I am stumped
    Originally posted by 79XS11F
    So the issue with the miss is back. It's not carbs, it's not coils, it's not the TCI box, the plugs or plug caps. I have switched out all those components with know good ones from my hop up bike.
    So.... do I start thinking about defective pickups? Do I replace the pick ups with the ones on my hop up bike or is there something else I should be looking at before I do that.
    The miss is not as bad as it was last year. is affecting # 1 and #4 and is present across all throttle settings.
    Perhaps it's just an OLD WEAK ignition system?
    It's that alien mother ship that passed over.
    If it's 1 & 4 it has to be a coil or a pick up coil.
    Have you ohmed out the pickup coils?
    I had a set that drove me crazy on an SG a couple years ago. They ohmed out at slightly lower readings than the spec range. This bike WOULDN'T start (no spark) if the temperature was below 40º F. If I heated the timing cover it would eventually start and run on 2 cylinders until the engine warmed up a bit then the other 2 would kick in. Swapped out the pickups and it works fine to this day. Go figure.
    • 79XS11F
      • 3563
      • Ottawa, Ont. Canada
      #92
      So they can be defective or become defective over time. how do I test them? Is the process in the manual?
      Rob
      KEEP THE RUBBER SIDE DOWN
      1978 XS1100E Modified
      1978 XS500E
      1979 XS1100F Restored
      1981 Suzuki GS1100
      1983 Suzuki GS750S Katana
      1983 Honda CB900 Custom
        The testing procedure and specs is HERE
          You can try checking voltage at the red/wht wire at the solenoid positive solder joint. The TCI gets it's power from this wire. If it is much lower than the voltage reading taken at the fuse panel, you have a weak/corroded/poor connection supplying needed voltage at the TCI. It's an easy check that only takes a minute. GL
            Don't forget, you need AT LEAST 10.5 Volts to fire, and 11.5 Volts for a good spark. Check you connection at the ignition switch as well! A drop of over 0.2 Volts is a problem.
              Good points however, the stated problem is with just 2 cylinders though. 1 & 4.
              • 79XS11F
                • 3563
                #97
                The engine fires right. It's just got an occasional miss on 1 and 4 across the board.
                Rob
                1978 XS500E
                1981 Suzuki GS1100
                  If this is your "modified" bike then it's just a guess but you probably have a pick up coil shorting internally or a pick up coil wire that is shorting or fixin' to break.
                  • 79XS11F
                    • 3563
                    #99
                    No it's not the modified bike. I checked the pick up wires they were good. but I will check them again before I pull the entire timing unit out of her.
                    The Accel coils are 3 Ohm type so if I try them on again I guess I am suppose to remove the ballast resister which I didn't do on ether bike.
                    Rob
                    1978 XS500E
                    1981 Suzuki GS1100
                      The Accel coils are 3 Ohm type so if I try them on again I guess I am suppose to remove the ballast resister which I didn't do on ether bike. Rob
                      So, it IS modified.........
                      • 79XS11F
                        • 3563
                        #101
                        No it's not? I have the access coils on my bench but could install them pretty fast.
                        1978 XS500E
                        1981 Suzuki GS1100
                          Looks like by your signature you have a lot of other XS's. Borrow some STOCK coils and see if that makes a difference.
                          Go from there.
                          • 79XS11F
                            • 3563
                            #103
                            Go from there.
                            I have already switched out the coil for 1 and 4 with others I have here with no luck. This is why I am thinking pickups is the problem but I don't really want to switch out the entire timing unit with the one on my modified bike if I can avoid doing that. I don't really want my modified bike becoming a "parts bike" LOL
                            Rob
                            1978 XS500E
                            1981 Suzuki GS1100
                              Best test though. If they come off they can go back on.
                              • 79XS11F
                                • 3563
                                #105
                                I'm going to go at it tomorrow I guess.
                                1978 XS500E
                                1981 Suzuki GS1100
