a couple carb questions
it'll work.......until you use the carbs
. Plasti-dip WILL also come loose....DAHIK.
I did find one thing that works though....kinda pricey just for this use though.
Automotive paint stores sell the professional fix for composite bumper repair, ect.(would even work for damaged fairing lowers with fractures).
It's two part(one time use applicator is mixing chamber) product comes out a tube(s) similar to a two part exoxy syringe, thru mixing chamber, to application......you got 30sec. for 'set' time! As strong as or stronger than base material.
I kinda 'waisted' one of the applicator/mixing chambers to test if it would work, as I only needed tiny 'dobs' in the eight wear locations of the diaphrams.
Seems to have worked perfectly as I've had carbs apart since more than I would like to admit
. Seems to also have given those points a wearing surface, so looks like it will last the duration of my riding yrs. I did this 'fix' 4-5yrs. ago.
Remove the metering rod and bring slide(s) with you, and I'll fix them for ya'....... also,still holding your camp spot
Last edited by motoman; 01-21-2015, 03:46 PM.81H Venturer1100 "The Bentley" (on steroids) 97 Yamaha YZ250(age reducer) 92 Honda ST1100 "Twisty"(touring rocket) Age is relative to the number of seconds counted 'airing' out an 85ft. table-top.Comment
Carburetors
You should ALWAYS check/adjust the float levels. It is a very good idea to hook up a fuel source to the carburetors BEFORE you reinstall them. Check for leaks now rather than after they are back on the bike. Tilt them to simulate the bike being on the side stand.Sure hope I'm not the only dummy that can tend to put the carb covers back on...forgetting to put the big spring back in!
Any lubrication to be done, such as choke or throttle linkages?
I didn't check/adjust float levels. Again because it runs well so I just put everything back as it was, just a little cleaner inside and outside.1981 XS1100H Venturer
K&N Air Filter
ACCT
Custom Paint by Deitz
Geezer Rectifier/Regulator
Stebel Nautilus Horn
EBC Front Rotors
Limie Accent Moves On In 2015
MikeComment
Suppose I should do a search for the step by step of float adjustment, once again never having done it. Factory manual doesn't have much to say about it. Why would it be necessary if the floats were not removed?
Looking forward to that camp spot Brant. Sure hope it works out.80 SG
81 SH in parts
99 ST1100
91 ST1100Comment
For diaphragm pin holes get some liquid electrical tape. CZ introduced me to this with the 80G I fixed up.
I sold the bike, but in think he has bikes that have been on the road a good while with that fix.Howard
2001 ZRX 1200
1982 Seca 750
1983 Nighthawk 550Comment
Float Adjustment
You do not know if they are adjusted properly unless you check them. If they are adjusted incorrectly, the bike can run lean or rich. With carbs off and apart there is no good reason NOT to check them. Search the forum and you will find adjustment procedures/details to set them correctly for your year/model. Both floats for each carb need to be the same.Suppose I should do a search for the step by step of float adjustment, once again never having done it. Factory manual doesn't have much to say about it. Why would it be necessary if the floats were not removed?
Looking forward to that camp spot Brant. Sure hope it works out.1981 XS1100H Venturer
K&N Air Filter
ACCT
EBC Front Rotors
MikeComment
Have read through a bunch of carb threads. All say to measure to the highest point of the float, with the carb upside down. But just where is that? Found this picture.
Most discussion seems to involve the carb base and whether to measure with or without the gasket, but little if any mention of exactly where on the float to measure to.
My # 1 measurement is very close to 23 mm
My # 2 measurement is very close to 21 mm
Which one to use?
I know that 23 mm is the proper setting to use on the SG carb.80 SG
81 SH in parts
99 ST1100
91 ST1100Comment
80 SG
81 SH in parts
99 ST1100
91 ST1100Comment
Carbs inverted, highest point of float for measurement. Key is ALL be set identically the same with same method.
If using OEM float needles, setting floats identically the same will have running fuel levels really close to the same.
If using K&L or other aftermarket float needles, chances are pretty good running fuel levels will vary between all four carbs. The springs in the K&L float needles seem to have varying tensions, and I had one that compressed farther than the rest causing fuel to weep a wet place around bowl when bike was initially shut off.(maybe that's why five needles come in their packaging
Consequently, I've had many carb removal/installs from poor quality control of float needle construction
Quick carb install question. I have the carb bank slipped back onto the engine boots, but can't quite get it back on the air box boots. I think it's due to that damn airbox hanger thing. It's still hanging below it's mounting bracket.
Do I get that back where it belongs first (above the bracket), before connecting up the carbs?80 SG
81 SH in parts
99 ST1100
91 ST1100Comment
80 SG
81 SH in parts
99 ST1100
91 ST1100Comment
