I am stumped
    Originally posted by skids
    OK, so I say that Brant wins with his "science project" assessment. Personally, I would try the carb spray technique before tearing the carbs off of the bank-'o-carbs. This is seriously easier and I have had great success with that. No need to remove butterfly shafts and no need to cuss God while you separate the carbs from the bracket! (I have begged forgiveness!)
    I don't recall anyone saying to separate the carbs.
      Hey Greg,
      Probably inferred with regards to checking the fuel inlet "T's", which they may have felt required the carbs seperated to check the T's. I know they can be checked by just removing the float valve seat and screen, and then can be accessed with carb cleaner spray to insure it can flow. But after reviewing the carb bodies Grant/Mack sent me, I was surprised to see how SMALL the little hole is at the inside END of the Carb body T fitting where it leads into the carb body/float valve needle seat area.
        You WOULD have to separate them to clean them properly but not to check them.
        The aluminum inside those T's will corrode and close up. The one I ran into I couldn't clean without destroying it as it was badly deteriorated so it had to be replaced. it was plugged solid going into one carb. That was on the green 79.
          Rocky Mountain HIGH.
          Musta' been the 14,101ft. atop Pikes Peak.
            Meanwhile, back in Denver.........
              Welcome Back Rob.
                I avoid THAT side of the 'hill'.
                BTW, your comment comparing Colo. mountains to western Montana.........could'nt agree more, specially from Big Hole Nat'l Btlfd up to Missoula with the Bitterroots as a backround drop. Can't forget about Cody's Nat'lFirearmsMuesum either!
                  • 6765
                  Hey Rob...just wondering with all that assy and dis-assy of the carbs if you are re-synching them each time??? since no one has mentioned it... Hope you can narrow it down...
                  2005 Honda SilverWing 600
                  2018 Honda PC-Xpress 150
                  • 79XS11F
                    • 3563
                    • Ottawa, Ont. Canada
                    Welcome Back Rob.
                    Thanks Phil )
                    KEEP THE RUBBER SIDE DOWN
                    1978 XS1100E Modified
                    1978 XS500E
                    1979 XS1100F Restored
                    1981 Suzuki GS1100
                    1983 Suzuki GS750S Katana
                    1983 Honda CB900 Custom
                    • SFerinTEXAS
                      • Jun 2006
                      • 877
                      I would go back and reconfirm those things in your first post. Years ago I put a new dist cap on a Toyota. On a particularly humid day in this northern province of mexico (spell check tried to make me cap the m in that word as if I had some respect for them)it would not start. After several days and too much money that new cap was the problem. I considered it confirmed. I was wrong. What I had ruled out was my problem.
                      79SF
                      XJ11
                      78E
                      • 79XS11F
                        • 3563
                        That's what I'm going to do. Give it a COMPLETE tune up and ANOTHER carb cleaning.
                        Rob
                        1978 XS500E
                        1981 Suzuki GS1100
                        • 79XS11F
                          • 3563
                          Okay, So yesterday I checked and adjusted the valves and confirmed the valve timing. I cleaned the carbs again and they are clean. I set all the floats at 1" and they are all the same. Installed the carbs and there's no leakage of gas and the bike still dose not run right. Here's what I got.
                          - Misfire on ether #1 or #2 as felt at the tail pipe. bit od back firing. I would call it occasional.
                          - When I give her a little twist and let go the RPMs seem to float and come down slowly as compared to the typical on/off of a crisp XS1100 that runs well.
                          - she won't hold an idle setting.
                          - at idle the vacuum advance is bouncing but not from stop to stop. but there is quivering within a 1/4" back and forth at a high speed.
                          The exhaust note dose not sound right.
                          How does one check for exhaust system blockages? Is there any way to do this with out pulling the exhaust? I do feel exhaust flowing on both sides however.
                          So I guess I will have to do the on the bench fuel height in the bowls thing which I hate do to the time it takes to it. Any other input from anyone will be approached. There's not much "nice" riding time left up here so I would be happy to have her sorted out sooner rather then later .
                          Rob
                          1978 XS500E
                          1981 Suzuki GS1100
                            Are the timing advance mechanisms free? Checked timing?
                              I haven't seen anywhere in this thread where you've synced them.
                                • 6765
                                I did ask this question........
