Running rich
    Originally posted by skids
    I think at 4000 and above, you are not using the pilot circuit much, including the mixture screws and pilot jets. I wonder if when you were fiddling with the choke, you were momentarily off the throttle allowing the bowls to catch-up with gas. Have you tried running without the vacuum operated fuel controller? If not, try running on prime.
    Correction skids......pilot circuit is MAXED out.
      • 3293
      Motoman, can you clarify what you mean by the pilot circuit is "maxed" out? On the last page he says the screws are only turned out 1.25 turns.
      In my understanding, at full throttle and large throttle openings when vacuum is low, the pilot circuit is contributing less relative to idle, steady-state cruise and small throttle openings where there is high vacuum.
      To the OP, are the slide diaphragms in good condition and seated properly under the carb tops when you screw them down? I'm reaching for stuff now. It may have already been talked about but it's been seven pages!
      2001 ZRX 1200
      1982 Seca 750
      1983 Nighthawk 550
      • BLOWCLVL
        • Apr 2017
        • 73
        • Trenton, Ontario, Canada
        #123
        Yes the diaphragms are perfect. No light shines through and fluid doesn't either
        80 SG
          • 3293
          Good deal!
          2001 ZRX 1200
          1982 Seca 750
          1983 Nighthawk 550
            Flow rate, because of jet orfice size is then at maximan flow(approx. 3,000rpm), therefore more fuel is fed as rpms increase thru the larger main jet circuit. Pilot jet screws out to whatever just dictates fuel/air ratio.
            • mack
              • 2411
              • Ontario, Canada
              #126
              Bring it
              up to my place and I'll have a look at it. I'm in Frankford. My number is in my signature.
              mack
              79 XS 1100 SF Special
              HERMES
              original owner
              81 XS 1100 LH MNS
              SPICA
              78 XS 11E
              IOTA
              https://youtu.be/wB5Jfbp6SUc
              https://youtu.be/RaI3WYHSuWA
              Frankford, Ont, Canada
              613-398-6186
              • BLOWCLVL
                • Apr 2017
                • 73
                #127
                Sounds good. I'll see when I can up.
                80 SG
                • BLOWCLVL
                  • Apr 2017
                  • 73
                  #128
                  Ok. What is this hole on the inlet side of the carb?
                  80 SG
                    • 7818
                    That should be the vent for the float chamber. IF it's not open, you have problems! Can be flooding or running lean, but usually flooding.
                    • BLOWCLVL
                      • Apr 2017
                      • 73
                      #130
                      Well the number one carb is leaking from it. Just started after I cleaned the carbs yet again lol. With still no change in how it runs lol
                      80 SG
                        • 7818
                        Mount the carbs with a C clamp on a 2X8 so they are upright. Pull the bowls and use a long ziptie to keep the floats in the closed position. One side at a time, put a fuel line from a remote tank ABOVE the carbs and allow the fuel to flow. Look to see if it IS flowing, as it should NOT. You may find a leak around the "O" ring that seals the seat for the needle, or you may find a crack in the casting causing the problems.
                          Well, for starters, you seriously need to check those float levels....specially #1. Fuel levels in bowls are to high, and likely attribute majority of issues your having. Float setting is 23mm for those carbs.
                          • red bandit
                            • 970
                            • central michigan
                            #133
                            The red arrow in post 128 is the air jet for the main jet. The bowl vents are the two top holes in the bell, left & right. I don't know how you can tell the fuel level in the bowls. There is no tubing connected to the bowls. The tubes are from the petcocks. I don't know where the tube on the left of petcock is from???
                            79 SF parts bike.
                              • 5073
                              #134
                              If have seen corrosion along the float pin to where it it dosn't allow propper movement of the float.
                              I have also seen sticky float needles in the valve.
                              Too much bending of the float tange can make it at such an angle with the needle valve that it may malfunction.
                              Float bowl gaskets can interfere by rubbing on the float bulb(s).
                              The seals around the needle valve seat can crach/split/leak.
                              Improper float height.
                              If someone has installed non-stock needles or other parts, it is recommended that the manometer method be used for float height, although it seems that your problem is due to something else as listed above. You have a free-flowing float valve for some reason...
                              • BLOWCLVL
                                • Apr 2017
                                • 73
                                #135
                                Will try that.
                                80 SG
