Broke down and towed back home
    • 3956
    Originally posted by motoman
    True, cept for his sig. says it's a 79model, which uses 1.5ohm coils. Even bypassing the ballast resistor(as Grg stated) when using 3ohm coils, will create an issue with TCI module used on the 78-79 model bikes. Not bypassing the ballast resistor and using 1.5ohm coils IS the correct option for 78-79 model yr. XS1100's.
    Wait, what? The ballast resistor is 1.5 ohms. The reason you bypass the ballast resistor when using the 3 ohm coils is because it's too much resistance. I have Dyna DC-1 3 ohm coils, with the ballast reaistor bypassed.
      • 3956
      Throwing parts at a problem before you know what the problem really is is a good way to waste money on new parts that may not fix the problem. My $.02
      Why not? That what dealerships do to troubleshoot Jk.
      • dbeardslee
        • Nov 2007
        • 4385
        • Maineville, OH
        #48
        I've been running 3 ohm coils with the resistor removed and bypassed in my 79F since 2007. The TCI is fine and with the 30KV Dyna DC1-1 coils I get better cold starts and much better throttle response.
          Knew that would get a rise of you and Ian.......whatever is working for you folks,.......just was stating what internally can happen with the 2H7 TCI as opposed to the one year used(1981) 4RO TCI if done incorrectly.
          • dbeardslee
            • Nov 2007
            • 4385
            • Maineville, OH
            #50
            I don't doubt for a minute that it could cause problems if you ran the 3 ohm coils on a 2H7 if you didn't bypass the resistor.
            • adelii
              • Jun 2015
              • 94
              • Tuscon, AZ.
              #51
              So after going through my bike and giving up a milkion times i took the bike to a retired yamaha mechanic. took him a couple hours to figure it out.
              The screw that holds the stator had worked its way out from the vibrations. It caused all types of timing issues and thats why the bike would not start.
              welp! At least i got some. rand new coils now lol. Right on time for riding season at least.
              79 SF
                • 3956
                The governor bolt, or one of the three bolts that holds the stator to the stator cover? Not sure how the governor bolt would come loose, and the stator bolts that hold it to the cover would just cause the stator to rub on the cover, which would def cause some charging issues. But, timing issues I don't think . . .
                • adelii
                  • Jun 2015
                  • 94
                  • Tuscon, AZ.
                  #53
                  from what the mechanic told me, it was switched from the vacuum operated one to the digital one. He said it was loose because if the bolt innthe middle?
                  all i know is that its running.
                  79 SF
                    • 3956
                    Ahh, the advance. That makes sense. I was gonna say . . .
                    • adelii
                      • Jun 2015
                      • 94
                      • Tuscon, AZ.
                      #55
                      Its back and it feels so good! Been takin her everywhere recently. Fixed all kinds of issues while it was at mechanic.
                      79 SF
                      • adelii
                        • Jun 2015
                        • 94
                        • Tuscon, AZ.
                        #56
                        79 SF
                          • 3956
                          That Jardine spaghetti exhaust looks good.
                          • adelii
                            • Jun 2015
                            • 94
                            • Tuscon, AZ.
                            #58
                            Thanks, sounds pretty good too. especially after 5k rpms
                            79 SF
                            • dbbrian
                              • May 2016
                              • 596
                              • Stratford, Ontario, Canada
                              #59
                              looking good
                              I really like how that bike looks with the choice of bars, seat, and that exhaust!
                              • adelii
                                • Jun 2015
                                • 94
                                • Tuscon, AZ.
                                #60
                                Thanks! Im really digging it too.
                                79 SF
