    • 2095
    Originally posted by motoman
    Good to hear the bike is working out good for you! As for the Conti Go's, they mate with the XS11's frame and handleing design like they were made for the XS11. Over the 3+ decades, I've run bout every brand of tire out there on my Venturer. The Continentels had always been the make of tire that matched the handling/design of the Venturer IMO. The Conti Go tires still fall in that same category as the old style Continentals RB2(front) K112(rear) of decades ago. Plus they stand a bit taller and wider(.015 clearance between tire and driveshaft housing on rear) than majority of other brand equivalent size. Also, the load carrying rating of Conti Go's is a bit higher than any other brand of tire. They also sipe water in hard rains extremely well. You'll be a happy rider with them on your bike.
    Brant,
    Your opinion and time tested experience with the Conti's helped with my decision.
    My 80G came with Conti Blitz's when I bought it in '92 and I replaced them with the same when it was necessary as I really liked them. Not sure when Continental discontinued the Blitz and in need of new shoes for my girl your reveiw of the Go's sealed the deal 'cause I wasn't sure if the quality went away like almost everything else.
    Thanxs for the tip
      • 9980
      Not hard to tune Greg.......but are a bit more finiky with adjustments and float settings.
      Been into then carbs 3 or 4 times. Runs great going down the road but at stoplights not so much unless you keep clearing the cyls........like an old hardly.
      Idles perfect for a few minutes then just freakin dies.
      And #1 needs the mixture screw turned WAY out to get a decent idle. Thought it was a bad carb body but I swapped it out and still the same.
      • Bigfoot
        XS-XJ GURU
        • Sep 2005
        • 1422
        • Kansas City, Missouri
        #2898
        On Thursday the weather in Kansas City was beautiful, so I jumped on the bike and decided i was riding for work. . First stop was a client about 20 miles away. Pulled into the parking lot, put in on the sidestand. Smelled gas, and thought crap, got a sticking float. Looked down and saw a steady stream of gas pissing all over my engine from a nice little hole that decided to open up near the front of the tank on the left side. Hit the kill switch, jumped off the bike, fumbled for my tool kit to get a wrench and pull the seat off then the tank. Of course I had just filled the tank and had a good 6 gallons in it. Day went from awesome to crappy in just a few seconds.
        On a good note, at least I already have a spare venture tank in the garage. Started prepping it to paint today.
        Harry
        '79 Standard
        '82 XJ1100
        '84 FJ1100
        Acta Non Verba
          • 9980
          That's what you get for not riding. The bike is PISSED at you.
          • Bigfoot
            XS-XJ GURU
            • Sep 2005
            • 1422
            #2900
            Yeah she is. Other than trying to make me a fireball going down the freeway, it is running good. lol
            Harry
            '79 Standard
            '82 XJ1100
            '84 FJ1100
            Acta Non Verba
              had that same issue with mixture screw WAY out on #4 of mine a few yrs. back. A carb removal and finding #4 idle mix screw o-ring fubared and missing the teeny flat washer for o-ring. Replaced those pieces and mixture screw easily tuned in at approx. 2 1/4 out from seated like or very similar to other three mixture screws...........JAT.
              • MarkD
                • Jun 2013
                • 488
                • N. Michigan
                #2902
                So-- today I finally started up my F. In the fall, I did the usual winterizing, which includes fogging the cylinders. Not to make anyone who posted today about the early carbs being a pain to tune jealous, but it started right up, and idled very smoothly. After a 20 minute run around the area, it still was idling really well. No, you can't have my carbs.
                79 F
                1967 Suzuki X6 Hustler
                1973 Suzuki TM 125
                1979 XS1100 F
                2005 Kaw. Vulcan VN800
                1991 BMW K75
                  • 2095
                  Jat
                  Are the B-fly shaft seals new ?
                    • 9980
                    O-rings all there and not broken.
                    I had that thought too but as I said I swapped out the carb body and when I did the butterfly shaft had to be swapped. The seals aren't new but good. I put the best 2 from both carbs in there. Swapping bodies made NO difference.
                      • 2095
                      Greg, check your fuel lines to make sure the carbs aren't intermittently running dry.
                      This morning I fired the G up and put on my gear but by the time I got my gloves on the bike sputtered, popped a lot and died, wouldn't start or fire at all so off came the gear and I remembered when I came back from my shakedown ride the fuel in the lines was bubbling 'cause they are too long and laying on the engine near the starter. I didn't realize the starter cover got that hot so I tucked the extra up under the tank and created an air trap that starved the carbs this morning. Dropped them back down and fired right up.
                      Also is the voltage for the TCI staying up while at idle ?
                        • 9980
                        Gimme a break. That's a given. Besides, as I said it runs fine down the road, the only issue is at idle.
                        I do need to check that. However, as it idles the RPM slowly drops over a few minutes then it just dies.
                        The tach IS all over the place though. Something else to check. Thanks
                        • XJOK2PLAY
                          • 2099
                          • Skiatook, Ok.
                          #2907
                          Greg,
                          My Maxim used to do those same two things. Another thing it also did- turn signals at idle would flash fine on the right side, but would just stay on and not flash on the left. It would idle, then stall, like yours. Ran great down the road. Was a handful to ride stoplight to stoplight.
                          Checked voltage at idle compared to 3k rpm. 11.2 at idle. Went through every connection, every ground... no luck.
                          My tach would bounce wildly all over the place, too.
                          Cody and I decided to look at the alternator. Pulled the stator out and turned it over. It had been hot, and all the resin was cracked up.
                          Replaced that, solved all the issues, and voltage at idle then was 12.5. Tach was perfect, turn signals worked perfectly on both sides.
                          I know about the differences between XJ and XS charging systems, but might be worth a look see? JAT.
                          That was also back when I still used the stock thermal flasher, too.
                          2011 Kaw Concours 14 ABS
                            • 9980
                            Voltage at idle hangs right about 11.8. I rode it out to Owasso the other day and the turn signals refused to even come on, emergency flasher worked fine though. Since then the signals have started working again.
                            There is a big difference between XJ and XS alternators. This one jumps up to 13 - 13.5 off idle.
                            • mack
                              • 2411
                              • Ontario, Canada
                              #2909
                              First good
                              riding weather this year in the last couple days. Still a lot of sand on the road as it has been very dry up here. Took the SF out for a good ride yesterday but 100 miles from home I started to get an intermittent subtle vibration in the left highway peg. Didn't feel anything at the drives peg but I could feel it when I put my feet forward.Stopped for a break and looked over the bike for anything loose and discovered a small leak at the middle drive cover. Had no oil with me so I nursed it home in fifth and checked the level. The unit was way down in hypoid. Retightened all the bolts today and topped up the levels and took it for another scoot to see if the vibration was gone and it was. Funny how in tune you get with these bikes!
                              mack
                              79 XS 1100 SF Special
                              HERMES
                              original owner
                              81 XS 1100 LH MNS
                              SPICA
                              78 XS 11E
                              IOTA
                              https://youtu.be/wB5Jfbp6SUc
                              https://youtu.be/RaI3WYHSuWA
                              Frankford, Ont, Canada
                              613-398-6186
                              • nzemke
                                • Sep 2012
                                • 179
                                • Moses Lake, Wash.
                                #2910
                                Replaced the small junk china knock off 1:1 digital tachometer. Not sure why I keep entertaining the notion that ebay china crap will be any good for me or the bike. On the other hand I picked up the 79 XS1100 sf round gauge for 20 including shipping. And it is SUPER clean. And wish that the guy bending the rear hoop wasn't flaking on me so much >.< I want that done so I can go through and repaint the frame poor thing looks like crap with the frame scratched up slightly sanded...Still need to take the rear wheel off and replace the tire.
                                79F with two parts bikes (78E and a 79F). Ran it for the first season all the way through the summer. more work to do this Spring!
