Bonz, you mention an oring on the pilot adjustment screw ? I dont have any orings on those screws, never did !
Idle mixture/etc one rich plug
On 78-79 carbs, no O-ring is used, 80-82 carbs use pilot screw O-rings. They have a different type pilot screw.2H7 (79) owned since '89
☮Comment
Lots of good posts and info. You mention "It is better", does that mean the black plug on #1 has been rectified? Have you done a second sync to verify all is good in that regard?
I just finished a major refurb of carbs (and fork seals, steering head bearings, brakes, etc) on a Gen 1 V Max for a friend. The idle was decent after bench sync, then spot on after Carbtune sync. But went downhill after a few rides. The braces that hold the carbs in the racked formation had loosened and were allowing the carbs to move around a bit, causing holy heck with the idle as now the sync was off big time. As an aside, getting those carb braces off between the racks needed an impact driver because they were so stuck after all those years on the bike. I out-thunk myself and put a bit of anti-seize on each screw holding the braces to the carbs on reassembly. Anti-seize also means anti-grip. Every damn screw had loosened up to finger tight lol. Thoroughly cleaned the threaded holes in the carburetors and the screws themselves. Put everything back together and they stayed solid like they should. After a fresh sync, they have stayed where they should.
In any case, are the carbs solid in terms of the braces that rack them together? Just taking a stab at this since it's been such a tough go.
ZRX1200
Seca 750Comment
NGK and new
Bonz, #1 is still rich, float height is proper
I did get a colortune just for fun and machining an adapter to go from the 10mm to 14mm they didnt have anymore when I ordered.
Have not done a second sync, I was hoping to get #1 a little closer, dont know what is causing the overrich condition
Idle still hangs at 2000 then slowly drops to a stall, to me indicating a lean mixture aside from #1Last edited by Mjpcarbon; 08-28-2024, 06:36 AM.Comment
What NGK spark plug? Are you using resistor or non resistor plugs? If your idle is not holding then you either have a vacuum leak somewhere or the jet/jets are not right or good. I had a problem with a set I was rebuilding that no matter what I did I could not set the pilot jet screw properly. Not talking about the pilot jet itself but the pilot jet screw setting. I removed that pilot jet and inspected it closely and didn't seem to have any problems. I ordered a new mikuni jet and replaced it anyway and the problem went away. On these carbs at different rpm ranges different circuits in the carbs come into play. Doesn't sound like you have the bike running good enough yet to actually be out riding the bike bringing the main jet circuit into play yet. When you cleaned the carbs did you replace the butterfly shaft seals? If they have never been replaced they can be a source of a vacuum leak. The carb intake manifolds can also leak where they bolt onto the engine. If there are paper gaskets in use you should remove them clean the surfaces and mount them with a small amount of yamabond. Solves any leak there.NGK and new
Idle still hangs at 2000 then slowly drops to a stall, to me indicating a lean mixture aside from #12 - 80 LGs bought one new
JimComment
Genuine Yamaha....
https://www.partshark.com/oemparts/p...0/-screw-pilot
This is for the screw only, the spring is a separate part #.
Beware of the cheap Chinese ones, the threads are sometimes the wrong size.Last edited by bikerphil; 08-28-2024, 08:24 PM.2H7 (79) owned since '89
☮Comment
If you have that hole on your carbs that Deebs pointed out then I am now confused about which carbs you actually have. On the earlier carbs there is no hole there. Any way you can post a picture or two of the carbs you have?2 - 80 LGs bought one new
JimComment
