New member
  • timktm
    • Dec 2015
    • 169
    • Ohio
    Well, couldn't figure out the brake light. Maybe when I rewired the fuse block I messed it up. Wiring diagram isn't that clear to me. Oh well for another day.
    1979 xs1100sf black.
    1973 Harley fx.
    2005 Honda 450x.
      Uuh..........Three-Phase post one for both later(80 and later) and 79 and earlier in color some 3yrs. back. Maybe T.C. or soeone would be able to locate those pics for ya'. Enlarge those pics, and it makes following the wiring childs play.
        If you screwed up the fuse panel wiring the brake light would do the same with BOTH brakes.
        You're just plugged into the wrong wire up there. It really doesn't matter though unless it just bothers you. As long as it works.
        The light only comes on when the brake is applied.
        • timktm
          • Dec 2015
          • 169
          • Ohio
          #34
          Right, it just bothers me. I checked the way it's plugged in and seams fine,so might just worry about getting her running.
          Tim
          1973 Harley fx.
          2005 Honda 450x.
          • timktm
            • Dec 2015
            • 169
            • Ohio
            #35
            Hopefully done cleaning the gas tank today. Bought a box of little screws and shook them around vigorously without gas and with. Ran an inspection camera down in it and looks pretty good. Might do that process once more. This after a week of electrolysis, shaking nuts around in, hot soapy water etc. Getting tired of the smell of gas to tell you the truth. Made a replacement rubber grommet for the rear brake too. More to come.
            Tim
            1973 Harley fx.
            2005 Honda 450x.
            • puskrat
              • Jun 2015
              • 312
              • Peoria IL
              #36
              Tim you've come to the right place. These characters have more to offer than you can imagine, to help get you started and keep going in the right direction.
              "Venturered" 80 XS1100G - "DoraMax" getting sort of resto/destro ed.
              Yeah it's a pretty blue, but just because you're old is no excuse to buy a bagger. Fortunately I have wrenches.
              • mikubuilder
                • Jul 2011
                • 548
                • Westland, Mich.
                #37
                Welcome to the madness....
                a few posts down you've mentioned something about your floats being concave, and some being convex...there is a good possibility that they are damaged and do not float anymore possibly have a pinhole leak...a good way to check those(brass ones) is to drop them into boiling water and look for bubbles coming out of any holes in them. Safer bet would be to buy new or old stock plastic ones, but make sure when setting them use newer specs.
                Nick
                1982 Virago 750 (it's alive!)
                • timktm
                  • Dec 2015
                  • 169
                  • Ohio
                  #38
                  I checked the floats and one did leak, I repaired it, it wasn't a concave one. They all floated and I adjusted them. I will know if they work in a week or two when I get it back together.
                  1973 Harley fx.
                  2005 Honda 450x.
                    #39
                    Hey Tim,
                    I meant to comment earlier about your caved in floats, but forgot!
                    Others have stated that they got concave floats after they applied compressed air into their carb bodies before disassembling them...so the air pressure built up inside the float bowl and compressed the floats. Because they now take up less volume, they will not set right with the stock setting. You can try to apply some vacuum to them to try to get them to expand back out to their normal volumic state, but if that doesn't work, then as stated, replace them or you'll have hell trying to get them to set the fuel level correctly!
                    • timktm
                      • Dec 2015
                      • 169
                      • Ohio
                      #40
                      Darn,
                      Wish you would have said something before I put them back on. I figured they were ok since I didn't get any responses. I was wondering if they they were going to float correctly. Got a good source for floats? I'm still going to try and fire it before I take them off again.
                      Tim
                      1973 Harley fx.
                      2005 Honda 450x.
                        • 2104
                        Also, along with the inaccuracy of the concaved floats, the "fix" on the leaking float will be a different weight than the stock floats.
                        Here's a link for floats:
                        http://www.mikesxs.net/products-35.html#products
                        • timktm
                          • Dec 2015
                          • 169
                          • Ohio
                          #42
                          Wow, I had no idea they are that sensitive. Anyone have any good usable floats they would like to sell or donate to the cause? Are the plastic the way to go if I do buy new ones?
                          Tim
                          1973 Harley fx.
                          2005 Honda 450x.
                            Tim
                            Nope, have to stay with the OEM brass ones, setting purposes and pick-up tube purposes on the early carbs.
                              Wrong part Schming......
                              http://www.mikesxs.net/parts/yamaha-...0-537-14186-00
                                • 2104
                                Wasn't sure if he was goin' with the plastic floats or the brass so I gave him the whole list
