  • Bigfoot
    XS-XJ GURU
    • Sep 2005
    • 1422
    • Kansas City, Missouri
    #1426
    It took quite a bit to figure out how to get them mounted as the brackets that were with them were either incomplete or for something different. A little thinking outside of the box got it done. Wired up the two inner lights to work with the brake lights and the outer ones are the turn signals.
    Harry
    '79 Standard
    '82 XJ1100
    '84 FJ1100
    Acta Non Verba
      • 9981
      Cool, can't wait to see it.
      I need to make another trip up there with Bear's carbs. I got a 4 day weekend over Thanksgiving. Maybe then if the weather ain't too bad.
      I see you found some locks?
        Originally posted by Bigfoot
        Installed a luggage rack and hard bags.
        Hi Harry,
        That looks like a nice set up. Do all those extra tail lights light up as running lights or are two brake lights?
          OK Answer was on page two
          • MPittma100
            • Aug 2011
            • 2359
            Ride
            Marty, let me know which day you want to ride a day or so in advance. Where do you want to go?
            MP
            1981 XS1100H Venturer
            K&N Air Filter
            ACCT
            Custom Paint by Deitz
            Geezer Rectifier/Regulator
            Stebel Nautilus Horn
            EBC Front Rotors
            Limie Accent Moves On In 2015
            Mike
            • Bigfoot
              XS-XJ GURU
              • Sep 2005
              • 1422
              #1431
              For a more complete answer, yes. lol.
              They all have dual element bulbs and light as running lights as well as brake lights for the inner two and turn signals for the outer two.
              Harry
              '79 Standard
              '82 XJ1100
              '84 FJ1100
              Acta Non Verba
              • Bigfoot
                XS-XJ GURU
                • Sep 2005
                • 1422
                #1432
                Mounted this fairing on the '79. It is a fairing off of a Venture that i got from Ivan.
                Had to cut a piece of glass for it and fix some of the wiring. I didn't bother painting it as it is just temporary until i get the other fairing i am working on done. This buys me some time so i don't have to rush it.
                Harry
                '79 Standard
                '82 XJ1100
                '84 FJ1100
                Acta Non Verba
                  • 4015
                  Actually, nothing at all. The bike is running so good, I really cannot think of anything to do to it. Maybe when things wear down, I'll do a valve clearance check, and check the timing and re-sync the carbs and re-set the air-fuel mixture. I'll have to re-build the petcocks, probably pull the calipers apart along with the master cylinder to see what they look like, check on all of the electrical connections, re-paint the engine, and then possibly think about a new color for the tins.
                    • 4015
                    Checked the valve clearances, re-synced/colourtuned the carbs. And, ripped up a valve cover gasket.
                    • LTKlein
                      • 2
                      • Phoenix, AZ.
                      #1435
                      Made
                      Made the decision to start the process of getting mine on the road, joined the forum and started the assessment.
                      It's a 1979 1100F with 28K miles. Belonged to my Dad in Illinois who parked it after getting a new bike about 10 years ago.
                      Brought it down to me in AZ and it's been sitting in my garage for the past 6 years.
                      Looks a bit tired...dark covers, a bit of rust from and last it ran..pretty rough.
                      Used to own a new one when I was over in Guam, so I know the bike well and miss the feel of it. Time to feel the rush again..
                      Pics/links and a thread when I actually do something credible...
                      79 F
                      • Pat Kelly
                        • 3046
                        • Golden Valley, AZ
                        #1436
                        Agreed to sell both bikes and all the parts I have for them. Mike will be happy.
                        Pat Kelly
                        <p-lkelly@sbcglobal.net>
                        1978 XS1100E (The Force)
                        1980 XS1100LG (The Dark Side)
                        1999 Suburban (The Ship)
                        1994 Dodge Spirit (Son #1)
                        1968 F100 (Valentine)
                        • Aches n Pains
                          • 349
                          • Reston, Va.
                          #1437
                          LT - we need pictures. Start a new thread on your work and keep us posted. Motorcycle porn is my favorite pass time.
                          Aches n Pains
                          1995 KZ100P
                          Pods, jets, pipes, cam adjuster, oil cooler
                          1977 Ironhead - custom build
                          Hot engine, custom frame, KZ front and rear, high torque starter, alternator conversion, Progressive shocks, Thunderheart wiring, Dyna ignition, oil cooler, Dakota Digital instruments, etc.
                          Sold all my XS's to Eastcoaster but still love to keep up with you guys. This is the best cycle forum on the web.
                          • RODS454
                            • Dec 2009
                            • 83
                            • Midlothian, Tx
                            #1438
                            Running Again!
                            The Cruise Missle is once again running. Cleaning the carbs did the trick. Balanced them, but need me a good tach to set idle mix, as my ears aren't good enough anymore. Installed the stock exhaust system I got from tv5150. I like the sound much better. Screaming loud is just not my thing anymore. Haven't got to ride yet, as I have a few fuel leaks, at petcocks, to deal with. Thinking about going with the Pingels, just to not have to deal with the old stuff.
                            "I'd rather be fishin'"
                            1980sg "Cruise Missle"
                            2002A Goldwing
                            • Rasputin
                              • 3193
                              • Lacombe, Alberta, Canada
                              #1439
                              Not worth it in my mind as rebuild kits and a bit of hand work will make these last for another 30 yrs and the Pingels would be more money. The bike when it was original worked like God's gift to motorcycle people everywhere. I know we do have to go aftermarket for some parts but I prefer to try to keep it like it was intended to be.
                              Of course if any parts are past fixing and can not be redone or found elsewhere, then by all means do what you have to in order to keep these bikes alive.
                              OMG I think I have just been labelled a "Purist" by Fred
                              2-79 XS1100 SF
                              2-78 XS1100 E Best bike Ever
                              • RODS454
                                • Dec 2009
                                • 83
                                • Midlothian, Tx
                                #1440
                                Not worth it
                                It is not the petcock itself that is leaking. It is the mating surface. New o-ring, new screws, new screw washers, and still leaks. Tried permatex moto gasket, and it is down to less than a drop in 8 hours. just on the right side. Money is not an object with me as it is with some, and I surely know how they feel, as I have been there before. My time is much more valuable now. I believe the Pingels will give me a better mating surface w/permatex, than the o-ring. Also I like the looks of the Pingels. And keeping this bike stock is definately not part of my plan.
                                2002A Goldwing
