Broke down and towed back home
2H9 Mod, Truck-Lite LED Headlight, TECHNA-FIT S/S Brake Lines, Rear Air Shocks, TKAT Fork Brace, Dyna DC-I Coils, TC Fuse Block, Barnett HD Clutch Springs, Superbike Handlebars, V-Star 650 ACCT, NGK Irridium Plugs, OEM Exhaust. CNC-Cut 2nd Gear Dogs; Ported/Milled Head; Modded Airbox: 8x8 Wix Panel Filter; #137.5 Main Jet, Viper Yellow Paint, Michelin Pilot Activ F/R, Interstate AGM Battery, 14MM MC, Maier Fairing, Cree LED Fog Lights. -
2H9 Mod, Truck-Lite LED Headlight, TECHNA-FIT S/S Brake Lines, Rear Air Shocks, TKAT Fork Brace, Dyna DC-I Coils, TC Fuse Block, Barnett HD Clutch Springs, Superbike Handlebars, V-Star 650 ACCT, NGK Irridium Plugs, OEM Exhaust. CNC-Cut 2nd Gear Dogs; Ported/Milled Head; Modded Airbox: 8x8 Wix Panel Filter; #137.5 Main Jet, Viper Yellow Paint, Michelin Pilot Activ F/R, Interstate AGM Battery, 14MM MC, Maier Fairing, Cree LED Fog Lights.Comment
I've been running 3 ohm coils with the resistor removed and bypassed in my 79F since 2007. The TCI is fine and with the 30KV Dyna DC1-1 coils I get better cold starts and much better throttle response.True, cept for his sig. says it's a 79model, which uses 1.5ohm coils. Even bypassing the ballast resistor(as Grg stated) when using 3ohm coils, will create an issue with TCI module used on the 78-79 model bikes. Not bypassing the ballast resistor and using 1.5ohm coils IS the correct option for 78-79 model yr. XS1100's
.I think I have a loose screw behind the handlebars.
Knew that would get a rise of you and Ian
.......whatever is working for you folks,.......just was stating what internally can happen with the 2H7 TCI as opposed to the one year used(1981) 4RO TCI if done incorrectly
81H Venturer1100 "The Bentley" (on steroids) 97 Yamaha YZ250(age reducer) 92 Honda ST1100 "Twisty"(touring rocket) Age is relative to the number of seconds counted 'airing' out an 85ft. table-top.Comment
I don't doubt for a minute that it could cause problems if you ran the 3 ohm coils on a 2H7 if you didn't bypass the resistor.I think I have a loose screw behind the handlebars.
So after going through my bike and giving up a milkion times i took the bike to a retired yamaha mechanic. took him a couple hours to figure it out.
The screw that holds the stator had worked its way out from the vibrations. It caused all types of timing issues and thats why the bike would not start.
welp! At least i got some. rand new coils now lol. Right on time for riding season at least.79 SFComment
The governor bolt, or one of the three bolts that holds the stator to the stator cover? Not sure how the governor bolt would come loose, and the stator bolts that hold it to the cover would just cause the stator to rub on the cover, which would def cause some charging issues. But, timing issues I don't think . . .So after going through my bike and giving up a milkion times i took the bike to a retired yamaha mechanic. took him a couple hours to figure it out.
welp! At least i got some. rand new coils now lol. Right on time for riding season at least.1979 XS1100F
That Jardine spaghetti exhaust looks good.1979 XS1100F
Jk.
