a couple carb questions
  • DeanR
    • Jan 2005
    • 1499
    • Finger Lakes NY
    Forgot to mention. I did not remove the floats, needle valve assemblies or the mixture screws.
    Also forgot to mention that covers and bowls were on when I sprayed em down.
    80 SG
    81 SH in parts
    99 ST1100
    91 ST1100
      Originally posted by DeanR
      Well,carbs are cleaning up nicely. Even hit the bowls with some Mothers Aluminum Polish I had. Nice and shiny now! Also am using the outboard chrome covers from both sets, so now all 4 are chrome.
      I've been using a couple cans of carb cleaner and Simple Green and lots of Q tips. Walmart carb cleaner is so much cheaper than others. I have heard that it is much harsher? Any opinions about using it. Can't see spending any more than necessary just for cleaner.
      I did take the carbs outside (minus jets and diaphragms) and emptied a can on them. Would that have reached anything that it shouldn't?
      Regarding diaphragms, any cleaning or carefully wiping them down with something prior to installing recommended? Man they cost a fortune to buy!!
      Better quality of spray carb cleaner out there, but your location I'm sure limits getting the 'good stuff' like I can still get here.
      Just rinse any foreign matter off diaphrams.
      A pointy tapered toothpic is your friend for reamming clean the sideholes of the emulsion tubes and pilot jets. Pay particular attention that the teeny atomizing hole in end of pilot jets is open. Use a magnifying glass to inspect for any foreign 'science projet' that may be trapped down inside those pilot jets. It gets in there and gets trapped with no way out cept for a tiny wire to fish the foreign matter out....BTDT.
      If it was running fine prior to being ignored(STeeds will do that), I'd leave float levels where there at unless you replaced the float needle.
      • DeanR
        • Jan 2005
        • 1499
        • Finger Lakes NY
        What makes one carb cleaner better than another? They all seem to do the job?
        I ran some monofilament fishing line through all the tiny holes Brant, and soaked them, even though no innards much looked like they needed to be cleaned at all.
        80 SG
        81 SH in parts
        99 ST1100
        91 ST1100
          Lol.......your 'short changing' yourself Dean. Gonna have to pull those mix. screws(counts turns IN,lightly seating before removal), bowls, air jets out of back of carb bells. Blow carb cleaner through bottom bowl passage(watch the eyes, as it comes out top-side gasket surface), same for enricher circuit(with enricher on/open).
          BTW, if you didn't remove the floats, you didn't remove all the jets.
          Keep ALL pieces removed with that respective carb.
          Careful removing float pins! So as not to break a post, there's usually enough gap between head of pin and post to LIGHTLY wiggle in side-cutters as a 'lever', pulling pin as cutters are closed. Others have good success with a spring loaded center punch to pop the pin loose. Do NOT drive out from other end of float pin using anything else! After removal, chuck the pins up in your drill and with side of a file, remove that short raised shoulder on the 'stop' side of pin...just enough that they still 'drag' going in that final eighth inch. They can't come loose once bowls on, and it'll save your carbs from a broken post in the future.
            • 8061
            Randakk's Cycle Shakk has a float pin removal tool. It's expensive unless you break a float post. In that case, it's very cheap.
            FWIW, I use the spring loaded punch, more commonly known as an automatic center punch.
            • DeanR
              • Jan 2005
              • 1499
              • Finger Lakes NY
              #36
              Figured I'd get yelled at for not doing a complete job. Here's the reasoning. Maybe it makes sense, maybe not.
              Found the source of my #2 cylinder problem as I was removing the carbs. That was the sole reason for this work. As long as I was that far along, decided to take em all the way off even though the bike runs fine. Though I've successfully muddled my way through most everything on my bikes, I don't know a thing about carbs. So, because it runs well, I didn't want to mess with the floats and the needle valve things beneath. Or the mixture screws. I do have those air jets out and have cleaned out all the other open passages (though they didn't need it). Main jets, pilot jets, needle jets all done. Figure I can just put everything back in place, reinstall the carbs and be good to go. Hope so anyway.
              I will say that I do have one of these Ken Talbot creations...
              80 SG
              81 SH in parts
              99 ST1100
              91 ST1100
              • DeanR
                • Jan 2005
                • 1499
                • Finger Lakes NY
                #37
                Another picture because we all like pictures..
                80 SG
                81 SH in parts
                99 ST1100
                91 ST1100
                  • 8061
                  AH! I see your reasoning.
                    Dats' purdy!.........Jokin' aside, if bike is on centerstand, I'd put a small 2"X4" or similar under front wheel before installing carb bank. This will throw mounted carb level off ju-u-u-st enough that if a float were to 'hang' when initially filling bowls, fuel would run rearward out of venturi of suspect carb/s and not into head intake side, diluting/contaminating oil.
                    At this point, before start-up, leaving airbox off makes it easy to see which carb, if any may be overfilling.
                    Installing airbox BEFORE start-up will limit any unwanted ignition somewhere other than inside the cyls. due to an un-expected backfire thru a carb venturi.
                    • DeanR
                      • Jan 2005
                      • 1499
                      • Finger Lakes NY
                      #40
                      You got it Marty. Hope it's valid
                      Thanks for the tips Brant. Don't recall hearing about that before.
                      80 SG
                      81 SH in parts
                      99 ST1100
                      91 ST1100
                        .......Welcome Dean! I'm sure though, you recall unfortunate pics posted by a few of results of an unexpected open venturi backfire.
                        • DeanR
                          • Jan 2005
                          • 1499
                          • Finger Lakes NY
                          #42
                          Did I get the throttle stop thing on #3, and that stand-off loop on #4, on correctly? Forgot to make a note of how they were positioned.
                          80 SG
                          81 SH in parts
                          99 ST1100
                          91 ST1100
                            You got the throttle cable mount on there right. As far as that wire loop for the clutch cable, mine has been gone since I replaced the engine. But, yep, that's where it goes.
                              • 8893
                              I would flip it around with the sharp end pointing inward, just seems to make sense. Carbs look good BTW.
                              • DeanR
                                • Jan 2005
                                • 1499
                                • Finger Lakes NY
                                #45
                                Sure hope I'm not the only dummy that can tend to put the carb covers back on...forgetting to put the big spring back in!
                                Any lubrication to be done, such as choke or throttle linkages?
                                I didn't check/adjust float levels. Again because it runs well so I just put everything back as it was, just a little cleaner inside and outside.
                                80 SG
                                81 SH in parts
                                99 ST1100
                                91 ST1100
