a couple carb questions
  • DeanR
    • Jan 2005
    • 1499
    • Finger Lakes NY
    Possible to pull a pilot jet for checking/cleaning (#2) without pulling the carbs? (I suppose one would need just the right 90 degree bent screwdriver)
    New float bowl gaskets required whenever the bowls come off?
    Can 81 bowls go on an 80, to gain the drain feature?
    80 SG
    81 SH in parts
    99 ST1100
    91 ST1100
    Yes
    Yes
    Yes
    The only thing to watch for is trying to get the pilot out without stripping the top of the jet. IF it's been in for a while, I would pull the carbs! I don't replace carb gaskets unless they rip badly as I pull the bowl. I believe you can put the '82 bowl on the '78 carb, so they will all interchange. BUT I'm going from memory, and most of my work has been on '78 to '80 machines..
      Yes, but wouldn't risk as it only takes 10min. to pull carb bank.
      No, they're fairly thick and robust.
      No, IIRC pic-up tube doesn't clear correctly.
      Dean, overall if you suspect contamination/blockage that's carb related, even if just one carb is suspect, others may soon follow. IMO, worth the extra 10-15min. to remove carbs and ALL bowls and do a close inspection of internal pieces.
      • mack
        • 2411
        • Ontario, Canada
        Bowls
        The pick up tube for the enrichement cct is offset slightly from the 81's so the bowls aren't interchangeable. I agree with pulling the carbs and cleaning them properly. From a 90 degree screwdriver you won't get that pilot out w/o stipping it, then you have issues.
        While it seems like a daunting task, you can have the carbs out in 8 minutes provided you don't have an octy.(Thats another minute)
        Remove seat and tank
        Loosen intake and airbox clamps
        Slip air box clamps off all the way to the rear until they are against air box
        Remove three bolts holding air box in place and pull air box to the rear
        Remove crankcase breather tube upper clamp and pull the tube out, bend it down and to the rear and tuck under the air box
        Pull the carbs straight back, wiggle them up and down a few times and they will pop out of the intakes.
        Tip them up slightly forward and remove to the left side paying attension to the head oil feed tube and throttle linkage.
        Remove throttle cable as soon as you have enough play
        Remove vacum advance hose, Note the it attaches to the #2 carb
        Slide the carbs out the rest of the way.
        Reverse to install.
        mack
        79 XS 1100 SF Special
        HERMES
        original owner
        81 XS 1100 LH MNS
        SPICA
        78 XS 11E
        IOTA
        https://youtu.be/wB5Jfbp6SUc
        https://youtu.be/RaI3WYHSuWA
        Frankford, Ont, Canada
        613-398-6186
        • DeanR
          • Jan 2005
          • 1499
          • Finger Lakes NY
          Yea, I know I should take em off. But it's cold out and a scary job! Quite sure they've never been removed. Cylinder 2 has taken a long time to get going for quite a while now, but once that #2 header finally gets hot, it runs great.
          Had the carbs off the ST recently, to replace all hoses while I was doing the timing belt.
          So,
          It's gonna be nice and warm on Christmas Eve. Good time to do it. Actually I have removed XS carbs once, when I stripped everything off the SF.
          I'll get the kitchen table ready for some work to be done.
          80 SG
          81 SH in parts
          99 ST1100
          91 ST1100
            So,
            Dean, having the STeed carbs off(BTDT), you should have the XS carbs off in 10min........while blind-folded.
            I'll add remove lower portion of air-box and filter first........gives the extra room to drop box DOWN, leaving carb intakes tottally clear of any air-box interference. As you go back in from left side with carb bank, hook up throttle cable.....easier than after carb bank is mounted.
            • CaptonZap
              • Jun 2010
              • 1748
              • Denver
              One other tip, since you say you are working in the cold.
              When it comes time to reinstall, borrow your wife or girlfriend's hair dryer. Set it on high heat, and blow it on the rubber manifold tubes. Smear a little vasaline on the insides. When they are good and warm, slip the carbs in.
              Do not use an industrial heat gun without constant monitoring, as they can melt the rubber.
              CZ
                CZ
                +1 on that. Even if you just set a little electric space heater so it blows on the boots it makes a HUGE difference when it's cold.
                  • 3371
                  Yes, +1 on what CZ said, get the boots good and warm. I find a quick shot of hairspray on the outside of the carb outlets provides some add'l lube while it's wet, then some stick after the carbs are slid in and dries. Or some rubbing alcohol slathered on the carb outlets for a bit of add'l slick factor that dries without a trace.
                  2001 ZRX 1200
                  1982 Seca 750
                  1983 Nighthawk 550
                    Are we at the Salon?
                      Hi Dean,
                      SO No Turkey being cooked at your house
                        Hmmmm.......that went from carb R/R to hands-on cosmotology fairly quick.
                          • 3371
                          Ba80, nothing but the finest treatment for the XS. Probably best to use a boutique brand of hairspray vs Wal Mart "White Rain".
                          I need to do a re-hab of the 80SG carbs over the winter/this spring. When I had them apart replacing o-rings on the needle seats and fuel screws before the most XSellent Colorado Rally this past July, the needle tips had pronounced rings on them from resting on the seats, and I feel that is causing the engine to be fat at idle and just off idle by not controlling fuel level as well as it should in the bowls.
                          I learned a crap-ton about carbs doing the retro fit of ZZR1200 carbs onto my ZRX1200, and now I have a set of ZRX 1200 (Keihin CVK36 mm) carbs that just might find a way onto the 80SG...
                          For anyone that has done the ZRX carb swap, has anyone kept the stock airbox for the stealth look instead of pods?
                          2001 ZRX 1200
                          1982 Seca 750
                          1983 Nighthawk 550
                            ......WhiteRain still makes for the best grip-glue...for all brands/styles of scoots.............a shot of silicone spray in the carb boots makes short work of carb installation........especially helpful sprayed inside the air-box boots.
                              • 8083
                              Armor All or any similar product is my choice lube for carburetor installation.
