent out!?
            Also checked my state inspection station and the fellow that knows me and Godzilla will be working next weekend, so that works out well for me.
            Have more to do tomorrow, but got the major things that had me worried about both performance and inspection under my belt.
            Scott, Thankfully I dont' live in "Can'tAffordYa" and all of their ANAL tendencies with vehicle law enforcement. My turn signals have been modded with LED innards for decade+ and haven't had any problems with inspections and such. Again, I know a guy at the inspection gas station that knows that I take care of my bike, and keep it in proper working condition, he is/was a biker also, so I have some leniency in his approach.
            PS, Nancy's Cardiac Cath showed only about 50% blockage, not severe enough for any Stents or Balloon angioplasty, just will make some medication changes to manage it, like her taking her Cholesterol meds AGAIN !
              • 8963
              TC, the MD vent hose is supposed to run upwards to a dry location to avoid water contamination.
              • spectra
                • Aug 2017
                • 113
                • Vancouver, WA
                #3157
                TC good to hear she is doing good! And that a lot of work hanging that thing......
                79 SF
                  I checked the spark plugs here in Phoenix, all good and the bike's running great!
                  T.C., the CFR is the Code of Federal Regulations, the States can make more restrictive laws but can't do less or no one could travel out of their home State, it's not a Call thing, if your inspector will ignore it -- great! It still won't change what other States can do.
                    Good to hear the XJ and you are both happy after your jaunt to there.
                      #3160
                      Godzilla Roars again.
                      Well,
                      Did a fair amount of work today. Cleaned and Repainted the muffler to get rid of the oil stains and heat stains and then remounted the headers/muffler, will see how long it lasts? Had to take off the rear caliper to remove the pads....OIL fouled from the Rt crankcase seal leak! Cleaned the rotor as well. Got the seat mounted. Had to replace one of the fuel lines to the carb "T". Put the gas tank on and connected the fuel hoses. Tore the carbs down and cleaned the jets, bowls and reassembled and installed. Got the Race/Automotive Alt bracket and Alt mounted, also sealed the galley plug with a new O-ring and 3bond. While manipulating the 10Ga charging wire, it came loose from it's CRIMPED O fitting going to the cutout switch I had to separate the ALT from the battery when the bike's not running. SO, had to trim and recrimp the wire BETTER into the O fitting, glad it happened NOW and not while running down the road.
                      Put the trunk bag back on, put bullet connectors on the 3 wires I had to cut going to the trunk lights, now I can take it off without cutting the wires again. Put the mirrors back on. Had to remake one of the windscreen brackets that got broke when the bike collapsed the 1" square tubing. Filled the crankcase with 3 quarts of Wallyworld 20-50. Had to repair 2 of the synch ports on the new intake manifolds that pulled out when I tried to pull of the vac. hose I had on there in place of the port caps! Turned the key and hit the starter button, and he fired right up. Rode it around the neighborhood for a few minutes going thru the gears, they all work. After getting back home, checked and so far no leaks from the right crankcase seal, so hopefully it'll hold.
                      SO it's ready for the inspector next weekend, and then the trip to XS SE the following weekend.
                      • HalfCentury
                        • 408
                        • Burlington NC
                        #3161
                        TC, its an amazing amount of work that you have done to your bike. Same goes for 3Phase.
                        I am looking forward to seeing these bikes in person that I have read so much about.
                        82 XJ1100 - sold
                        96 Honda Magna 750 - Girlfriend's bike
                        2000 ZRX1100 - sold
                        2003 FJR1300 - Silver rocket
                          • 7844
                          As Phil said, you CANNOT have the vent go down! I had my bike spewing a coco mix as I was going down the road because the PO ran the vent down, and NOT up as it's supposed to. The "clip" that should be under the seat bolt is to hold the vent tube under the fuel tank. If the tube is down, it WILL pick up water in the rain, as the rain cools down the middle drive, and the vent sucks in whatever is around when this happens.
                          • mschor
                            • Jan 2017
                            • 183
                            • West Palm Beach, FL.
                            #3163
                            I Can Gingerly Tip an XS11
                            Add this to my list of things not to do twice. Last night after backing a couple inches closer to my XS so I could pull out of my parking space, I noticed a little flutter in the cover. Oh must be just a little breeze picking up, I thought to myself. So I paused a minute just to be sure before pulling forward and out. Oh the sight through my rear view of that beautiful 600lb machine beginning to topple.......no wait maybe its just the wind.........CRASH......a sound like plastic fairing and bags crumpling and who knows imaginings running wild....alas, barely a scratch, Amazing!.......it's built like an International Scout after all.
                            [IMG][/IMG]
                            81 Special
                              • 8963
                              I'm glad it wasn't worse, It doesn't look too bad, a little touch up paint and no one will ever know. Is that a chrome moulding that got messed up too?
                              • CaptonZap
                                • Jun 2010
                                • 1748
                                • Denver
                                #3165
                                Craig Vetter, Vetter, motorcycle design, Triumph Hurricane, Vetter Hurricane, Windjammer, Windjammer parts, Vetter fairings, Vetter fairing, Vetter history, fairings, Triumph Rocket 3, Mystery Ship, mysteryship, Terraplane, motor scooter design, industrial design, Triumph Bonneville TT, fuel economy contest, designer, inventor, lecturer, flying machine contest, high mileage contest, Quicksilver fairing, snap-vents
