Rear Wheel Help
    • 9980
    Originally posted by TheRev
    So do you think this is my problem? Do I take the nuts off and use the bolts or try to find the origionals?
    Shorter bolts, they shouldn't stick out much past the flange on the u-joint.
    • TheRev
      • Jun 2012
      • 235
      • Madison, Wi.
      #77
      Awesome. Thank you so much. I appreciate it. I will switch the bolts tomorrow. Thanks
      1979 xs1100f
      New Fuse Box
      Progressive Shocks
      Gold Valve Emulator
      Dyna Coils
      Electronic Flasher
      Led Headlight
      Led Turn Signals
      4 Led Driving Lights
      2nd Gear Fix
      Auto Cam Tensioner
      Digital Dash
      Stainless Braided Lines
      R6 4 Piston Calipers
      Stainless Bolt Kit
      Maier Fairing
      Dyna Balancing Beads
      Spin On Oil Filter
      Stebel Nautilus Horn
      Plasti Dip Rims
      ISO Grips
      • TheRev
        • Jun 2012
        • 235
        • Madison, Wi.
        #78
        Thank you so much phil. I am so happy to have found this forum. You all are a great help. Thanks again.
        There shouldn't be nuts on the back of those 4 bolts, the u joint itself has it's own threads. Not the correct bolts either.
        1979 xs1100f
        New Fuse Box
        Progressive Shocks
        Gold Valve Emulator
        Dyna Coils
        Electronic Flasher
        Led Headlight
        Led Turn Signals
        2nd Gear Fix
        Auto Cam Tensioner
        Digital Dash
        Stainless Bolt Kit
        Maier Fairing
        Spin On Oil Filter
        Plasti Dip Rims
        ISO Grips
          • 8766
          No problem, a picture is worth 1000 words.
          • CaptonZap
            • Jun 2010
            • 1748
            • Denver
            #80
            The parts list in CBugs site says that the bolts are washer (flange) based.
            Part number 90105-08066-00 #39 in this illustration.http://www.yamahamotorsports.com/par...S1100G_-_1980)
            They go in from the front, and thread into the U-joint flange. Check the internal threads to make sure that the PO didn't do something dumb, like force the wrong pitched bolts into the hole. And then use a smaller diameter bolt and nut clear through to "FIX" it.
            Torque them real tight. (I can't find a torque spec at the monment).
            CZ
            • TheRev
              • Jun 2012
              • 235
              • Madison, Wi.
              #81
              Is there any way you can take a pic of your u joint bolts? I know it's a lot to ask I can't seem to find the ones that belong there. The darn microfiche doesn't tell how long they are supposed to be. I really appreciate it. Thanks
              1979 xs1100f
              New Fuse Box
              Progressive Shocks
              Gold Valve Emulator
              Dyna Coils
              Electronic Flasher
              Led Headlight
              Led Turn Signals
              2nd Gear Fix
              Auto Cam Tensioner
              Digital Dash
              Stainless Bolt Kit
              Maier Fairing
              Spin On Oil Filter
              Plasti Dip Rims
              ISO Grips
                • 9980
                I should have several in my bolt bin. I'll get you the size and thread pitch.
                If you like I can send you some.
                • CaptonZap
                  • Jun 2010
                  • 1748
                  • Denver
                  #83
                  You can measure the length by adding the thickness of the middle drive flange, and the thickness of the U-joint flange. Add a couple of millimeters. You should see a couple of threads sticking through on the back side. And really tighten them. The XJ manual calls for 31 ft lbs.
                  Did you check to see if the internal threads on the U-joint flange are buggered?
                  Greg would have the flanged head bolts, which would be better than plain heads, so take him up on his offer.
                  CZ
