Tim,
That small "pipe" is for the enriching circuit. Allows fuel to be pulled up for choke. Make sure it's very clean. I had an awful time getting the port in the bowl(s) cleaned where that pipe slides into with the last set I purchased. You should be able to squirt carb cleaner into the port inside the bottom of the bowls and it will eject out the hole where that "pipe" will reside. Son of a gun to get 'em nice & clean if they get gummed up. I had to use a single strand of fine wire to poke through and loosen the goo.
Kurt
Kurt
