a couple carb questions
    Originally posted by DeanR
    Well, things are finally all buttoned up, starting well, running well in the garage and ready for a quick unregistered and uninsured jaunt down the street.
    Thanks for all the help and guidance guys.
    Good to hear it's back to life Dean...........now you can resolve that pesky coolant weep on the main ride and give it some test riding time before heading this direction in June.
    • LoHo
      • Sep 2002
      • 1342
      • Fresno, CA
      #92
      A tip on fixing diaphragms that may have been covered:
      Use the black Plasti-Dip, but be sure to dab it on BOTH sides of the pinhole. That way, it sticks to itself in the hole and forms a little plastic rivet that handles the air pressure from inside and outside the carb, which is its job anyway. Remember to clean around the hole with a Q-tip and appropriate solvent to help the mend stick.
      • DeanR
        • Jan 2005
        • 1499
        • Finger Lakes NY
        #93
        Well the ride down the road revealed something new, which I should know the answer to, but don't.
        Rpm's shoot up when the clutch is pulled in. What might be the reason for this?
        80 SG
        81 SH in parts
        99 ST1100
        91 ST1100
        • tcoop
          • Nov 2009
          • 793
          • South Weber, UT
          #94
          Possibilities
          1. Air/Vacuum Leak some where
          2. Choke is still pulled out (BTDT)
          3. Idle needs to be adjusted
          Ty
          78 XS1100E - Now in Minnesota
          80 XS1100LG - The Punisher
          82 XJ1100 - Daughter's Bike
          • jrm000kc
            • Jun 2012
            • 66
            • Kansas City, Mo.
            #95
            Wow them are some purdy carbs! Cleaned mine last year-but since I have no filters and the gas leaked out I think my enrichment ports are blocked since I have to give some throttle when I start up.
            Don't ask my motives-but Sunday I went through my extra parts and saw the octopus I took off last year. Having some extra fuel line I decided to put it back on. I get about 99% done until I get to the part when I put the tank back on-and its a total PITA to get the darn fuel line to match up with the fuel ports. There's a very small threshold for getting them just right, and I tried about 3 different ways with different lengths of the braided nylon line I bought. Whatever way I tried I'd get a kink somewhere. Do the left and right carb hookups point up or down? Anyhow, I got tired of fiddling around and pulled everything off and went back to my 'H' arrangement-and to my dismay I didn't have any more plugs to put on the prime ports. I thought 'Off' meant what it says, but nope, I had gas running out.
            Is there truly any difference in performance between letting the gas gravity feed versus the diaphragm actually forcing gas? I would think the positive force of the diaphragm would deliver a better flow. The Japanese engineers really did an awesome job on the XS as far as keeping things simple, but when I look at the octy I ask myself "why?". I know it keeps gas from flooding out but was that the only reason? I think I'll get some different fuel line and a new diaphragm and have another go with the octy.
            79 SF
            Raptor Auto CCT, octopus-less, tapped/plugged fuelcock prime ports, new shorter handlebars, original stock Yamaha seat (w/ Octo routing diagram), looking for stock grab-bar/sissybar/backrest.
              None........vacuum pulls diaphram, which opens valve. No vacuum, valve stays closed....hopefully. Nothing magic goin' on there.
                The diaphragm does not add any pressure to improve gas flow. The octy is just a valve that opens when it is actuated by the engine vacuum. So, the octy actually restricts the flow a tiny amount (negligibly) compared to removing it.
                • jrm000kc
                  • Jun 2012
                  • 66
                  • Kansas City, Mo.
                  #98
                  Okay. Since there's no difference I see no point in messing with the octy. What's the purpose of the two screws above each fuel port? Instead of having to replace caps for the prime port I'll never use again is there any type of single fuel port replacement anywhere?
                  I probably check/replace the gaskets and the screens on the internal tank petcocks. (I'm sure my tank has a lot of gunk in it.) I'd like to see if I can figure out a way to block that prime port. (Caps work-temporarily. I'd like to figure out a permanent solution.)
                  79 SF
                    • 8938
                    Might help...
                    • DeanR
                      • Jan 2005
                      • 1499
                      • Finger Lakes NY
                      #100
                      Have wondered the same thing.
                      also:
                      RPM 's shoot way up when the clutch is pulled in. Idle RPM is fine. What might be the reason for this?
                      I know you know out there!
                      80 SG
                      81 SH in parts
                      99 ST1100
                      91 ST1100
                        • 8938
                        Check for vacuum leaks, cracked port caps, vacuum lines, etc. I would sync the carbs and adjust the idle mixtures, see if it persists. My bet is out of sync. carbs.
                        • donebysunday
                          • Oct 2012
                          • 1737
                          • New Berlin, Wi.
                          #102
                          The 2 screws are to flush internals of the petcock (ON/RESERVE/PRIME routes) clean without having to remove it and or the fuel lines. JMHO
                          76 XS650 C ROADSTER
                          80 XS650 G Special II
                          https://ibb.co/album/icbGgF
                          80 XS 1100 SG
                          81 XS 1100LH/SH DARKHORSE
                          https://tinyurl.com/k6nzvtw
                          AKA; Don'e, UD, Unca Don'e
