New member
    • 1262
    • Peachtree City, Georgia.
    Originally posted by timktm
    That hole is for the small pipe that goes up into the bowl, what does it do anyway?
    Tim,
    That small "pipe" is for the enriching circuit. Allows fuel to be pulled up for choke. Make sure it's very clean. I had an awful time getting the port in the bowl(s) cleaned where that pipe slides into with the last set I purchased. You should be able to squirt carb cleaner into the port inside the bottom of the bowls and it will eject out the hole where that "pipe" will reside. Son of a gun to get 'em nice & clean if they get gummed up. I had to use a single strand of fine wire to poke through and loosen the goo.
    Kurt
    1982 - CBX1000 - Honda
      Oh, and I spent over 45 minutes looking for the washer that goes on the bottom of the needle. I dropped it and heard it hit the floor, man I hate when that happens.
      I just spent a half hour looking for a dropped carb screw on Saturday, so I am laughing. Once I lost one of the carb choke detent balls and found it in a far corner of the garage, hours later. Happens to me far too often- think I would learn...
      Here is a pic of the bowl gasket I got from Mikes. The one hole doesn't line up. Would it be OK if I opened the hole a bit or no?
      I bought the same gaskets once. Never got around to retuning them with a complaint. I tried to open that hole it with a drill bit, and it came out all ragged and fuzzed. I decided to put them aside instead of using them. It would be OK if you could trim the hole with an Exacto-Knife instead. You can see that part of the carb body is an open channel anyway, so you will not lose any sealing surface if you just open it up where you need it.
        __________________
        '79 XS1100SF 16k miles
        '80 XS1100SG 39k miles
        '79 XS750SF 12k miles
        '79 XS750SF 20k miles
        A forsner bit will make those a perfect hole without the ragged edges.
          I'll try that again Mike.........a forsner bit will make that a ferfect hole without the ragged edges, using a small block of wood for a back-up.
            Maybe
            Brant: Worth a try- I do have Forstner bits, not sure I have one that small.
              Even better yet, a small hole punch like one used on a piece of leather.
                I tried a piece of 1/8" copper tubing that was sharp from the pipe cutter tool. It was too soft. A 'harderer' tube would work.
                A leather punch would be ideal if I had one. Good idea.
                  So I got the carbs all torn down again, last time I'm hoping! Found one float was leaking, repaired that one. Found it interesting two of the floats # 1, # 2, the outside of the floats were actually concave compared to #3 and #4, which were convex. Should I be concerned? Also, the needle jets, #1,4 are 301 X-2. #2,3 are 266 X-2. I take it this is by design due to the cylinders being inboard? The needles are all the same, 5GZ6, third position from top(middle position). Main, jets are 137.5 and pilot is 42.5, 180 starter?
                  I performed the bench sync thanks to the article on here. Oh, and I spent over 45 minutes looking for the washer that goes on the bottom of the needle. I dropped it and heard it hit the floor, man I hate when that happens.
                  Here is a pic of the bowl gasket I got from Mikes. The one hole doesn't line up. Would it be OK if I opened the hole a bit or no? That hole is for the small pipe that goes up into the bowl, what does it do anyway? Any thoughts on Mikes carb needle and seat sets?
                  Thanks,
                  Tim
                  A small leather type punch IS your best bet to open up that hole a bit.
                  • rdmcguy
                    • Jul 2013
                    • 515
                    • Denver, Colo.
                    Little holes
                    I had the same issue with motion pro gaskets ..
                    I went to Office depot and found hole punchers of assorted sizes , Tiny one for carb gaskets and larger for sidecase (5 mm)screws Think I spent a whole ten bucks !
                    • timktm
                      • Dec 2015
                      • 169
                      • Ohio
                      I ended up just trimming with a razor blade. The enrichener cleaned up no problem in the bowl.
                      Working on routing the fuel lines, oh joy! Still waiting on petcock screens and petcock gaskets. Got the carb buttoned up and mounted.
                      One weird thing with the wiring I have to look into is the front brake light works even without the key on?
                      1979 xs1100sf black.
                      1973 Harley fx.
                      2005 Honda 450x.
                        Front brake light?
                        You mean the brake light comes on when you pull the front brake lever? If that's so the switch wire is plugged into the wrong spot inside the headlight bucket.
                        • timktm
                          • Dec 2015
                          • 169
                          • Ohio
                          Yes, front brake.
                          1973 Harley fx.
                          2005 Honda 450x.
                            I edited my post.
                            • timktm
                              • Dec 2015
                              • 169
                              • Ohio
                              Lol, I got ya. Will look into that.
                              1973 Harley fx.
                              2005 Honda 450x.
                                If ya' got a bench grinder with a fairly fine wheel, rotating the brass tubing, grinding a taper to its sharp inner edge will work also.
