  • draketrumpet
    • Feb 2010
    • 387
    • Norman, OK
    #256
    Originally posted by WMarshy
    IS THERE ANY GOOD WAY TO FILL THE REAR MC WITH OUT OVER FILLING IT AND MAKING A MESS???
    Very carefully.
    • CatatonicBug
      • 6117
      • Clinton, UT
      #257
      I use an icee straw. Actually, I MAKE an icee straw by cutting open the end of a bendy straw and spreading it open. It makes a teeny tiny funnel. I also only pierce the foil cover on the brake fluid bottle with two little holes to make it possible to pour into the tiny funnel.
      • draketrumpet
        • Feb 2010
        • 387
        • Norman, OK
        #258
        I sold it for $100!
        No, no, not Monster. That other little bike that hasn't run since October when the piston mysteriously froze (ok, not so mysteriously, but all the same, it froze). Some kids came to the door and asked if I would sell it to their dad. I had been contemplating putting it on craigslist at 75 or 100 obo, so I told it didn't as is and I'd take 100. 20 minutes later I had to go find the title and keys . Now, what to do with the $100 to make Monster ride better....
        • CatatonicBug
          • 6117
          • Clinton, UT
          #259
          Good for you! Too bad $100 is spent so quickly on these things... I just spent that on my new seat cover!
          • XSokieSPECIAL
            • Jun 2009
            • 1631
            • Tulsa, OK
            #260
            We know where to get seats covered CUSTOM for a good price don't we Dale?
            • draketrumpet
              • Feb 2010
              • 387
              • Norman, OK
              #261
              Yep, great price...if you can wait a bit
              • CA
                • Feb 2009
                • 267
                • Nashville, TN
                #262
                Changed the
                middle and final drive oil. I bought the bike over a year ago with 12k miles. It now has 17K and I had never checked it. And the bike had sat for 5 years before i got it.
                The stuff i pulled out was dark and gray, the stuff i put in was nice and yellow.
                1979 XS1100SF (4-1 Kerker, XS Pods, 145 mains, 45 pilots, drag bars, blacked out)
                • tcoop
                  • Nov 2009
                  • 793
                  • South Weber, UT
                  #263
                  Well yesterday
                  I pulled the front master control, took it apart cleaned it, put it back togeather and bled the breaks.
                  Cut some foam for my seat and cut out the vinal.
                  Pulled the Reat master control
                  Missed out on a ride up to Bear Lake because all my bikes are out of commission.
                  Ty
                  78 XS1100E - Now in Minnesota
                  80 XS1100LG - The Punisher
                  82 XJ1100 - Daughter's Bike
                  • 79XS11F
                    • Jul 2006
                    • 3563
                    • Ottawa, Ont. Canada
                    #264
                    Today I repaired the side cover lock on my hop up bike. It was not working properly and I nearly had to break the cover off to gain access to my battery.... which proved to be DEAD. It's 4 years old so I guess that's as much as I could expect from it.
                    Anyway I found the very tip of the original owners side cover floating around inside the lock so it would not fully release the side cover tab on my side cover. After removing it and lubing the lock it works fine. The battery is a different story. It is in deed DEAD and non chargeable so a replacement is needed before I move forward with tunning this bikes engine. Bummer, a battery will cost between 80 and 100 bucks. I also noticed that the battery ground strap is very weak at the frames mount point and it broke off with very little bending. I guess I will braze it back together cause I don't have a spare ground strap on hand.
                    On a different note I took my restored 79 bike for a run the other day and all is good with her :-)
                    Rob
                    KEEP THE RUBBER SIDE DOWN
                    1978 XS1100E Modified
                    1978 XS500E
                    1979 XS1100F Restored
                    1981 Suzuki GS1100
                    1983 Suzuki GS750S Katana
                    1983 Honda CB900 Custom
                    • Rasputin
                      • 3193
                      • Lacombe, Alberta, Canada
                      #265
                      Wonder what color
                      I finally finished the prep of the parts I need to paint. They are off a 78E, a 79SF and a 81LH. I am going to paint them all the same color, so I hope I am happy with whatever I choose. Leaning towards Black Cherry right now. Every piece was taken down to bare metal or raw plastic so no old paint to worry about. Yeah there is some bondo in each tank, although not much, and two of the side covers were repaired. They are spares for my 78E so they will be fine. Here is a couple of pics...
                      2-79 XS1100 SF
                      2-78 XS1100 E Best bike Ever
                      • Pat Kelly
                        • 3046
                        • Golden Valley, AZ
                        #266
                        Installed the 750 final drive today.
                        Pat Kelly
                        <p-lkelly@sbcglobal.net>
                        1978 XS1100E (The Force)
                        1980 XS1100LG (The Dark Side)
                        1999 Suburban (The Ship)
                        1994 Dodge Spirit (Son #1)
                        1968 F100 (Valentine)
                          Rob
                          Hi Rob,
                          I picked up an Energizer brand at WalMart for $69 +$10 deposit which you get back if you take in an old battery.
                          Maxim Phil
                            Originally posted by ManitoulinLad
                            Did the above as mentioned last night with 'red locktite" on the helicoil & the plug backed out this morning perfectly. Have anti-sieze on all plug threads now & took the bike to work today - Back on the road - feels good - Dan
                            Hi Dan. Glad to hear you got that sorted out.
                            Maxim Phil
                            • Crazcnuk
                              • Aug 2006
                              • 2980
                              • Hinton, AB, Canada
                              #269
                              Fixed a fuel leak, synched the carbs, set idle mixtures, and took the 78E for a few short test runs.
                              It feels like it's running out of fuel. it will pull to redline, but it bucks along the way. It's particularily bad below 3000rpm, but can feel it surging throughout the range.
                              Oh and jury-rigged teh headlight to come on with the key. Just temporary, but I can't figure out why it's not working normally.
                              Don't the 78's have an on/off switch for the headlight?
                              '05 ST1300
                              • draketrumpet
                                • Feb 2010
                                • 387
                                • Norman, OK
                                #270
                                Normal operation has the light come on regardless of the switch position when you start the engine. If you want it to come on before cranking the engine, flip the switch to on. But, without blowing a fuse or bulb etc. it should always be on with the engine running.
