I am stumped
Exactly...
That was my point. It would be a quick, easy way to determine if the coils and/or wires are doing their job on each cylinder.
Quick, easy tests, to either rule out potential problems, or identify them.
It's a whole lot quicker to do that, than say, pull the carbs.
And, if ignition has been ruled out as the problem area, then move to the carbs.
I always prefer to start from baseline... Rule out the easy...then after things point the direction of carbs, go there.
Most times, that IS where the problems are, but one never knows.'82 XJ1100J Maxim (has been sold.)
'79 F "Time Machine"... oh yeah, Baby....
(Sold back to Maximan)
2011 Kaw Concours 14 ABS
"What we have here is a failure to communicate."Comment
There are much easier ways but I won't mention them because some people have read books by people that say I'm wrong. Experience means nothing sometimes.
Just look it up..........Greg
KEEP THE RUBBER SIDE DOWN
1978 XS1100E Modified
1978 XS500E
1979 XS1100F Restored
1981 Suzuki GS1100
1983 Suzuki GS750S Katana
1983 Honda CB900 CustomComment
1978 XS500E
1981 Suzuki GS1100
This makes no sense what so ever. Okay, I have confirmed that the fuel levels in the carbs atre correct and there is no flooding. I hooked up the strobe light and I have no signal on both 1 and 2 and full signal on 3 and 4. i checked timing on 4 and it is good. with carbs paired 1 & 2 / 3 & 4 and ignition paired 1 & 4 and 2 & 3, what the heck is going on here?
RobKEEP THE RUBBER SIDE DOWN
1978 XS500E
1981 Suzuki GS1100
Have you done a compression test?Greg
My tester is not working relibility but it makes no difference, there's no signal from the electrial system. I just switched out plugs and no change. The inductive timing light should see the signal even if a cylinder does not fire?
Could this be the CDI box?
RobLast edited by 79XS11F; 08-23-2014, 09:55 AM.KEEP THE RUBBER SIDE DOWN
1978 XS500E
1981 Suzuki GS1100
And the plot thickens. With the plugs on the head i see spark across all 4 but the strobe light will not detect the signal on 1 and 2 but does on 3 and 4. I am wondering if there is a posibility that there is an exhaust system blockage. Maybe some freaking critter got in and blocked the tail pipe of headers or something. Is there any way to determine an exhaust system blockage without exhaust system removal?
1978 XS500E
1981 Suzuki GS1100
There's nothing in the tail pipes right up to the first baffle, with the air box cover off there no blockages in the stacks or air intake snorkel and no difference in the way it runs. I'm really getting discouraged now :-(KEEP THE RUBBER SIDE DOWN
1978 XS500E
1981 Suzuki GS1100
Sounds like you may have a weak coil. If there's a weak spark it won't fire under compression.
You got another you can swap out?Greg
Apples and oranges.........your secondary ignition issue has nuttin' to do with what exhaust is or isn't doing..........(hang on.....gotta think this thru for a sec.)And the plot thickens. With the plugs on the head i see spark across all 4 but the strobe light will not detect the signal on 1 and 2 but does on 3 and 4. I am wondering if there is a posibility that there is an exhaust system blockage. Maybe some freaking critter got in and blocked the tail pipe of headers or something. Is there any way to determine an exhaust system blockage without exhaust system removal?
Rob81H Venturer1100 "The Bentley" (on steroids) 97 Yamaha YZ250(age reducer) 92 Honda ST1100 "Twisty"(touring rocket) Age is relative to the number of seconds counted 'airing' out an 85ft. table-top.Comment
