Winter project FINALLY started
    • 2057
    Originally posted by red bandit
    I've had a few delayed issues with USPS the last year or two. I've had stuff sit in Detroit (more than once) for 3-4 days. Or go back and forth across my state. Or come to my state and go to another state and then back again. Sometimes it should take 3 days and it takes 10.
    I wasn't going to say it, but now that you chimed in. I am still waiting for 2 cans of Spraymax2k from Warren, MI. They were shipped USPS on March 18. They sat in Detroit for 5 days, then went to Grand Rapid and stopped.
    Detroit work ethic is not good.
      • 1770
      If you think USPS is bad now, wait until they start "fixing it".
        • 7755
        Ordered the NLA bearing from a local shop. Different brand, but should be the same. When it gets here in about one week, I'll measure and let everyone know if it will work. Not cheap, about $80 for one double row ball bearing. It IS the main support bearing for the shaft that carries the primary chain and sits behind the clutch basket in the upper case.
          • 7755
          Bearing is here! It looks like the original, double row ball. I need to freeze it to install, as it is a tight fit. That is a good thing, as it has to take a LOT of load. More on the progress Monday evening my time.
            • 7755
            So I got a quote for two sets of Stainless Steel head studs. Please sit down!
            "For us to make you only 24pcs, pricing would be $94.65 per pc."
            If others would want a set, I can try and collect the information and see if I can get the per unit price back into our solar system. Reply here or send me a pm. I think if I could do 120 pcs. I might be able to get the price down to $70 per. I'm going to call and talk with them Wednesday, so I'll let everyone who may be interested know what is going on.
              • 7755
              Well, as I DO want the stainless, I just ordered two sets of studs. It will be a bit before I get them, but the good news is ARP will now have the specs for anyone else who would want to buy them. I've not done much lately, as I'm putting in a replacement air compressor. My 20 gallon is 35 years old, and as of 2005 they put a 20 year service date on ALL compressor tanks. My new unit should be ready to go in about one more week, if I can get up early and into the attic before it reaches 130F. This is about 11:00am local time!
                • 2057
                Good for you.
                We're getting to the stage of life where we should do what we really want because we can't take it with us when we're gone.
                  • 7755
                  So three months later and the package just got to my door. two complete sets of head studs, with shipping, $2,300.27. OUCH! but it is what I wanted so I don't need to worry about rust. I'll have one set on my "new" engine I'm building, plus a spare set. These are ARP studs designed to be stronger than stock units and Stainless Steel on top of that.
                  I have had things here at home that needed my time and even more money, so not sure when I'll be going back to work on the engine. I would like to start next week, but I don't think I'll have the time to do that.
                    • 265
                    that is a few bucks for engine parts,,,,with your patience and aptitude the final result will be crazy good, keep us informed DiverRay, xs projects are all good,,,,Mike in San Diego and Pa
                      • 7755
                      I'm getting a little time, and making S-L-O-W progress. The upper case is almost done now, so I may be able to re-assemble the cases Tuesday or Wednesday. I'm just working on it a little bit, then throw the plastic over it until the next few hours I can manage. I'll post photo's as I put the cases together.
                        • 7755
                        So in and out with the primary shaft! I'm trying to get the gear endplay close. The spacer that was in there is too tight, so I'm trying to make some shims I had from rebuilding kingpins on my '57 Chevy truck work. Photo's show the gear one side then the other. I known not much BUT I want it to last a long time! First photo the gear is close to the starter clutch. Second photo it's farther away. Movement is about 1mm.Click image for larger version
ID:	888372 Click image for larger version
                          • 7755
                          Another step back today! I got the spacing correct, but cut an "O" ring doing it... So a few more days until I try once more. Getting older and not being able to see like I used to sucks!
