Winter project FINALLY started
    • 7764
    Shifting and shift cover is done! I also put in the new cam chain guides. My plan is the clutch by Tuesday with the cover on. I'll post more pics later.
      • 7764
      Slight detour on the work. Pictures are from the '79 Special I was getting ready to start riding for the year. First ride and it sounded wrong and loud. Checked under the pipes while at idle and felt something under the right side. You can see what happened after only 47 years! Geeze, can someone make a bike that does any better? OH, that's right, nobody does!
ID:	888606 Click image for larger version
        • 7764
        Just need to put it back on! Yes, the welds are NOT nice looking, but it is welding Chromed steel, rust, and carbon. I added a bit of 16 gauge to the bottom for extra strength. The flat black is all I could fine quickly for high temp.
ID:	888610 Click image for larger version
ID:	888611 Click image for larger version
          • 8793
          It's nice to have the skills to be able to do that yourself. Looks good Ray.
            • 7764
            Not sure how it will hold up, but I put some silver paint on so it looks a little better.
            Click image for larger version  Name:	fixed1r.jpg Views:	0 Size:	183.4 KB ID:	888659 Click image for larger version  Name:	Fixed2r.jpg Views:	0 Size:	121.4 KB ID:	888660 Click image for larger version  Name:	Fixed3r.jpg Views:	0 Size:	128.0 KB ID:	888661
            Getting the two old gaskets out of the head was a PITA! But, they are out and new goes in tomorrow. I need to wait for the paint to dry....
              • 2064
              Nice job.
              The paint looks good. Any special type of paint?
                • 7764
                The flat black is high temp paint and the silver is just rattle can, so it may burn off. I was just trying to get it to look good again, even though you probably will not be able to see the weld under the cover. I'll be putting the pipe back on in about two hours, and then warm it up and change oil/filter and check carbs. After that, start riding next week when it get warmer around here.
                  • 1909
                  Ray, I don't know what you have available around you but VHT sells a flame proof silver in rattle can that might hold up a bit better. vht silver paint - Google Search
                    • 7764
                    I just picked up something quick. The black IS VHT, but silver was not available at that store. It's almost all behind the shield, so it's for protection more than looks.
                      • 1807
                      This is great stuff. Holds up to road salt for several years on my Guzzi.
