ZRX1200 Carb Conversion
    • 3327
    For sure I don't want to be the one to say pilots and it's the mains or say mains and it's pilots. Lol.
    Three turns out of the pilot says that's pretty good for idle, Going up a size in pilots would probably mean two turns out total on the new screw setting more or less.
    If you feel it pulls good up top, try richening up the needle a half position at a time. If you are at three notches down from the top, put a washer under the clip to make it 3.5. Or however you would arrange the clip and washer to get a half position based on your current setting.
    I've discovered two stages to barely cracked throttle according to my wrist and the AFR gauge. Barely barely cracked which is still the pilot system, and then barely cracked past that which starts to bring the needle up out of the main ever so slightly. I tend to spend more time at the second stage of barely cracked throttle and was leaner than I wanted to be. A half position on the needle got it better without richening everything else up too much.
    Thanks for asking for the advice, I hope it gets things richened up.
    2001 ZRX 1200
    1982 Seca 750
    1983 Nighthawk 550
      • 4001
      Here's what I'm thinking: (3) turns out for the Keihins seems too far. So, I'm going to take the pilots out to 42's from 40's. Then, the Main's from 140's to 142's. I think that may be the perfect mix. Ideally, I leave the needles in the middle position.
        • 3327
        That's as good of a plan as any. Three turns out on ZRX (Keihin) carburetors is not too many, IMO. Unless you feel like the screws are going to rattle out so to speak. 2.5-3 turns is a common setup with most aftermarket jet kits running those carburetors on the ZRX.
        Main thing is you want to richen it up, and both of those will accomplish it from opposite ends of the operational spectrum. No harm running a bit rich versus the alternative.
        2001 ZRX 1200
        1982 Seca 750
        1983 Nighthawk 550
          • 4001
          If I remember correctly, anything past 3.5 turns on the mixture screws, and the screws felt loose from lack of thread engagement. So, going up in the pilots will probs help. I have to make a trip to Chicago tomorrow, and Atlanta on Wednesday, so I'll wait for the mains to come before slapping the carbs back on. I ordered two more sets of plugs to test with.
            • 3327
            Looking forward to the next time you can work on it. Thanks for all the updates.
            2001 ZRX 1200
            1982 Seca 750
            1983 Nighthawk 550
              • 8071
              Another twist. To richen less than a jet size, go down a size on the air jet.
                • 4001
                The one jet most of us never touch on these.
                Yet, on my Volkswagen Weber carbs, the air correction jet is the difference between a happy engine & not.
                  • 3327
                  ZRX carburetors don't have adjustable air jets. Air jets are pressed in place.
                  It's a good idea if it was something that could be done.
                  2001 ZRX 1200
                  1982 Seca 750
                  1983 Nighthawk 550
                    • 4001
                    Okay. Put the 142 Mains, and 42 Pilots in. 2 turns out on the mixture screws. Took it for a 5-mile ride. Runs extremely well, pulls strong. I'll pull the ppugs in the morning to see where I'm at for a tune. It would not surprise me if I was still lean.
                    On another note: I still have another oil leak. I heard it when I parked the bike, and saw oil dripping on the exhaust. I'll attempt to find it tomorrow after I pull the plugs. If it's NOT the head gasket, my only guess is the ACCT, but I have that RTV'd with a gasket, so not sure.
                      • 3327
                      Best of luck tracing the oil leak, that's maddening at the least, and will drive you insane in the grand scheme.
                      I've reused head gaskets on the ZRX 1200 a time or two, whatever the copper head gasket spray is that recoats the head gasket, has never let me down. I would trust that more than RTV. RTV works great on valve cover gaskets or base gaskets that don't see much pressure. Head gaskets get a **** ton of pressure, copper head gasket spray is a better option.
                      2001 ZRX 1200
                      1982 Seca 750
                      1983 Nighthawk 550
                        • 2149
                        Click image for larger version  Name:	Gasket Sealer.jpg Views:	0 Size:	174.9 KB ID:	891356
                        Perhaps something like this....
                        I used it on a troublesome oil pan. I was wondering how difficult it would be to remove it if I had to.
                          • 4001
                          Mwahaha. I have definitively traced the leak to the ACCT. So, I'll play around with sealing that up.
                            • 8071
                            I had that problem for years. I finally figured it out and fixed it.
                              • 4001
                              I found the leak! Threads on the plunger were stripped out. Ordered a new v-star ACCT. I'll throw the manual one on there in tbe meantime.
