ZRX1200 Carb Conversion
    • 3297
    Modified airbox that breathes much more with an automotive frame filter. I also have the Chinese 1179 kit.
    The carbs had the original Keihin jets in it. Just the needles were the dynojets.
    Gotcha. Factory pro has a kit for the ZRX that uses the air box with a big ring K&N Filter inside. It jets the same more or less as pods. 130-132 mains, 35 pilots 3-ish turns out as baseline fwiw. ZRX 1200 big bores are 1224 (1164 stock), 1100's are 1109 (1052 stock). Jetting doesn't change for either of the big bores. At least with the ZRX.
    My thought is 140s and 38's are going to be on the large side. But that's the half the fun of being a guinea pig in the newer era of working on older bikes.
    Will be interested to see how she runs.
    2001 ZRX 1200
    1982 Seca 750
    1983 Nighthawk 550
      • 3297
      Once the bike will start and idle, sync the carbs. Mid-range and top end don't matter at that point, gives a consistent baseline to start.
      Then find the main that pulls best at high rpm, once the needle has cleared the main jet.
      Then work with the needle position clip, then back down to the pilot and adjust anything with that.
      2001 ZRX 1200
      1982 Seca 750
      1983 Nighthawk 550
        • 3956
        How do I tune the needle? How will I know to drop the clip or raise it?
        Then, the pilot? I presume too many turns out on the A/F screw equals pilot too small, and vice versa?
          • 3297
          You got it on the pilot, if you go past 3.5 or 4 turns for sure, it needs to be larger. 1.5 or less and go smaller.
          Even if the main jet isn't perfect, the needle clip is what you're tuning for mid-range response, roll on, fuel mileage at cruise.
          It's definitely subjective based on the seat of the pants. If it feels rich, raise the clip to put the needle further into the main jet to lean it out in the mid-range roll on, and cruise conditions. If it feels lean lower the clip on the needle to get more of the needle out of the hole.
          With the AFR gauge on my ZRX and the ZZR 1200 carburetors, a half clip position was worth .5 air fuel ratio either way all else equal, making one change at a time and comparing.
          Fuel mileage can be a great help as well with respect to needle position. If gas mileage is in the high 30s or low 40s, you're probably pretty close. I would expect the more modern ZRX carburetors would get you into the lower 40's on the whole.
          From what I've read in the old thread when this was first done, the performance increase should be noticeable regardless.
          Did you drill the vacuum port? I always understood the vacuum advance on the XS1100 helped with fuel mileage when it pulled in the advance at high vacuum cruise.
          2001 ZRX 1200
          1982 Seca 750
          1983 Nighthawk 550
            • 3956
            Thanks for the walk-thru! And, yes, sir. I drilled per Tad's write-up.
              • 3297
              That's awesome. This is going to be a great revisit of that original conversion.
              2001 ZRX 1200
              1982 Seca 750
              1983 Nighthawk 550
                • 3956
                Okay, a couple things to confirm:
                1. The carbs WILL mount to the OE airbox
                2. The carss will mount to the OE intake manifolds without issue
                3. The carbs take a decent amount of gas to keep the float bowls full Click image for larger version
ID:	890818 Click image for larger version
ID:	890819 Click image for larger version
ID:	890820 Click image for larger version
                  • 3956
                  okay, got it started. I'll have to pull the carbs back off, and put the airbox on to start getting an idle, then swap the plugs to see what's going on with the tune.
                    • 3297
                    I didn't see the alert, bummed I didn't see this post quicker...
                    Good work. Float height for the ZRX carbs is 18.5mm +/- 2mm. Curious what you went with.
                    Sync the carbs as soon as you get the airbox on and idling. Don't expect a steady idle at first, but the sync will help dial that in. As you sync, may need to turn the idle down or up depending on how it responds.
                    Goes without saying, use the first set of plugs for the sync. Go for a ride, see how it feels if it is rideable at all or if it's decent. Make the first round of changes based on how it feels/seat of the pants. I would go for another ride with the first set of plugs, once the second round of change(s) are made. At that point I would put the new plugs in if I was doing it.
                    Last week I took a big swing at the CVK40's on the ZRX 1200. For those that might not have read the whole thread, I adapted those on instead of the stock ZRX carburetors. Did to the ZRX with ZZR 1200 carburetors as this thread is doing with the ZRX stock Carburetors in place of stock XS 1100 carbs.
                    The cruise air fuel ratio would not lean out much even when I leaned the needle clip out. Lean the needle clip enough to help light throttle cruise and then it's lean above that. It's certainly a balancing act.
                    Pilots control fuel flow more than I realized at light throttle cruise. Swapped down to 38 pilots from 40s. Man, what a difference in air fuel ratio. It's in the low 13s to low 14s now, instead of low 12's to high 12's. 12s are where power is made, mid-13s into low 14s are the balance for economy.
                    Hopefully you can flesh those things out by the seat of the pants and the plug reads. I share what I did above as information that might help in your continued work.
                    Heres hoping you've had some time over the weekend to make progress. Look forward to hearing!
                    2001 ZRX 1200
                    1982 Seca 750
                    1983 Nighthawk 550
                      • 3956
                      I'll try to make tire tomorrow. I'll need to pull the carbs and increase the size of the pilots. The Keihin 138's had me at 3.5 turns out, with more needed. I'll bump them up to 140's, and sync the carbs.
                        • 3297
                        138 and 140 are main jet sizes, you're going to increase the main jet size as well? Or were you meaning 38's to 40's on pilots.
                        2001 ZRX 1200
                        1982 Seca 750
                        1983 Nighthawk 550
                          • 3956
                          I mispoke. Yeah, I upped the sizes from Keihin 38's to 40's. I kept the 140 Keihins main jets in. I'm at 2.5 turns out. I have the carbs "synced", but not technically. I synced 1 to 2, and 4-3, but when I attempted to sync 2 to 3, I had a hanging idle. So, I left the two banks unsynced to keep the idle from hanging. I'm letting the engine cool so I can pull the plugs and see where I'm at for fuel mixture. From there, I'll attach the tank and tank it for a spin and see what everything else is doing.
                            • 3297
                            Awesome. Keep those updates coming!
                            2001 ZRX 1200
                            1982 Seca 750
                            1983 Nighthawk 550
                              • 3956
                              Alright: Took it for a quick ride this morning before I get deep into work meetings. Runs well, pulls just as strong in all revs without bogging. Just the same as with the Mikuni's. I'll take it for another quick ride at noon to allow more color to develop on the plugs, then pull the plugs this afternoon to see where it's at.
                              On another note: I was able to free all butterfly screws on the Mikuni's, and will order new seals, despite them all looking okay. I know Len sells them, but they're cheaper through Partzilla. I also think I'm going to order new intake manifold boots from Mikes. I tested them for leaks and did not find any, but I'd rather play it safe.
                              The next issue to deal with that I'm constantly chasing is the clutch: I cannot get it adjusted properly to save my life. New steels and frictions, and my Barnett springs are still in spec. Throwout adjusted per the manual (1/4 turn). When I drop it in gear, it lurches and stalls. I've filed down the basket to ensure the frictions are not grabbing. The only thing I have left in my toolbox to try is adding steel and hoping that helps.
                              Thoughts?
                                • 2140
                                Wouldn't adding a steel make it worse?
