oil use
    • 2004
    Oil threads always seem to evolve like this.
    Just another search on this and I only post this for those reading this thread not to prove I am right or wrong.
    Motorcycle-specific oils utilize ashless polymeric dispersants, primarily polyisobutylene succinimide (PIBSI) and its derivatives, to achieve clutch debris management.
    How They Work
    Unlike standard automotive oils, which focus dispersant chemistry heavily on managing combustion carbon (soot), motorcycle-specific 4T formulations require high-molecular-weight organic polymers. These molecules feature a dual-structure:
    • Polar "Soot-Loving" Head: Bonds physically with the microscopic wet clutch friction dust (fibers and metallic particulates) as it sheds from the plates.
    • Oleophilic "Oil-Loving" Tail: Solubilizes perfectly in the base fluid.
    The dispersants encapsulate the fine clutch debris into microscopic structures called micelles. This prevents the friction dust from agglomerating into heavy sludge or binding to crucial components like clutch spring stacks, holding the debris safely in suspension until it passes through the oil filter.
    Why Car Oils Differ
    Passenger car motor oils (PCMO) lack this specific operational balance. Because cars utilize separate dry clutches, automotive oil chemistry is optimized purely for fuel efficiency and emissions. They rely on friction modifiers (like molybdenum compounds) to make the oil as slippery as possible. In a motorcycle's shared-sump system, automotive friction modifiers will glaze wet clutch plates and cause severe slipping. Motorcycle oils certified under the JASO MA or MA2 standards deliver the necessary high-shear stability and debris dispersion without containing these problematic friction-reducing additives.
    By the way Pete your selection of Yamalube was a good one. I also have to confess I have used Supertech 20w50 in the past. I don't really ride as much these days as I used to so my oil changes intervals are a lot less now so my choice in oil is not that big a deal for me. Of course I can afford whatever oil I want these days. Whether I pay too much or not is also a personal choice.
      • 2057
      Ha ha. The old oil thread trick. Never talk about politics, religion or oil in polite company.
      Friction modifiers? Malarkey. Would only be a factor if you are drag racing. You (we?) are not drag racing. However, if you are driving your bike like that on the street you are an idiot but that is not important right now. I have used car oil for over 40 years in over 60 bikes and I ride to Alaska, Canada and Mexico. I have ridden in every state (except Missouri for some reason). Never had an issue. One of my bikes has 240,000 miles and does not burn a drop of oil. I am a down_to _the_crankshaft mechanic and an intercontinental motorcycle traveler. The industry promotes this crap and the (perhaps some) people who fall for it ride under 10,000 miles a year and consider an oil change "wrenching". They possibly also believe that America is now "great" somehow and will receive a 5 thousand dollar check in the mail real soon.😁
      For what it's worth, I am currently using Shell Rotella in my XS11 sidecar rig. However, that Walmart Supertech oil is fine and I use it in many applications and never had one come back. I love you guys and enjoy our chats together.
      Click image for larger version  Name:	Alaska021.jpg Views:	0 Size:	170.8 KB ID:	891590
        • 2057
        Originally posted by LAB3
        It never fails to amaze me how many people become experts on petro chemicals based solely on their ability to repeat what that pretty girl on the Sunday morning informercial disguised as a motorhead show have to say! How DO you sell oil at $10 per quart unless you can convince someone that it's somehow superior to the stuff that sells for $5! BS, that's how!
        Some may ask "Well then Mr Know it all, what's YOUR experience?" It's pictured below. You know, living in the REAL world. So few people do it these days ...
        LAB3, you live the life. You ride. A lot. You know the truth. It's transportation. It's a motorcycle, not the Space Shuttle.
          • 296
          Good info,,,,agree with all the above,,,these old bikes just keep going with 10/40 or 20l50 or similar oil with no issues, I also have used Walmart cheap blue bottle Super tech in my cars and bikes,,,,plenty high mileage in all, the other parts wore out before any of the engines, with regular oil and filter changes all will last. Ride on XS Riders,,,,,Mike in S.Diego and Pa.
            • 3346
            Good stuff Mike. Nothing like the voice of experience.
            2001 ZRX 1200
            1982 Seca 750
            1983 Nighthawk 550
              • 8927
              I have a feeling they may be blending the super tech with some synthetic mix now, the label says good for 5K instead of the usual 3. I am getting some slip now with a new clutch. The Castrol GTX is being discontinued in 20w-50. You can still find some for now.
                • 2158
                Oh no!
                I've been using that in all my bikes for 46 years.
                  • 3346
                  I've never seen Super Tech saying good for 3,000 mi. Everything's 5000 Mi 10,000 Mi or more depending on which one.
                  2001 ZRX 1200
                  1982 Seca 750
                  1983 Nighthawk 550
                    • 8927
                    I don't think it said any number before, 3 is just the norm. now it says 5.
                      • 8927
                      Oh no!
                      I hope I'm wrong about this, but the 20/50 5qt jug is on clearance for $15, usually 34. I used to use it too, and am going to again.
                        • 2004
                        I haven't seen the Supertech 20w50 in my Walmart for some time now. Was one of the reasons I started looking at alternatives. Seems from doing a quick search on Walmart that they have reformulated it to a synthetic blend. Phils pictures above show the new product and is why it is labeled all mileage and 5000 miles. I guess the next discussion this will bring up is synthetic versus non synthetic in these old bikes of ours. I am putting my popcorn in the microwave now.
                          • 8927
                          Thank you for confirming this Jim. I'm off to stock up on the Castrol GTX before it's all gone.
