Jet Kit for 79 xs1100F
  • #61
    Early Carbs
    Originally posted by IanDMacDonald View Post
    I know we have the same bike, but do u have the '79 carbs? Stock, you should have 137.5 Mains, and 40 Pilot jets(?). Start there. Plug chop come Spring.
    All of the stock 78E Carbs that I have disassembled had 137.5 mains, 45 pilot jet, and 210 air jet - even though none of the service literature eludes to those sizes for the E. Also, all of the emulsion tubes had the same number of holes in them.
    The 79F/SF carbs have 137.5 mains, 42.5 pilot, and 180 air jet. The emulsion tubes are different. Tubes with the most holes go to the inner carbs - least holes to the outer carbs.
    Also have noticed that the float height setting varied during the years. Check the manual for the type/year carbs that you are using for the correct setting.
    1981 XS1100H Venturer
    K&N Air Filter
    ACCT
    Custom Paint by Deitz
    Geezer Rectifier/Regulator
    Stebel Nautilus Horn
    EBC Front Rotors
    Limie Accent Moves On In 2015
    Mike
    • #62
      Air Filters
      The link has three options. I believe the Hi-Flo is just a paper filter and probably works great. The Uni is a very good filter and costs much less than the K&N. The K&N listed here is probably at about the best price you're going to find it.
      • #63
        K&N Air Filters
        Here is a good price and free shipping:
        http://www.ebay.com/itm/K-N-Air-Filt...b37d96&vxp=mtr
        K&N Air Filter
        ACCT
        EBC Front Rotors
        Mike
        • #64
          Thanks Matt. I knew 40 did not sound right. And, I believe the air jets are basically non-removable, correct? Aren't they pressed in?
          • #65
            *I meant Mike
            • #66
              No, back of carb bell, and they are SmallMikuni main jets.
              • #67
                To expand and clarify on this. There are 2 different air jets. The pilot air jet is removable. There is also a main air jet and that is a pressed it fixed jet.
                • #68
                  Thanks Nate. So, the 180 air jet is the pressed-in jet, correct?
                  • #69
                    Nope.
                    180 Pilot air jet is threaded in (LH side of bell).
                    140 Main air jet is pressed in (RH side of bell, I think)
                    • #70
                      Thanks for all the advice. I cleaned up the air box today and I am missing one of the special nuts that hold the air box together. I don't suppose any of you would happen to have a air box nut laying around, would you? I couldn't find one online.
                      1979 xs1100f
                      New Fuse Box
                      Progressive Shocks
                      Gold Valve Emulator
                      Dyna Coils
                      Electronic Flasher
                      Led Headlight
                      Led Turn Signals
                      4 Led Driving Lights
                      2nd Gear Fix
                      Auto Cam Tensioner
                      Digital Dash
                      Stainless Braided Lines
                      R6 4 Piston Calipers
                      Stainless Bolt Kit
                      Maier Fairing
                      Dyna Balancing Beads
                      Spin On Oil Filter
                      Plasti Dip Rims
                      ISO Grips
                      • #71
                        I was looking a these last week before I freed mine up with an easy out. Seller is in the UK somewhere I believe.
                        http://www.ebay.com/itm/New-Genuine-...16a7e7&vxp=mtr
                        81 xs1100 SH
                        81 xs1100 SH (parts)
                        80 suzuki gs550et
                        07 suzuki S40
                        • #72
                          I'm a convert to the UNIs. They are what almost every motocrosser uses and they want the best flow and dust control.
                          Here's a quote from this thread:
                          Uni's are generally less expensive
                          Uni's can be oiled with almost anything (although Uni does recommend thier own foam oil)
                          Uni's are arguably easier & faster to clean
                          Uni's are arguably more durable
                          The Uni pods on my Triumph outflow the K&N's they replaced"
                          "aaaaannnnnndddddd...... oiled foam air filters have been proven in laboratory tests to STOP MORE DIRT than gauze and screen, time after time. Isn't that the whole reason we decided to use air filters anyway?
                          Living to EXcess.
                          1979 XS1100F Canadian, stock exhaust. Top end rebuild in progress.
                          • #73
                            I will NEVER use a Uni in a street bike. I've taken a few air boxes apart, and the one with the uni had nothing but crud clogging up things. They WILL come apart after just a few years because of the heat and oil in the street bikes. I know, race bikes get hotter, but not for the length of time a street bike does.
                            I run K&N in all my bikes, as well as the wife's ML320. JMHO
                            • #74
                              So i pulled my main jets yesterday and I can't tell what size they are. Is there a special number I should be looking for? If so where should it be? I can't see any numbers on these jets. Perhaps they wore off.
                              1979 xs1100f
                              New Fuse Box
                              Progressive Shocks
                              Gold Valve Emulator
                              Dyna Coils
                              Electronic Flasher
                              Led Headlight
                              Led Turn Signals
                              2nd Gear Fix
                              Auto Cam Tensioner
                              Digital Dash
                              Stainless Bolt Kit
                              Maier Fairing
                              Spin On Oil Filter
                              Plasti Dip Rims
                              ISO Grips
                              • #75
                                I have one. Message me if you are interested.
                                79 SF parts bike.
