  • ManitoulinLad
    • 358
    • Manitoulin Island,Ont.,Canada this is in Lake Huron
    #241
    Did the above as mentioned last night with 'red locktite" on the helicoil & the plug backed out this morning perfectly. Have anti-sieze on all plug threads now & took the bike to work today - Back on the road - feels good - Dan
    '81 XS1100 LH - Midnight Special - been lookin' a long time for this one.
    1179 big bore kit, 80SG motor
    Rebuilt head, valves
    TC Bros Forward Controls (Brass Pegs)
    Tkat Fork Brace
    T.C. Spade Fuse Box
    Dyna Coils & wires
    Mikesxs shocks,controls,& bars (special)
    ISO grips with stelleto ends
    4 into 1 black Bassani exhaust
    Bridgestone Spitfires
    Tuned by Tinman905
    & a will to keep it.
    • CA
      • Feb 2009
      • 267
      • Nashville, TN
      #242
      Fixed her internal Cancer
      Well I was just going to do a simply fusebox replacement this weekend, but then realized that the backing was beginning to rust and my battery box it attaches to was completely rusted. I forgot to take before's of the rust but here is the pictures I have from the project.
      And here is the after of the rusty battery box:
      My next project is to soda blast the engine and paint it glossy black. My question is do i nee to use engine primer before i use the VHT black gloss? the VHT doesnt call for it, but would it help a good bit? I plan to soak it down in acetone to prep it before I paint it. Hopefully that will be done by this next weekend...
      1979 XS1100SF (4-1 Kerker, XS Pods, 145 mains, 45 pilots, drag bars, blacked out)
      • jwhughes3
        • 2798
        • Home of the Alamo
        #243
        A new sticker
        Good to ride another year!
        '81 XS1100H - "Enterprise"
        • tcoop
          • Nov 2009
          • 793
          • South Weber, UT
          #244
          Pulled the clutch cover to check for clanking. Found no problem there.
          Ty
          78 XS1100E - Now in Minnesota
          80 XS1100LG - The Punisher
          82 XJ1100 - Daughter's Bike
          • XSokieSPECIAL
            • Jun 2009
            • 1631
            • Tulsa, OK
            #245
            If your looking for some clanking Ivan can fix you right up.
            • draketrumpet
              • Feb 2010
              • 387
              • Norman, OK
              #246
              Went to the local bike shop here in Norman...
              ...and there was a 79 special with full pacifico touring gear parked outside. Hopefully that guy will get on here to learn a thing or two about his bike. He was looking at getting his timing chain replaced.
              Also, picked up a Crampbuster on clearance for $5. Now I'm good for slabbin' it!
              • tinman905
                • Aug 2007
                • 946
                • Orangeville,Ontario ,Canada
                #247
                I took the main fuse from the left side of my bike and installed it in the fuse block behind the right side cover.
                I had my bike on the dyno a few days ago and solve a few minor problems dropped to a lower 124 main jet (Dyno Jet kit) and another 1/4 turn on my idle jet screws now at 4 1/4 turns out. It's running like a champ now so I can concentrate on how she looks now!
                BDF Special
                • exquized1
                  • Oct 2006
                  • 644
                  • Polo Il.
                  #248
                  Tried to get the new 80 standard running. Its been sitting for 24 years. She turns over fine just not firing.
                  68 Honda Cl350 (sold)
                  76 Honda Cb 400 super sport
                  79 special (skull bike)
                  79 special (parts bike w/title)
                  79 special
                  80 standard full dress (Sat 24 years)
                  81 special (parts for now trying to get the title)
                  81 kaw 750 ltd (sold to brother-in-law)
                  80 650 maxim (fixing for wife)
                  81 650 maxim
                  81 Xs 650 special ( No title found in a barn)
                  88 Zx 600r (Sold)
                  01 Gz 250
                  • XSokieSPECIAL
                    • Jun 2009
                    • 1631
                    • Tulsa, OK
                    #249
                    24 YEARS??? HOLY CRAP!
                    Compression, fuel, fire..........your missing one of them.
                      #250
                      Wow! I thought it was bad when my 400 sat for 13 years and I had to get it going again (ok, didn't have to, but I wanted to ). But I ran into the same kind of thing, but it was almost 3 years ago, and I don't remember what the problem was, but it was either fire or fuel that was missing from the equation. I think I had to clean the carbs something like 6 times, and that was with having drained all fuel from the system before it sat.
                      • CatatonicBug
                        • 6117
                        • Clinton, UT
                        #251
                        I had my front tire replaced at the local shop (took 3 hours, but it was free), and that seems to have solved my front-end bounce problem. Now I need to replace the missing radio knobs in the fairing that fell off because of the bouncing!
                        Also got a new B&N seat cover in the mail yesterday, and got that installed. It's purdy! Only thing is, the new cover has a bit more "tack" to it, and it holds onto my pants. It doesn't let me slide around like I used to. At least now I won't have to worry so much about water soaking into the foam through the splits in the original cover.
                        • Hideki
                          • 85
                          • West Hills, CA
                          #252
                          My used 4-1 pipe came in the mail today, I sand blasted it, and painted it with vht header paint. Also, re-routed my oil cooler lines from in front of the frame to behind (looks 100 times better now) when the paint dries I'll probably install the exhaust today.
                            #253
                            Well, yesterday I sanded, prepped and painted the side covers. Tonight, I'll finish fixing the small dent in the tank (no big deal, but if I'm putting a nice paint job on it, the dent would detract from the job), and depending on how ambitious I'm feeling I might go ahead and paint the tank. Then again I might not, cause the first showing of Iron Man 2 is at midnight, and if SWMBO will allow it, I just may be at the movies tonight.
                            • Crazcnuk
                              • Aug 2006
                              • 2980
                              • Hinton, AB, Canada
                              #254
                              Fired up the '78E today, it was cranky, but once it fired up it ran nice.
                              Got the seat ready to put on, and now i can road test it.
                              It's blowing the usual 'I haven't run in a long time' blue, and I discovered one of thepetcocks is leaking badly.
                              '05 ST1300
                              • WMarshy
                                • Apr 2009
                                • 2402
                                • Mexico NY
                                #255
                                Today, I set out to put new rear pads on my bike. Once I got the caliper off the cylinder wouldnt compress all the way to accomidate the beefy new pads. The old ones had about 0.050" left to them. Well, after I tried compressing it with no luck I knew what to expect when I removed the master cylinder cover. Yep, you guessed it, brown/rusty crap. So, I proceeded to drain the system and clean the MC. As some of you may know this isnt very complicated job, but I made the mistake of draining the MC, lines, and caliper without forcing the caliper piston with the fluid in it. I knew better but decided to try it anyways b/c the piston seemed to move freely. Unfortunately, the piston wouldnt come out, its always that last 1/4". So I sprayed out the caliper with some break cleaner and called it good. Cleaned, reassembled everything and now I have good rear breaks. BTW the sintered pad I put on didnt make a peep. I still have to bleed them just a little more as the pedal isnt as hard as I would like.
                                IS THERE ANY GOOD WAY TO FILL THE REAR MC WITH OUT OVER FILLING IT AND MAKING A MESS???
                                '79 XS11 F
                                Stock except K&N
                                '79 XS11 SF
                                Stock, no title.
                                '84 Chevy K-10 "Big Blue"
