Running rich
Motoman, can you clarify what you mean by the pilot circuit is "maxed" out? On the last page he says the screws are only turned out 1.25 turns.
In my understanding, at full throttle and large throttle openings when vacuum is low, the pilot circuit is contributing less relative to idle, steady-state cruise and small throttle openings where there is high vacuum.
To the OP, are the slide diaphragms in good condition and seated properly under the carb tops when you screw them down? I'm reaching for stuff now. It may have already been talked about but it's been seven pages!
2001 ZRX 1200
1982 Seca 750
1983 Nighthawk 550Comment
Yes the diaphragms are perfect. No light shines through and fluid doesn't eitherMotoman, can you clarify what you mean by the pilot circuit is "maxed" out? On the last page he says the screws are only turned out 1.25 turns.
80 SGComment
Flow rate, because of jet orfice size is then at maximan flow(approx. 3,000rpm), therefore more fuel is fed as rpms increase thru the larger main jet circuit. Pilot jet screws out to whatever just dictates fuel/air ratio.Motoman, can you clarify what you mean by the pilot circuit is "maxed" out? On the last page he says the screws are only turned out 1.25 turns.
81H Venturer1100 "The Bentley" (on steroids) 97 Yamaha YZ250(age reducer) 92 Honda ST1100 "Twisty"(touring rocket) Age is relative to the number of seconds counted 'airing' out an 85ft. table-top.Comment
Bring it
up to my place and I'll have a look at it. I'm in Frankford. My number is in my signature.mack
79 XS 1100 SF Special
HERMES
original owner
81 XS 1100 LH MNS
SPICA
78 XS 11E
IOTA
https://youtu.be/wB5Jfbp6SUc
https://youtu.be/RaI3WYHSuWA
Frankford, Ont, Canada
613-398-6186Comment
Well the number one carb is leaking from it. Just started after I cleaned the carbs yet again lol. With still no change in how it runs lol80 SGComment
Mount the carbs with a C clamp on a 2X8 so they are upright. Pull the bowls and use a long ziptie to keep the floats in the closed position. One side at a time, put a fuel line from a remote tank ABOVE the carbs and allow the fuel to flow. Look to see if it IS flowing, as it should NOT. You may find a leak around the "O" ring that seals the seat for the needle, or you may find a crack in the casting causing the problems.Ray Matteis
Well, for starters, you seriously need to check those float levels....specially #1
. Fuel levels in bowls are to high, and likely attribute majority of issues your having. Float setting is 23mm for those carbs.
Last edited by motoman; 06-01-2017, 04:40 PM.81H Venturer1100 "The Bentley" (on steroids) 97 Yamaha YZ250(age reducer) 92 Honda ST1100 "Twisty"(touring rocket) Age is relative to the number of seconds counted 'airing' out an 85ft. table-top.Comment
The red arrow in post 128 is the air jet for the main jet. The bowl vents are the two top holes in the bell, left & right. I don't know how you can tell the fuel level in the bowls. There is no tubing connected to the bowls. The tubes are from the petcocks. I don't know where the tube on the left of petcock is from???79 F full cruiser, stainless brake lines, spade fuses, Accel coils, modded air box, 750 FD.
79 SF parts bike.Comment
If have seen corrosion along the float pin to where it it dosn't allow propper movement of the float.
I have also seen sticky float needles in the valve.
Too much bending of the float tange can make it at such an angle with the needle valve that it may malfunction.
Float bowl gaskets can interfere by rubbing on the float bulb(s).
The seals around the needle valve seat can crach/split/leak.
Improper float height.
If someone has installed non-stock needles or other parts, it is recommended that the manometer method be used for float height, although it seems that your problem is due to something else as listed above. You have a free-flowing float valve for some reason...Skids (Sid Hansen)
Will try that.Mount the carbs with a C clamp on a 2X8 so they are upright. Pull the bowls and use a long ziptie to keep the floats in the closed position. One side at a time, put a fuel line from a remote tank ABOVE the carbs and allow the fuel to flow. Look to see if it IS flowing, as it should NOT. You may find a leak around the "O" ring that seals the seat for the needle, or you may find a crack in the casting causing the problems.80 SGComment
