Hey Kurt,
To test the 2nd gear, you'll need to be able to get on the throttle fairly strongly.....the dogs/slots will pull apart under throttle stress and then they spin past each other and then slam back together, so you get this skipping effect.
The charging system doesn't kick in until around 2500 rpm, so yeah, with a weak battery it can be hard keeping the bike running at idle...dropped voltage levels drop spark energy and you can get the eventual ignition failure to where the engine dies.
Yes...we often warn new members to really hang on lest they get their arms yanked out by the sockets when they crank the throttle!
Fuseblock asembly looks great (Even though you didn't use the one I resell).
has been replaced with the proper Yamaha unit. Unmolested fork ears and proper turn signal mounts have also been installed.
I'm gonna grab one of those sets! We're gonna cut 'em apart and fabricate a nice set for the XS11 using the pieces. We should be able to modify the collectors and pipes to make a really nice, interesting and functional unit for pennies compared to the retail cost of the few sets of new that are still being sold and a mere fraction of a good used XS11 set. I'll keep you posted of my progress on this......
) I put it back together so I could move it around or maybe make a trip around the block but a "Real Ride" is absolutely out of the question! There's too much work to do before anything other than a spin around the block would be considered.... I think I'm back to a 5/16/16 target for full operational ability (one year from initial purchase and my birthday).
