Running rich
  • BLOWCLVL
    • Apr 2017
    • 73
    • Trenton, Ontario, Canada
    #106
    What spark plugs are you all running?
    80 SG
    • BLOWCLVL
      • Apr 2017
      • 73
      #107
      Just wondering as I have NGK BPR7ES in there right now?
      80 SG
        BP6ES is the correct plug, the ones you have are a step colder, shouldn't really make that much difference.
        • BLOWCLVL
          • Apr 2017
          • 73
          #109
          That's what I figured. Just trying to find other options with the issue
          80 SG
          • BLOWCLVL
            • Apr 2017
            • 73
            #110
            Oh another clue maybe to the issue. The left exhaust pipe is much hotter to the touch than the right after I come back from a ride.
            80 SG
            • BLOWCLVL
              • Apr 2017
              • 73
              #111
              ok so I decide to check my coil resistance and according to http://www.xs11.com/forum/showthread.php?t=583 I should have 1.5 oms on the primary side and I do. The secondary side (spark plug side) says I should have 15k oms. One coil has 25k oms the other is at 25m ohms. Could this be the issue or am I not doing it right.
              80 SG
                #112
                The manual isn't terribly clear, the 15K value for the secondaries is with the plug caps OFF, just measuring bare wire to bare wire. The caps will probably have ~5k ohms ea, and so if they do, then it adds up....5+5+15=~25Kohms.
                • BLOWCLVL
                  • Apr 2017
                  • 73
                  #113
                  Yep you are right. Rechecked without the caps and much closer to the 15k oms.
                  80 SG
                  • BLOWCLVL
                    • Apr 2017
                    • 73
                    #114
                    Now the weird thing. I decided to put the 105 mains in and the 45 pilots. My slide needles are set to the middle and my mixture screws are 1 and 1/4 turns out. Took the bike for a ride and runs with same issues. once I get to 4000 rpm it backfires like mad and doesn't go anymore. I reach down pull the choke to see if it helps and it does not. Put the choke back in and 2 seconds later I whack the throttle and the bitch climbs all the way up to 7000 rpm and does not hesitate for the rest of my ride. Turn off the bike have a coffee and its back to its old self again until I repeat the process with the choke. So tell me what causes that.
                    80 SG
                      It sounds like the enricher circuit (choke) is dumping excessive fuel into the mix which you compensated for with smaller jets. When the enricher is opened and then closed. it temporarily closes off the additional fuel and allows for a leaner mixture. May want to take them apart and inspect.
                        #116
                        I think at 4000 and above, you are not using the pilot circuit much, including the mixture screws and pilot jets. I wonder if when you were fiddling with the choke, you were momentarily off the throttle allowing the bowls to catch-up with gas. Have you tried running without the vacuum operated fuel controller? If not, try running on prime.
                        • BLOWCLVL
                          • Apr 2017
                          • 73
                          #117
                          I had it wide open when I flicked the choke on and off.
                          I have tried running in prime no change. Have not tried running with the vacuum line off the controller.
                          80 SG
                          • donebysunday
                            • Oct 2012
                            • 1737
                            • New Berlin, Wi.
                            #118
                            Resistance
                            is futile !
                            You have the resister plugs there and your running resister plug caps so you are doubling the resistance
                            76 XS650 C ROADSTER
                            80 XS650 G Special II
                            https://ibb.co/album/icbGgF
                            80 XS 1100 SG
                            81 XS 1100LH/SH DARKHORSE
                            https://tinyurl.com/k6nzvtw
                            AKA; Don'e, UD, Unca Don'e
                              #119
                              Wow! If it is repeatable with the choke, you are definately onto something, but I'll be damned if I can figure out the interaction. It would seem to eliminate electrical issues from ignition. I just wonder of the levels in the bowls are still too low and with that boost of gas from the choke, the engine pulls enough air velocity to lift the main needles. I know I am not explaining this very well...
                              • BLOWCLVL
                                • Apr 2017
                                • 73
                                #120
                                LOL confusing I know.
                                80 SG
