Originally posted by motoman
View Post
Broke down and towed back home
Originally posted by dbeardslee View PostThrowing parts at a problem before you know what the problem really is is a good way to waste money on new parts that may not fix the problem. My $.021979 XS1100F
Originally posted by motoman View PostTrue, cept for his sig. says it's a 79model, which uses 1.5ohm coils. Even bypassing the ballast resistor(as Grg stated) when using 3ohm coils, will create an issue with TCI module used on the 78-79 model bikes. Not bypassing the ballast resistor and using 1.5ohm coils IS the correct option for 78-79 model yr. XS1100's.I think I have a loose screw behind the handlebars.
Originally posted by dbeardslee View PostI've been running 3 ohm coils with the resistor removed and bypassed in my 79F since 2007. The TCI is fine and with the 30KV Dyna DC1-1 coils I get better cold starts and much better throttle response.81H Venturer1100 "The Bentley" (on steroids) 97 Yamaha YZ250(age reducer) 92 Honda ST1100 "Twisty"(touring rocket) Age is relative to the number of seconds counted 'airing' out an 85ft. table-top.
Originally posted by motoman View PostKnew that would get a rise of you and Ian.......whatever is working for you folks,.......just was stating what internally can happen with the 2H7 TCI as opposed to the one year used(1981) 4RO TCI if done incorrectly.I think I have a loose screw behind the handlebars.
So after going through my bike and giving up a milkion times i took the bike to a retired yamaha mechanic. took him a couple hours to figure it out.
The screw that holds the stator had worked its way out from the vibrations. It caused all types of timing issues and thats why the bike would not start.
welp! At least i got some. rand new coils now lol. Right on time for riding season at least.79 SF
Originally posted by adelii View PostSo after going through my bike and giving up a milkion times i took the bike to a retired yamaha mechanic. took him a couple hours to figure it out.
welp! At least i got some. rand new coils now lol. Right on time for riding season at least.1979 XS1100F
Originally posted by adelii View Postfrom what the mechanic told me, it was switched from the vacuum operated one to the digital one. He said it was loose because if the bolt innthe middle?
all i know is that its running.1979 XS1100F
That Jardine spaghetti exhaust looks good.1979 XS1100F
